07-11-2018, 01:54 PM | #2267 |
Rep 41,220
Yes, although I assumed Unit was installed in car with Gateway connection.
07-11-2018, 02:06 PM | #2269 |
Rep 41,220
ID4 Hardware has 2 Gb of Ram. ID5 has 4 Gb. If you flash ID4 Hardware with ID5 Firmware, it will run slow, and suffer frequent reboots as it does not have enough memory. Also, unless car has a functional ATM module, you will loose all Telematics (e.g. RTTI).
07-11-2018, 02:46 PM | #2270 |
Rep 211
Ok. Thanks shawn.
I do not have telematics services.. I think it's faster evo id4 what nbt 609 professional. the maps evo. I do not know if they are better than NEXT of the NBT? |
07-11-2018, 02:56 PM | #2271 |
Rep 41,220
Although NBT2 ID4 and NBT2 ID5/6 run the same EVO map, the issue is the ID5/6 firmware on ID4 hardware runs sluggish.
07-14-2018, 02:02 AM | #2272 |
Rep 2
hi shawnsheridan can you send me the link for esys the latest working version, i have a bmw 3 series f32 2013, i have the cable but havent got the full software package, can you share with me. thanks
07-14-2018, 02:42 AM | #2273 |
Rep 41,220
PM sent.
07-17-2018, 03:27 AM | #2274 |
Rep 44
I want to code a new G31 with I-Step S15A-18-03-532
1a) SeatBeltReminder Driver OFF 1b) SeatBeltReminder CoPilot OFF 2) AutoStartStop default OFF for 1) in ACSM5-1B29, "3001 Gurtwarnung" it should be "Gurtwarnung_0_0_255". Currently it is set to "UNK_PARAM_2" "UNK_PARAM_5" ("Wert 4"). Is that the correct option for 1a) and what is the target value? It is said to be different for different I-Steps? for 2) in old F10-days, it was in CAS. Where is it now? |
07-17-2018, 03:52 PM | #2275 |
Rep 1,387
Can anyone confirm if there's any different requirements between 2.8.0 and 2.8.2? I'm trying to install it onto a family members W7 laptop and 2.8.2 just crashes on launch, yet 2.8.0 opens perfectly fine.
Java is up to date at version 181 and .net framework 4.7.2 - anything else I should be checking?
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
07-18-2018, 04:23 AM | #2276 |
Rep 1,387
*update to my last post, formatted his laptop with a fresh install of Windows 7 64bit and it's still the same - I can only presume then 2.8.2 has a major bug and doesn't work?
2015 435i - 401whp
07-18-2018, 06:43 AM | #2278 | |
Rep 41,220
07-18-2018, 08:19 AM | #2279 |
Rep 15
could somebody please give me detailed instructions on how to get warning chimes and the date and time to set on my retrofitted nbt pro nav with no combox ? thankyou
im new to coding and watched loads of videos but just some detailed instructions or a link would be great thank you |
07-18-2018, 08:52 AM | #2280 |
Rep 5
hey @[shawnsheridan] could you kindly send me the link to the E-Sys please.
Think what I might do is uninstall it all and then reinstall it, do you know of any issues with Windows 10 and E-Sys? |
07-18-2018, 08:56 AM | #2281 |
Rep 41,220
No issues. I run Win10 64-Bit, and it works fine. PM sent.
07-18-2018, 11:12 AM | #2283 | |
Rep 41,220
07-18-2018, 01:18 PM | #2284 | |
Rep 1,387
Video of it in action:
2015 435i - 401whp
07-19-2018, 11:40 AM | #2286 |
Rep 41,220
PM sent.
07-20-2018, 09:33 AM | #2287 |
Rep 44
No ideas for "SeatBeltReminder Driver OFF"?
in ACSM5-1B29, "3001 Gurtwarnung" it should be "Gurtwarnung_0_0_255". My stock coding it is set to "UNK_PARAM_2" "UNK_PARAM_5" ("Wert 4"). What is the target value? It is said to be different for different I-Steps? |
