05-17-2018, 06:04 PM | #1 |
Rep 2
Drives: 2014 335i
Drivetrain Malfunction Warning
Just passing on the results of changing spark plugs at 58,000 miles after having a drivetrain malfunction when I occasionally went WOT. I was able to clear warning after restarting, was not able to capture CEL or other error code with Scwabben BMW reader. I have read that this might be symptomatic of a bad coil pack causing a cylinder misfire. Figured step one was change and inspect plugs, and see if problem persists. Problem still persisted, and I noticed slight brown mark on electrode whereas the rest were normal grey colored (original plugs). So I replaced the coil pack with a OEM BMW coil pack on the cylinder with the dis-colored plug and I have not been able to repeat the drivetrain malfunction. With a warm engine and a handful of launches and spirited driving today so far so good. Just wanted to share the results.
05-19-2018, 09:57 AM | #2 | |
Rep 1,953
Drives: 2013 328i xDrive
MARC20102.00 |
05-22-2018, 09:49 AM | #3 |
Rep 14,143
Drives: G82 M4C X-Drive
Drivetrain Malfunction Warning is a huge blanket warning that could be a multitude of things, but bad ignition coils is actually the most common culprit. Happened to my F80 just a few months ago.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-25-2018, 12:37 PM | #4 |
Rep 2
Drives: 2014 335i
Thanks for following up with your experiences with the drivetrain malfunction warning. It happened for the first time in a couple of weeks after in stop and go traffic. Probably 10 minutes of rolling 15-20 mph then it opened up so I mashed the pedal and got the warning. Restarted and haven't got it again so may be low fuel pressure at the time? Eventually would like to do a proper stage 2 set up with upgraded fuel pump and ecu flash tune. Right now just the turner tune with AA FMIC, Charge Pipe, exhaust and a dinan CF intake.
03-26-2021, 03:23 PM | #5 |
Rep 6
Drivetrain Malfunction: Wastegate Actuator
Just wanted everybody to know that if you have the SULEV warranty (many cars have this, i just found out) the wastegate actuator is covered. I have been getting a drive train malfunction intermittently and the car would go into limp mode. Indy shop quoted $1200, the dealer replaced the part under warranty, I paid $0. So if you have the "drivetrain malfunction - drive moderately" issue and it turns out to be the waste-gate actuator, this is covered till 150,000/15 yrs on SULEV cars. I hope this helps somebody! |
04-01-2021, 11:03 AM | #8 |
Rep 267
I've had this pop up a few times on my '14 335i M Sport 6MT right on start up. Usually I just turn it off, let it sit for a few minutes, start it back up and it doesn't come back. Another thing I noticed is that when it does it the car is usually sitting uneven in my yard or driveway.
01-31-2022, 11:44 AM | #9 |
Rep 2
Drivetrain!
Hi!
So, I have F30 (2015 3 series) two years ago my car got that message and upon sending it to agency they did a full check and recommended to replace many things including the injectors, spark plugs and etc. Things went fine for a while until the message reappeared after three months. They did the work, and in two days time the problem persisted and again the car spent two weeks at dealership. This continued to happen for the last two years, until two months ago I made a big issue as I have done all recommendations by agency and car was only maintained there, after keeping the car for few weeks they said it was good to go that time. Two days ago I was driving and again the message appeared and obviously the shaking and loss of power came. I am unsure if the BMW dealership is not able to deal with it, then who will be? I am frustrated and I am thinking of getting rid of the car. It is unbelievable and I am the first owner of the car, no body drives the car, and I am driving delicately and the car never had accidents to cause such failures. Anybody has such experience? Everytime the dealership starts a new story, oh this time it is a different part, however, I am sure they replaced the injectors twice and they were damaged, replaced spark plugs, another air part I do not know what it is, and this isn't solving it permanently. I also opted for filling the car with super petrol at no avail.... Any advise or recommendation, please? Thanks |
drivetrain malfucntion |
