05-03-2013, 03:11 PM | #3477 |
Rep 46
Checking for fault codes
Quick question... A few months back I was able to code a few things... mirror folding, side markers, etc... not a whole lot. Recently I experienced a loss of power while driving home. I found this threat that mentions a possible problem for my case http://www.f30post.com/forums/showth...7#post13929107
Is there any way for me to check if there's any engine or electrical fault code logs using E-Sys or any other way? Any help will be much appreciated.
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
05-03-2013, 04:03 PM | #3478 |
Rep 41,178
PM sent.
05-03-2013, 04:06 PM | #3479 | |
Rep 41,178
1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Hopefully, Problem Solved. Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
05-03-2013, 06:52 PM | #3480 | |
Rep 1,044
I might turn it off next time I code the car because there's nothing worse than having the ability to set options for hardware that just doesn't exist in your car.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
05-03-2013, 07:02 PM | #3481 |
Rep 1,044
I've been a little too loosey-goosey about my coding and now the payment is coming due.
I've been very happily coding my car with Esys 3.18.3 and PSdZData 48.2 -- the car is a 2012 F30. I've been coding along without keeping track of what I've set. Now, the car is coming up on its first service interval and I am sure the dealer will update it so that I have to upgrade to a later Esys and PSdZData (and I will get my own personal "PM sent" reply from shawnsheridan when I ask for the new files and contact info for the seller of the Esys token). My question is: can anyone suggest a technique I might try to save the changes I've made, as compared to the base files, so that I can reconstruct what I did when I start with a new, updated level of software in the car? (I promise to keep a personal cheat sheet next time, which is what I should've done from the beginning. )
MY18 X3 30i:
05-03-2013, 11:53 PM | #3482 | |
Rep 1,892
One thing you definitely don't want to do is to take one of your existing .ncd files and apply it to a newly updated ECU. There is a very high likelihood that the FDL layout has changed and pushing an old .ncd file will change settings you don't want to change and/or completely mess up your ECU. I've seen that there is a CAFD comparison utility floating around on the other forums, but it's of no practical use to me because it requires decrypted CAFD files and I have not seen any tool out there to do that. |
05-04-2013, 12:11 AM | #3483 |
Rep 1,130
Drives: '16 340i AW MSport
Frogman/Shawn, trying to code FEMBODY and i'm getting this: File for "cafd_00000794-004_228_010" not found!
Either of you can link me to this CAFD file? Last edited by kromix; 05-04-2013 at 12:23 AM.. |
05-04-2013, 12:29 AM | #3484 |
Rep 1,892
05-04-2013, 12:36 AM | #3485 |
Rep 1,130
05-04-2013, 12:48 AM | #3486 |
Rep 1,892
05-04-2013, 04:08 AM | #3487 | ||
Rep 41,178
49.3 CAFD's though cannot be added to 49.1. Full 49.3 is needed. PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 05-04-2013 at 07:03 AM.. |
05-04-2013, 06:21 AM | #3488 |
Rep 1,130
Thanks guys!!!! I can't state enough how badass u guys are. Can I Send you a pizza or something??? lol
05-04-2013, 07:04 AM | #3489 |
Rep 41,178
Make mine a Meatlover's.
05-04-2013, 07:15 AM | #3490 |
Rep 1,130
lol....... Hey how come I don't have an ICMQL ECU? Wanted to code Sports+ Mode, but don't see that ECU? Could it be under something else?? Last edited by kromix; 05-04-2013 at 07:27 AM.. |
05-04-2013, 07:29 AM | #3491 |
Rep 41,178
It should be ICM something.
05-04-2013, 09:53 AM | #3492 |
Rep 3
Built Feb 2013
Hi guys,
she's here... built feb/2013 in Germany. I'm kind of lost which data file and E-Sys version should I use... also, if any token will be necessary. I already have the cable... Would someone (Shawn??) please please PM me with the links for download?... I'll be forever grateful!! Thanks a lot!!!! San |
05-04-2013, 12:55 PM | #3493 |
Rep 1,130
SPORT +
Yes ICMQL 3000 IcmKod_B_Sportlenkung nicht_verbaut verbaut Enables SPORT+ mode (You'll get an error about RPA after coding. Restart car and it goes away) Additional coding required to get the FDS menu complete will come in a later update. What does this part mean? Is it worth coding this?? |
05-04-2013, 02:13 PM | #3494 | |
Rep 41,178
05-04-2013, 03:45 PM | #3495 |
Rep 169
Hey guys! I got it working and coded some stuff today (All thanks to Shawnsheridan, you rock!)
I just wanted to share this piece of information incase if someone is having a hard time establishing an ethernet connection. I was using my work laptop and the ethernet controller was set to static IP. I tried & tried for an hour and it I couldn't connect to the car. Go to Control Panel > Networks and Internet > Network Connections. Right click on your ethernet controller & click Properties. Make sure "Obtain IP Address Automatically" is selected. |
05-04-2013, 04:17 PM | #3496 | |
Rep 1,892
HU_CIC / 3000 / Macro_fds change from popup_only to popup_and_config |
05-04-2013, 05:06 PM | #3497 |
Rep 1,130
05-04-2013, 06:59 PM | #3498 |
Rep 1,130
Figured the above out, it enables Sport+ as an option.
Hey side question, is it just me or is it so hard to remove the coding cable from the car by hand I have to use pliers to rip it out with force??? is there an easy disconnect method I'm missing?? |
