10-22-2018, 05:10 PM | #23 | |
Rep 1,934
Eg. <1 "not ready" tests passes in MA vs. <N in another state
11-17-2018, 12:54 PM | #24 |
Rep 170
How about a catted down pipe? Does anyone in Mass have one that passed the state inspection? I'm looking to add one this summer with a flash tune but I'm hesitant about the inspection process. Further, I know a lot of shops are tentative to remove/install any equipment that alters emissions equipment. That could be another issue just finding an installer or shop to do the work.
I heard that Fabspeed's sport cat will pass but it's double the price of most other catted DP's. But maybe that is the price you have to pay to get a pass with Massachusetts emissions standards. |
11-27-2018, 04:13 PM | #25 |
Rep 13
not sure about the one imformation but i have anotber question if anyone mah be able to help.
i recently got a safety rejection due to my lamin x yellow film over my fog lights. has anyone else had this issue or is the inpsector just being a stickler? the law states "(d) Lighting Devices and Reflectors. All lighting devices and reflectors originally equipped on the vehicle at the time of manufacture shall be operable and operate as they were originally designed. Lenses must be intact, clean, unobstructed, and free from cracks. The use of adhesive tape to repair lenses is prohibited." i surely do not believe they can consider them non operable as they were originally designed could they? |
11-27-2018, 04:20 PM | #26 | |
Rep 239
11-29-2018, 08:38 PM | #27 |
Rep 13
so if I was to replace my burnt out fog light with yellow ones. this would pass? if there was no film or a clear film to just protect the lens. I just dont see how this is a safety issue by any means
12-02-2018, 11:17 AM | #28 |
Rep 10,473
And you also scam people out of money.
Birds of a feather.... https://f30.bimmerpost.com/forums/sh...9#post24058109 |
03-11-2019, 08:07 PM | #30 | |
Rep 43
03-17-2019, 11:11 AM | #31 |
Rep 3,223
Drives: 2018 BMW 440i GC
The plate frames thing pisses me off so much. First its BS. Second they took of my plates chance of scratching my car. I had an inspection done by a dealer though and they did not remove my plate frames so that may be my goto
03-17-2019, 04:53 PM | #32 |
Rep 170
Anyone in Mass with the Fabspeed catted down pipe pass state emissions?
2015 335xi Black/BLK, FBO BM3 Stage 2, AA FMIC, CTS Turbo CP, FabSpeed Sport Cat DP, MPPK airbox w/high-flow filter, 18" AG M310's black
03-17-2019, 07:10 PM | #33 |
Rep 239
Never was resolved, I'm not sure what to do as well, I'm probably going to get a catless downpipe, as I have my HD FMIC, chargepipe, and BM3 tune, just need the DP. I'll probably end up swapping DPs before each inspection unless some can shed some light or info to if we need to whether with a catless or catted.
03-18-2019, 10:35 AM | #34 |
Rep 1,934
Someone on here says they have passed NY inspection with MHD and catless. Should be the same with MA.
03-22-2019, 09:58 PM | #35 | |
Rep 43
That said, my own understanding is that as long as you meet the following requirements, you will pass even with a catless DP (unless you get a real stickler/PITA shop performing the inspection): 1.) No CEL's either showing on the dash or hidden (if blocked by an aftermarket tune - i.e. JB4 or otherwise) 2.) Successfully completed drive cycle (showing readiness for the required readings)- presumably with standard tune, or at the very least a tune that will not block certain readings for readiness I've read stories of people who have passed in MA with catless DP's using sparkplug non foulers. I have also read stories of people who are able to pass because they run the catted DP and are able to run these without an aftermarket tune due, and without throwing a CEL. Yet the catted DP's, they will go on to tell you, always end up eventually throwing CEL's as they wear out, meaning you've spent almost $1k more to be stuck in the same position as those with catless DP's afterall... It is always a risk, and it appears the laws keep getting more stringent around this stuff. If you're going with a catted DP, I strongly recommend knowing what the current drive cycle involves for 'readiness', and doing test runs to see whether you are able to complete this without drawing a CEL. Also suggest picking up the non-foulers that others have referenced and reviewed in this forum. |
08-04-2019, 08:33 AM | #37 |
Rep 190
I had mine inspected yesterday. Mind you mine is catted but I had absolutely no inspection issue getting a N.H state inspection. Plugged into obd port and I was on my way.
08-05-2019, 02:32 PM | #38 | |
Rep 1,934
What kind of catted DP? How many miles you had it on. Are you tuned? MHD? BM3? Or JB4? Ever thrown a CEL?
08-07-2019, 08:13 PM | #39 |
Rep 190
08-07-2019, 08:35 PM | #40 | |
Rep 1,934
08-07-2019, 08:56 PM | #41 |
Rep 190
08-07-2019, 09:01 PM | #42 | |
Rep 1,934
08-08-2019, 07:43 AM | #43 |
Rep 170
Congratulations! Great to know. Just need $1400 now... haha
08-08-2019, 11:54 AM | #44 |
Rep 190
I like it. Not too loud and it burbles here and there. I run it mostly in comfort and it sounds great. Sport of course turns it up a notch. I’m debating on resonator removal but the reported drone has me hesitating. Im wondering if I might be able to adapt the AWE mud pipe to the Remus. That might make it scream
