European Auto Source
      12-03-2012, 08:05 AM   #1343
scottg61376
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Sorry, but with only 1 Post, I can't PM you. Either post your email, or wait until you have enough posts and send me a PM.
Thanks, scottgreenwell at msn dot com
      12-03-2012, 11:11 AM   #1344
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Email sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      12-03-2012, 11:57 AM   #1345
scottg61376
Email sent.
Thank you sir!
      12-03-2012, 11:18 PM   #1346
Yobyot
Yobyot's Avatar
30
Drives: MY12 F30 ZSL
Yes, I think in that instance, incompatible Werte Values were used.
There may be some way to tell, but again with normal FDL coding nothing is obvious, especially after the coding is removed and the module is returned to the original state. Now if you alter your VO Options, and / or change your Production Date and write it to the car, and do not reverse that, that will easily be discovered. If you flash the firmware on an ECU, which can't be reversed, that may or may not be noticed.
Hi. I just noticed that people were discussing this question I posted earlier.
The werte values I used were from the F30 cheat sheet.
As I originally posted, when I reload a CAFD that was altered, the UNKNOWN and INVALID settings are displayed.
Oddly, the coding changes work perfectly -- that is, the intended modifications are in effect.
To eliminate these errors, I tested by setting values back to the defaults, then reloaded them. There were no errors with defaults. Only the values in the cheat sheet, once entered, saved and coded generated errors on reload.
I haven't coded in a while but I've noticed no ill effects.
I am waiting for BMW to come up with a fix for poor/error prone voice recognition for music search with a USB-connected iPhone. I suspect that would mean a complete reprogramming. I will be curious to see if it wipes my coding changes and if the CAFD files that were marked invalid are also reset as a result of a complete reprogramming.
Until then, I'd sure like to hear what others are experiencing when the re-look at coded files.
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
      12-04-2012, 02:31 AM   #1347
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
I coded alot, both werte values and just changes from aktiv-nicht aktiv etc, never had any error like you described.
Last week the car was in for some issue and they did a software update, I had no problem coding the stuff again. (courtesy of Shawn who was quick to send me the new 48 version of files )
Mind you i had loaded all the default files before I took the car to the dealer. I don't want them to know about me coding at all.
      12-04-2012, 03:25 PM   #1348
Tekener
Tekener's Avatar
Drives: F30 335xi
Hi guys,
I'm new here and I'm in the lucky position that most coding issues won't arrise for me: I know my vendor for more than 10 years already and he's pretty fine to code my F30 335ix anything I want, so no software/Laptop/cable messing I could do wrong
However, is there a newer Cheat Sheet for the F30 than the one on the first page from mid June? Before I start bother you about what is possible I would like to have a look at the latest table you have.
Anyplace I can download the Sheet?
Thanks a lot!
      12-04-2012, 06:32 PM   #1349
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Originally Posted by Tekener
Hi guys,
Thanks a lot!
I uploaded a new list today it's one thread down from this one
      12-05-2012, 12:37 AM   #1350
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Email sent.
Hey Shawn, could you please email me the links to the updated files as well.. Thanks...
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      12-05-2012, 01:07 AM   #1351
shawnsheridan
PM sent.
      12-05-2012, 06:30 AM   #1352
TonyS
Drives: F30 335i
I see that in the F10 cheat sheet there are a couple of settings for importing/exporting POIs (NAVI_MYPOI_IMPORT & NAVI_MYPOI_EXPORT).
Has anyone had any luck with these on an F30? If so, any clues as to the format needed? I'd try this myself but my laptop died a couple of days ago and I've got to get it repaired.
      12-05-2012, 08:51 AM   #1353
shawnsheridan
Thanks to JEG23, we have Trip Import working using Google
Google Maps is a better and more efficient tool to generate routes than the BMW Navigation System. You have the flexibility to change routes as you wish and select specific roads from point A to point B. The attached manual (and program) describes how you can generate trip files that can be imported into your BMW Nav system. This is possible thanks to the great programing work of our fellow fester, Aussie40d, from the E70 forum. Enjoy.
JEG23
https://rapidshare.com/#!download|35...v.pdf|1505|0|0
https://rapidshare.com/#!download|67...3.xlsm|166|0|0
However, no luck so far on POI import, although it continues to be studied.
      12-05-2012, 09:10 AM   #1354
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
JEG23
Shawn, I only glanced at JEG23s info, but am I correct to assume this will only work on cars with the import trip already, or will it work on our "budget cars" with the cheap navi and no default import from usb/google
      12-05-2012, 09:13 AM   #1355
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
nm, just read the pdf "The uploading will only work from usb in the glove compartment"\
us cheapos dont have that one.
      12-05-2012, 09:15 AM   #1356
shawnsheridan
What is cheap Navi? I thought you either had 609 Navigation or no Navigation? There is something in between?
In any event, in the U.S. anyway, Trip Import is not enabled by default, and has to be coded on with:
HU_CIC / 3000 / NAVI_TRIP_IMPORT = aktiv
So, maybe you can code this on to.
      12-05-2012, 09:16 AM   #1357
shawnsheridan
Yep, you do need the Glovebox USB Port, as it connects straight to the Head Unit's hard drive where the files must be copied to.
      12-05-2012, 09:36 AM   #1358
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
oh well, at least i have a slider for the ambient lights
I have found 3 values for that btw (they are on the sheet)
Did you get any more time to check if it works for you?
I'll have time to search more in the weekend
      12-05-2012, 09:38 AM   #1359
shawnsheridan
Sorry, but no, I have not looked yet. Too busy working on E-Sys ECU Firmware Flashing project and some other things...
      12-05-2012, 09:58 AM   #1360
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
sounds dangerously interesting. care to elaborate over pm?
PS here in yurop we have a cheaper version of the navi, called navigation business S606A. I thought that was available in yoe es as well.
      12-05-2012, 10:06 AM   #1361
shawnsheridan
It isn't a secret that I am keeping. You can use E-Sys to flash individual ECU Firmware, same as you can with WinKFP for Exx chassis. And while it is known that it can be done, the E-Sys process itself is not understood nor documented, so we are defining it and developing a DIY Guide.
      12-05-2012, 01:42 PM   #1362
Puri1
Puri1's Avatar
Sorry guys quick question.
I downloaded the psz files that Shawn sent me (by the way Shawn THANKS) but I'm confused as to what to do now. Should I just replace all the older files (drag and drop) or something different.
      12-05-2012, 01:59 PM   #1363
shawnsheridan
I don't remember what you got, but:
If you got only the 45 new CAFD's from 48.1, extract them and copy them to folder C:\ESysData\psdzdata\swe\cafd.
If you got the full 48.1 PSdZData, DELETE in its entirety your existing PSdZData folder located under C:\ESysData\ (i.e. C:\ESysData\psdzdata) and REPLACE it with the new 48.1 PSdZData folder. DO NOT copy the new PSdZData folder on top of the old one.
      12-05-2012, 02:49 PM   #1364
Puri1
Puri1's Avatar
Got it.. Thanks Shawn !!
