02-29-2024, 03:01 AM | #2466 | |
Rep 294
02-29-2024, 08:08 AM | #2469 |
Rep 39
02-29-2024, 08:17 AM | #2470 | |
Rep 39
02-29-2024, 08:23 AM | #2471 |
Rep 2,369
Drives: E63 645Ci
02-29-2024, 10:24 AM | #2473 | |
Rep 294
kentodessa6.00 |
02-29-2024, 11:16 AM | #2475 |
Rep 223
About factory_config.xml:
Before you upload any NEW factory_config.xml files to the OEM folder (e.g. of your SDCARD) and import them, using the 'Factory Settings' import button, you should first backup your current factory_config.xml file and the FACTORY_SETTINGS files from this folder: /mnt/vendor/persist/OEM/ You can do this by adb pull (adb root & remount first) or installing an FTP server on your HU (e.g. 'sftp server s0 v1' or 'Solid Explorer'). (if FACTORY_SETTINGS cannot be read use adb shell chmod 774 /mnt/vendor/persist/OEM/FACTORY_SETTINGS) FACTORY_SETTINGS (JSON format) is important, because it shows you which options have been set to which value. You can use these properties&values specified in here and then open factory_config.xml you downloaded and find these properties and modify their values to reflect FACTORY_SETTINGS. You will end up with a factory_config.xml file which is fully populated with all your personal settings for your device. Now, whenever you factory reset your device, you can place this new factory_config.xml in your OEM folder and do the import. That's all you need. You do not need to download any other file from anywhere, unless your factory settings do not cover your car in some way, somehow. PS. as stated above, not all options are specified in the factory_config.xml file. On the contrary, all your selected options are specified in FACTORY_SETTINGS. e.g. I have added the 3 options below to the end of my new factory_config.xml, exactly because they were not specified in my default factory_config.xml from the factory. If I do not specify them here, I am going to have to manually go to my 'Factory Settings' interface and choose them by hand. <!-- M600 (SD662) MIC gain range: 0~20 --> <mic_gain_m600>20</mic_gain_m600> <!-- Original car display - see list of CarDisplayParam e.g. for [11]CCC_E60, use 10 below --> <CarVideoDisplayStyle>10</CarVideoDisplayStyle> <!-- Front Left Speaker "0": Enable "1": Disable --> <Front_left>0</Front_left> <!-- Unknown Setting --> <MicControl>1</MicControl> </factory> </ConfigInfo> RedErik do you know what MicControl setting is doing? After my factory reset, I found this set to 1 in FACTORY_SETTINGS. But, I cannot find any way to alter this value from the 'Factory Settings' interface. So, if I do not set the value to 1 above, it defaults to 0. Last edited by conandrum; 02-29-2024 at 01:38 PM.. |
Steljo1.50 kentodessa6.00 |
02-29-2024, 11:36 AM | #2476 |
Rep 294
May be this - Vehicle - MIC external built-in toggle switch
02-29-2024, 02:19 PM | #2477 | |
Rep 12
Sucsses :)
Found proper zxw_factory_config.xml for my HU from here In this factory config have a section - <SupportUIListNotTestedYet> just cut from there and paste in section - <SupportUIList>. Then import factory config to navigation and restart. Now i see all UI Configuration. Upload not modified xml and if you someone want tested working (to my GT6) factory_config no problem i will upload. For - zxw_factory_config.xml.txt just remove .txt Last edited by Steljo; 02-29-2024 at 02:34 PM.. |
Shamanix138.00 |
02-29-2024, 04:10 PM | #2478 |
Rep 223
yes that's the one.
So I modified my file to include: <!-- MIC external built-in toggle switch "0":External "1":Internal --> <MicControl>1</MicControl> Here is something funny for you guys Tonight, when I started my HU, the 'Phone is starting' message was interrupted, just before the HD icon appeared in the top corner, the KSW video player opened in the foreground and started automatically playing videos!!! (same thing after reboot). I decided to load my original factory_config.xml and rebooted. This time, the 'Phone is starting' message was interrupted, just before the HD icon appeared in the top corner, and the music player opened in the foreground and started playing music! very weird. Usually the music player can start playing music after the launcher is fully loaded! (same thing after reboot). So I imported my personalised factory_config.xml back again and rebooted. This time, everything was back to normal. very weird. |
02-29-2024, 04:57 PM | #2479 |
Rep 294
02-29-2024, 07:20 PM | #2481 |
Rep 223
Have any of you guys ever tried another Launcher and recommend it as a replacement for the stock launcher?
