10-13-2018, 05:42 AM | #287 |
Rep 565
Just a lot of patience, it took me half an hour to do it the first time. Just be careful not to break it. Maybe use a small mirror so you can see what you are doing.
10-15-2018, 12:51 AM | #288 | |
Rep 123
Question regarding screen mirroring: Does it switch only the video input or both video and audio? Reason is because im usually connected via Bluetooth and stream spotify. I want to be able to keep BT streaming the music but just mirror the display ( Waze, mostly ) |
10-15-2018, 09:33 AM | #289 | |
Rep 565
10-17-2018, 04:04 AM | #290 |
Rep 277
Drives: 2018 230i MSport
I've combed through this post so many times and I find I'm left with more questions than answers it seems. I have a 2018 230i LCI that I would like to upgrade to the 8.8 display. Some questions I am hoping to find answers to
-Will the touch function work on the upgrade display? -If I upgrade the controller will the touch function work on that as well? -Will I have the ability to install Apple car play with the upgrade? -Is there a way to connect a GPS antenna and have a fully functioning NAV system if I replaced the controller and screen? -Is it more cost effective to just get the bimmertech screen and controller and use mirroring to use a nav app off my phone? My goal is to have the larger screen and use nav apps off my iPhone while it's in the wireless charging cradle. Thanks in advance! |
10-17-2018, 05:50 AM | #291 | |
Rep 565
3) OEM CarPlay requires professional nav, so it only works with NBT EVO (the head unit that comes with the larger screen and supports touch) 4) You can probably enable business nav (not pro nav) in your head unit by connecting an GPS antenna and doing some coding (requires FDL codes). If it can be done, it definately won't be easy. You need to ask in the coding forums or pay someone to do it for you. 5) It is definately cheaper than replacing the head unit, and less likely to void your warranty. |
10-17-2018, 11:15 AM | #292 | ||
Rep 277
10-17-2018, 06:29 PM | #293 | |
Rep 565
Be sure to check this post for part numbers for the 3-series. Check http://www.realoem.com/ for your 2-series. You'll also need an ENET adapter (eBay) and eSys software (coding forums). Good luck! |
10-17-2018, 09:22 PM | #294 | |
Rep 123
Just replace the display, everything you listed is way more hassle and $$$$ that is worth. I am waiting for Bimmertech to release to update for their Carplay MMI that is supposedly gonna support full screen - that is native Carplay ( via Apple Cable, none of the hack-y screen mirroring with Wifi and / or Apple TV stuff they also have ). Too bad there is no Android Auto support. |
10-18-2018, 01:48 AM | #295 | |
Rep 277
Can I do the coding with the OBDII adapter and bimmercode? I know I have seen a majority of the entries listed needing to be coded under the advanced settings while making other changes. |
10-18-2018, 06:29 AM | #296 |
Rep 565
A couple of folks have done it, so yes, you can try it and if things go wrong, you'll need to use eSys.
11-26-2018, 12:21 AM | #297 |
Rep 4
Issue upgrading to 8.8
Sorry to keep this thread alive and kicking, but i recently purchased the 8.8", with the product no. for pre LCI screen, as i have pre LCI F31, with 6.5" screen, and HU_ENTRYNAV. I had the screen installed and coded by a mechanic here in Adelaide, South Australia, followed the codes on this page and found that the resolution altered, but the screen itself would only display a reduced amount. Refer photos attached. He thinks the screen is faulty, but wondered if anyone had encountered this same issue, if maybe there was another code that needed adjusting, or if in fact it is a faulty screen. The spare parts place that i bought the screen off deny it is faulty, and are now saying its not compatible with my vehicle, after i provided them my VIN.
Appreciate any comments or suggestions, i thought this was going to be failsafe as i ticked all the boxes. Even avoided coding myself, thought id find a professional! |
11-26-2018, 07:47 AM | #298 |
Rep 565
Wow, that's strange! Haven't heard of this problem before... IMHO the screen is faulty and I suggest you try connect it to a car that has pro nav to prove it.
Have you double-checked that you have HU_ENTRYNAV head unit (seen in eSys as module) and that you coded the "display_variante" setting to "breites_display"? EDIT: Here are the exact options you need to code: EXBOX > DISPLAY_VARIANTE -> "breites_display" EXBOX > DISPLAY_SIZE_RESOLUTION > "8.8_1280x480" (the second option should not be necessary - my car had "10.25_1280x480" as the default set for a 6.5" screen and it worked) Last edited by MarkoSK; 11-26-2018 at 07:56 AM.. |
11-26-2018, 07:48 AM | #299 |
Rep 565
11-26-2018, 04:14 PM | #300 | |
Rep 4
The coding software used was not esys, it was another software that my mechanic had which i assumed was far more advanced, he hadnt used esys before. Could this have been the issue? That was my next step was to try find another F30 with the larger screen installed to do a straight swap and see what happened. |
11-26-2018, 04:29 PM | #301 | |
Rep 565
I think the software wasn't an issue - if the values hadn't been coded correctly, the screen would be either black or would show "NO VIDEO". It won't hurt to double-check, though . Good luck! |
11-26-2018, 09:11 PM | #302 |
Rep 4
UPDATE: I remembered that when i was able to toggle split screen, i could see that the point in which the display ceased, was actually the line of the split screen....is there potential for another code that would be impacting on the visibility of this side of the screen? or would a split screen setting be preventing that side from displaying?
11-27-2018, 07:56 AM | #303 | |
Rep 565
Plus there's a difference between a black screen and a completely blank screen - the display emits a little light when displaying black, so take a good look at the right part of the screen when turned on and when the car is off and locked. If there's no difference, then you have a dead part of the screen (hardware issue). |
11-27-2018, 06:06 PM | #304 | |
Rep 4
11-27-2018, 06:57 PM | #305 | |
Rep 565
I don't know what he meant by "Screen_Variante (split screen)" and honestly didn't try to find out since he had solved the problem . I guess he meant DISPLAY_VARIANTE, because AFAIK there's no SCREEN_VARIANTE setting in HU_ENTRYNAV. |
12-05-2018, 08:57 AM | #307 |
Rep 351
Thought I read somewhere on the forum or an answer that the 6.5 entrynav system does not show anything in 3D. Wasn’t too disappointed about it.
Fast forward several weeks later and I’m driving through the city.. Can’t see how this could be different to any pro nav 3D, but there’s some sort of 3D rendering going on. Just a heads up.. |
MarkoSK123.00 |
12-05-2018, 10:07 AM | #308 | |
Rep 777
