09-27-2017, 03:34 AM | #199 | |
No 55mph
1623
Rep 8,479
With that being said, I have had absolutely no problems with these wheels. I have the 19's for F32 MSport They were all checked for trueness on HRFB machine prior to mounting tires & were fine. Did not require excessive amount of weights to balance. Michelin PSS +3 tire size I chose put the tires flush with fenders without using any spacers with wheel supplied F32 offset. No wobble, no shimmy, no mfg. defects, no issues with mounting - perfect. Only item to note is that the OEM BMW wheel roundels do NOT fit these wheels. However, they are supplied with gloss black centers - I use black/silver CF roundels on my car anyway - I just simply used the JBSpeed wheel emblems & applied them to the OEMConcepts supplied black centers & all looks good Very happy I chose these wheels - I get compliments on them all the time both from spectators and dealer
09-30-2017, 06:51 PM | #201 |
Rep 26
This question may be silly but have dealers ever used rims as an excuse to refuse what would be a warrantied repair for something such as shocks, etc?
10-02-2017, 02:50 PM | #202 |
Rep 841
02-12-2018, 11:28 AM | #205 |
Rep 177
You guys should try other local vendors. That's where I got my set from. They actually may be easier to come across than you'd think. Even ebay has them.
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
02-16-2018, 11:43 AM | #206 |
Rep 5
Hey guys,
OEMConcepts looks to have gone completely dark, so I took a look around and found what look to be the same rims being offered here out of Missassauga: http://www.zracing.ca/wheels/DAI-All...-Machined-Face My only question is, I'm planning on getting the tires as part of the package, and per my doorwell the recommended tire fitment for 19's is F:225/35/19 and R:255/30/19. My car is a 2008 335i w/Sport Suspension - will I have any issues if I get a tire fitment of F:235/35/19 and R:265/30/19? Will they not jive with the car sensors, etc.? |
02-18-2018, 07:36 AM | #207 |
Rep 495
You will not have any issue with the 235-265 tire and it would be the best setup you could put on.
Bmw 435M 2014 Convertible SOLD!
Bmw 340i X drive 2018 New orange sunset, Manual transmission, M performance I & II, M performance front lip, side extension rear diffuser, tinted windows. : SOLD Back in old N55 love! Bmw 335 EBII M performance edition : ER Downpipes, VRSF Chargepipe, VRSF HD 6.5 Intercooler, BM3 Stage 2 93 octane, MPPSK, H&R Spring |
03-17-2018, 09:59 AM | #208 |
Rep 26
Hi guys, I have an 2014 F32 428i and I was just about to pull the trigger on 19 inch 437m rims and tires with a staggered setup which was listed as 8.5 inch fronts with 35 offset and 9.5 inch rears with 40 offset. Seller told me he made a mistake and that both front and rears are 35 offset. Tires are gonna be 235 40 19 and 265 35 19.
Someone earlier quoted the Oem Concept guy (who disappeared) as saying that the rear 40 offset rim is for the 3 series and the rear 35 offset rim is for the 4 series. Does anyone with a 4 series have a 9.5 in rear rim with a 35 offset? If so, any pictures? Do they poke too much? Thanks |
03-18-2018, 07:01 PM | #209 | |
Rep 100
435i xdrive. Went with 235/40r19 and 265/35r19 to go along with my eibach .8 f .4 r. With the increased sidewall, it should sit pretty tight with the fender hopefully. Can't stand that wheel gap. Last edited by ez2c; 03-18-2018 at 10:54 PM.. |
03-28-2018, 07:10 PM | #211 |
Rep 1,288
Drives: 2014 435iX, FBO
PM them OEMCONCEPT. They are still there.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
03-30-2018, 11:03 AM | #212 |
Rep 4
04-27-2018, 08:58 AM | #213 |
Rep 296
Anyone know if the reps have the same concaveness front and rears as the real 437Ms? I can't tell by looking at the pics.
D Unit
Bay Area, CA |
04-30-2018, 08:33 AM | #215 |
Rep 177
No they do not. I asked the same question about that and unfortunately they don't. Still looks good tho
05-11-2018, 07:54 PM | #216 | |
Rep 296
It was mentioned the OEM center caps don't fit too well so people are just purchasing BMW "stickers" on Ebay on putting them over the replica caps. Can someone post the diameter of the center caps? I want to buy mine before my wheels arrive.
D Unit
Bay Area, CA |
05-18-2018, 02:55 PM | #217 | |
Rep 1,071
There's a lot of variables to this - mostly don't want to compromise on quality but I also don't want to use stickers... or have any rubbing on my 435i. So yea... still thinking about it. |
05-19-2018, 07:23 PM | #218 |
Rep 3,045
Got my reps from OEMconcept in 4 days, they fit beautifully and the service was top notch.
Currently mounted are my original 225's in front and 255's in the rear. I definitely think I will go with 235/265 next. Both OEM center caps and M badges fit right in flawlessly. @OEMconcept
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= Last edited by 7iM3less; 03-24-2020 at 07:33 PM.. |
d_a_m92.50 |
05-20-2018, 11:51 AM | #219 | |
Rep 177
7iM3less2610.00 |