I know Shamanix is using FlowUX. Anybody else have a recommendation? Also, have you guys tried 'Headunit Reloaded' and do you recommend it? I suppose this would be like a replacement for ZLINK? Any other killer recommendations? let me know below! |
02-29-2024, 10:42 PM | #2482 | |
Rep 294
<client>ALS_6208</client> Were you not mistaken? #2442 Here you could download without dancing with a tambourine. Stock launchers are available for simultaneous use with third-party launchers at any time. Last edited by Shamanix; 02-29-2024 at 10:48 PM.. |
03-01-2024, 03:43 AM | #2483 | ||
Rep 223
e.g. <!-- Integrated BT Module Switch 0:disabled 1:enabled--> <Android_Bt_Switch>0</Android_Bt_Switch> <!-- Front Left Speaker "0":Enable "1": Disable --> <Front_left>0</Front_left> <!-- MIC external built-in toggle switch "0":External "1":Internal --> <MicControl>1</MicControl> <!-- Reverse Camera time "0-0":disabled "1-1":1 sec up to "1-10" for 10 seconds --> <!-- do NOT change to "0" it will block Factory settings --> <Reverse_time>0-0</Reverse_time> <!-- 360 boot up camera (Vehicle Settings) Selection of camera 0:No camera use 1:Retrofit camera 2:Original car camera --> <BootUpCamera>0</BootUpCamera> <!-- Global Weather APP 0: Hide 1: Show --> <globalweather_app>1</globalweather_app> See my personalized file attached. |
03-01-2024, 08:33 AM | #2484 |
Rep 223
Hey guys,
Q1. Have you ever noticed that your app icons get shufffled around every so often? (Does it have anything to do with KSW-Toolkit service being started?) ANSWER: ??? Q2. do any of you know what this KEY icon means at the top right hand corner? I haven't seen it before. ANSWER: it is the VPN icon. Last edited by conandrum; 03-01-2024 at 09:14 AM.. |
03-01-2024, 09:49 AM | #2485 | |
Rep 294
ksw toolkit does not change the position of icons, time-tested |
03-02-2024, 07:53 AM | #2486 |
Rep 31
Hi guys,
I've been reding your discussion about DACs and bluetooth call issues with great interest as I had to tackle this issue myself over a year ago. I own 2 different DACs a Fiio K3 and more recently a Shanling UA4. Both deliver outstanding audio/HiRes with the right source (lossess flac or DSD via Poweramp configured correctly). To get working bluetooth calls I used a splitter on the screen harness to connect the DAC to the my CIC and also coded the CIC to use CIC AUX not Combox AUX and disabling the USB in the armrest. The outcome was much louder and clearer sound from the 662 screen via DAC for music and NAV and when a call came through because of the splitter it still routed analogue audio (AUX) to the CIC albeit not via the DAC. A caveat is that I have never used Carplay or Android Auto with the 662 screen, why bother with cut down apps when I can use what I need in split screen without compromises or flakey connections? Anyway, fast forward to a few months ago, because my car has upgraded base audio system (coded to Hifi, 1x 5channel amp, 1x mono amp, various speaker upgrades and boot subwoofer) I decided to get a Helix DSP with a HiRes USB HEC module to remove most of the added rubbish out of the equasion. My final solution was to send a speaker high level signal from the CIC to the DSP which then feeds my amps. This meant I could remove the splitter and allow the screen to function as intended sending bluetooth calls, parking sensor beeps and warning alarms to the CIC AUX and in parallel I am sending via a long USB cable all the music, nav etc... to the Helix USB HEC. One compromise is that I have to use a separate volume controller (Helix Commander) to control the volume of sound globally. But since I am not intrested in Carplay and AA this setup gives me way more control over music and quality rather than be at the mercy of the android screens developers waiting for solutions that may never materialise. To confirm, I've never been able to route phone audio via the DAC, and ultimately my time is worth way more than the money spent on the Helix DSP. The positive side to all of this is that I have the best possible audio quality by sending the audio (apart from bluetooth calls) from the 662 in digital format to the Helix DSP without adding another digital to analogue step in the path to my two main amps. I hope this all makes sense, it was a very long journey for me. |
conandrum40.00 |
