02-21-2016, 06:44 AM | #1 |
Rep 32,881
Extra USB Audio/Apps Socket Mod Guide
I just thought I'd share this little mod I did today, it gives you an extra USB socket which can be connected to behind the dash as I've done with my Brodit phone mount, or it can go in the glovebox where there is a hole already there for it.
It is handy if like me you have the phone mounted on the dash and want to use connecteddrive apps without running a cable from the USB under the armrest, also so you can have 2 devices attached without the need to swap them over, for instance a USB flash drive/HDD and a phone/ipod. This is for cars with NBT/NBTevo Pro Media (maybe also newer Business Media) and no factory EBT (unless you want to disconnect the snap in adapter), as this second USB goes in the snap in adapters USB2 socket on the back of the head unit, which is only empty if the car does not have the snap in adapter preperation. Also you need to code EBT for it to work. Guide: 1) Buy this cable and socket: http://www.ebay.co.uk/itm/BMW-CIC-NB...YAAOSw2s1UvjHy 2) Remove head unit as shown in this video (ignore removing the head units plugs at end): 3) Connect cable to the empty USB2 socket as shown in pics below. 4) Either plug your phone cable in and feed out under the dash trim, or run the cable to the left hand side of glovebox and remove the little square cover to reveal the USB socket hole. 5) Code EBT, see my guide for that here: http://f30.bimmerpost.com/forums/sho...ighlight=idiot 5) Open BMW Connected app to automatically connect, or select in External devices where it will show up as the snap in adapter device. Don't forget to appreciate this post if you found it helpful! Last edited by teaston; 01-29-2017 at 03:12 PM.. |
02-21-2016, 06:58 AM | #2 |
Rep 1,404
Nice work, very clean looking as well, I might have to give this a go, started keeping my phone on the dash as well and can't be bothered with any more snap-in adapters!
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
LobB5109.00 |
02-21-2016, 07:12 AM | #3 |
Rep 19,982
Good post teaston, should be useful for a few folk. Makes a change from the usual repeated debates!
But the key question of course with this mod is.... Will it affect the warranty?!
LobB5109.00 |
02-21-2016, 10:46 AM | #6 |
Rep 500
Drives: BMW G20 M340d
Thank you for the detailed guide. May I ask you whether the cable is of exact length or should we tie it in the back of the HU to avoid rattle? Also if the car is already coded for EBT then it's a matter of the cable to connect is it correct?
Cheers
Jay |
LobB5109.00 |
02-21-2016, 12:27 PM | #7 |
Rep 4,939
Drives: 340i MPPSK
Great guide and would love an extra USB port because I'd like to connect my phone for BMW apps at the same time as a USB stick of mp3s. However knowing my luck I'd have major squeaks & creaks after reassembly
Life is a state of mind |
LobB5109.00 |
02-22-2016, 05:04 AM | #10 |
Rep 4,653
Is there a usb socket in the glovebox? Ive bought a cheap tracker and would like to stash it somewhere discreet to power it.
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
LobB5109.00 |
02-22-2016, 05:07 AM | #11 | |
Rep 32,881
LobB5109.00 |
02-22-2016, 05:15 AM | #12 | ||
Rep 4,653
Steve Roberts UK
LobB5109.00 |
02-22-2016, 05:21 AM | #13 | |||
Rep 32,881
LobB5109.00 |
02-22-2016, 05:51 AM | #14 | ||||
Rep 4,653
Steve Roberts UK
LobB5109.00 |
02-22-2016, 05:56 AM | #15 |
Rep 32,881
I would tap the wires that feed the under glovebox 12v socket so it's all hidden behind the dash with one of these (depending if it micro or mini USB):
http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB And some scotch locks: http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB |
LobB5109.00 |
02-22-2016, 06:04 AM | #16 |
Rep 4,653
Hi where is the 12v socket in the glovebox?
Steve Roberts UK
LobB5109.00 |
02-22-2016, 08:13 AM | #19 |
Rep 275
Excellent post! Ill be ordering one of these for mine when it arrives.
Where did you get the brodit mount from by the way?
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
02-22-2016, 08:18 AM | #20 | |
Rep 32,881
http://www.dsldevelopments.com |
LobB5109.00 |
02-22-2016, 11:09 AM | #21 |
Rep 8,525
I installed an additional USB cable from the head unit to the provided cut-out in the glovebox - works a treat and BMW Apps from my iPhone 5S are displayed without any problems that I've encountered.
One piece of advice - get yourself a fishing tool : trying to thread the USB cable to the back of the glovebox is an absolute bitch without one. I tried and tried to remove the entire glovebox but no joy.
LobB5109.00 |
