BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Audiotec Match UP 10DSP Amp as PnP Upgrade Solution For HK Equipped Cars?
      03-26-2024, 11:31 PM   #353
whitewidow
Drives: 355i
Originally Posted by NealfromNZ View Post
With Mobridge for augmented HK system you can do the following
Run all HK speakers passive
Or
Drop either centre channel or rear door speakers and run a trunk sub.
Or what I’ve done.
Note , I’m quite oldschool with music so prefer the sound infront, No centre speaker and minimal sound from rear.
Active front door speakers (75 rms / 150 watts )
Underseat woofers ( 150rms / 300 watts )
Passive rear doors ( 75rms / 150 watts
Trunk sub ( 400 rms / 800 watt )
I’ve set the dsp up in the following manner.
DSP map 1 ( surround setting ON on Idrive ) map for all passenger
DSP map 2 ( surround setting OFF on Idrive ) drives seat tune , front speaker bias
Audio routing
Music sinks ( stereo on BMW ) , all speakers
Voice calls sinks , Front speakers
Nav / voice commands / chime sinks Drivers side speakers
PDC sinks , factory surround
Factory control of fader and HK eq functions
For now I just want to run all the stock hk speaker as they are except I will replace the under seat subs with earthquakes. Then add a 10" sub in the rear. Sounds like going with the Mobridge would fit my needs nicely.
