10-13-2020, 06:50 PM | #353 |
Rep 6
Does this generator work for NBT2 head unit? If yes, what parameters do I use to get the FSC related file from the car. I can't seem to extract it with the normal values "1B, DE". If not as I heard from others, how do I go about updating the EVO map on my NBT2 HU? btw, I already tied and the lifetime code generated using the VIN didn't work. Thanks,
10-17-2020, 08:21 AM | #354 |
Rep 2
Hi
i tried to install Europe Evo 2020-02 on my EVO ID4. But the generated code doesn't work.. Can you help me please? If possible better for the 2020-03 map. This is my f0-file |
10-17-2020, 08:27 AM | #355 |
Rep 12
10-22-2020, 03:03 PM | #360 |
Rep 12
11-04-2020, 12:21 PM | #367 |
Rep 26
I also wasn't able to generate this code using his file.
@Jagaer I need to say that you did amazing job creating this application. I was wondering if you could tell me how to get all required maps properties like: - SWID_FscShort - HEX number from some file map? SQLite DB file? - SgbmId - sop - version - NextNo I'm asking about this because I'd like to add a new map: "Road Map EUROPE EAST Next 2021-1" to the Lookup.xml file. Last edited by geron1; 11-04-2020 at 12:33 PM.. |
11-04-2020, 05:37 PM | #368 |
Rep 102
@Jagaer
I need to say that you did amazing job creating this application. I was wondering if you could tell me how to get all required maps properties like: - SWID_FscShort - HEX number from some file map? SQLite DB file? - SgbmId - sop - version - NextNo I'm asking about this because I'd like to add a new map: "Road Map EUROPE EAST Next 2021-1" to the Lookup.xml file.[/QUOTE] Hi again Jagaer I have downloaded the 2021-1 Europe West map for my car. (2014 NBT running NEXT maps) Is there anyway your generator could be updated to produce the FSC code for that map? Cheers |
11-05-2020, 04:29 PM | #369 |
Rep 1
Hi Jagaer,
my friend own X5 (2016) and i also downloaded 2021-1 West Europe NEXT map for him. Is it any way how to generate the FSC code? Thank you for an answer |
11-09-2020, 05:12 AM | #372 |
Rep 26
I can confirm that I was able to install Road Map Europe EAST 2021-1 by adding this entry manually based on the WEST version.
I'm really impressed It worked flawless. Thank you @Jagaer! |
