12-16-2011, 01:14 PM | #2179 |
Free Thinker
17306
Rep 7,457
The biggest gotcha with that is blowing out highlights beyond recoverability. Make sure your histogram is to the right, but not pressed up against the right side.
12-16-2011, 01:19 PM | #2180 | |
Rep 7,389
I also turn on my blinkies in post, since you can blow out parts of a perfectly exposed image by raising Contrast too much, or raising levels or any number of things. Dave |
12-16-2011, 01:31 PM | #2181 |
Free Thinker
17306
Rep 7,457
I've been making good use of the Recovery slider in ACR. Works wonders for wiping out blinkies and recovering whatever detail may be there.
12-16-2011, 09:19 PM | #2183 |
183
Rep 2,391
yes, and flattening out the highlights - love it.
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
12-16-2011, 09:25 PM | #2184 |
Rep 5,114
12-16-2011, 09:26 PM | #2185 |
183
Rep 2,391
ha. unless you're aiming for shades of middle grey.
12-16-2011, 09:43 PM | #2186 |
Free Thinker
17306
Rep 7,457
I've noticed that. But so far only on clouds where the gray isn't a big deal. If the detail is gone for good, you get the gray spots.
12-16-2011, 09:46 PM | #2187 | |
Rep 5,114
that's just me personally though. I try to keep that rule in for fill light too. I don't want to have to clean up more noise, or get banding or any of that (which doesn't seem to be as much of a problem in RAW.) |
12-16-2011, 10:49 PM | #2188 |
183
Rep 2,391
lately, i've been using it as a further push south for the highlight end of the curve, after making a really funky looking custom curve. it makes for a really soft gradation to the highlight.
like here: i probably set recovery to about 50% - nothing was blown out at all (obviously) when the exposure was 0%, it just has a nice feel on my custom curve. do you think it looks bad? and the in-focus blinds on the edge of the frame really bother me. should crop it. blah.
12-16-2011, 10:51 PM | #2189 |
Rep 5,114
I would crop the in focus part, it's creating a second focal point to your picture, and the picture is fantastic as is, but would be better without those in focus parts.
perhaps turn it into a profile pic instead of square while getting rid of lines? |
12-16-2011, 10:54 PM | #2190 |
183
Rep 2,391
surely you know my thoughts on vertical/portrait orientation.
12-16-2011, 10:55 PM | #2191 |
Rep 5,114
yes, but seems like the only solution, unless there's more of this image which was previously cropped?
or was this image framed as is? I made the assumption that you're so good that it was basically framed as is with the exception of being a square crop |
12-16-2011, 11:04 PM | #2192 |
Free Thinker
17306
Rep 7,457
Hmm, I agree the in-focus part of the blinds should go, but then you're messing with the geometry of the image by quite a bit. I think if the fine detail in the blinds was gone, you could leave them in and not have to crop. Maybe create a new layer and surface blur it so the detail in the blinds in muted some, then layer mask that area only?
12-16-2011, 11:06 PM | #2193 |
Rep 5,114
did you take an alternate version of this picture with everything in focus? (i assume no) because the blinds would have worked quite well as leading lines.
12-16-2011, 11:09 PM | #2194 |
Free Thinker
17306
Rep 7,457
Like so, maybe?
12-16-2011, 11:12 PM | #2196 |
Free Thinker
17306
Rep 7,457
No. The fine detail in the blinds is gone. I don't think they grab the eye as much now.
12-16-2011, 11:17 PM | #2198 |
Free Thinker
17306
Rep 7,457
Exactly. You really can't blur the blinds there completely because the plane of focus will be uneven and your eye will pick up on that.
12-16-2011, 11:22 PM | #2199 |
183
Rep 2,391
meh.
12-16-2011, 11:32 PM | #2200 |
Free Thinker
17306
Rep 7,457
EDIT: Never mind. I like your new version better, rodi.
