05-27-2013, 04:33 PM | #3719 |
Rep 383
So far I have everything working again. Office showed up and the Bluetooth options showed. The sub functions of office didn't yet show up, such as SMS etc, but I'm going to see if it works next time I turn on the car. The Bluetooth options weren't there before so I think that's a good sign.
05-27-2013, 06:40 PM | #3720 |
Rep 41,178
Yes. No problem. ENET is good for both.
05-27-2013, 09:28 PM | #3721 | |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
3073 - C_CLC_ENA = F020disable disabled both cornering fog lights AND the fog lights from turning on when reversing. |
05-28-2013, 08:32 PM | #3722 | ||
Rep 169
I was able to fix it by clicking the root folder, right click ---> "Code". This reset the whole car (all modules) to default values based on my VO. Tested it out today, the lights turn as expected. Quote:
Damn...good to know, Shawn! |
05-28-2013, 11:01 PM | #3723 | |
Rep 1,544
05-29-2013, 07:05 PM | #3725 | |
Rep 41,178
You don't need it though unless you are programming a car with 49.4 on it. |
05-31-2013, 07:38 AM | #3726 |
Rep 1,130
Drives: '16 340i AW MSport
Anyone know if you can code this?
- Change sensitivity of Auto-Headlights? I don't want the Xenon's to come on when it's still so bright outside on the Auto Setting. Would like for the DRL's to be on longer into dusk and have the Xenons turn on when its actually dark outside :P |
05-31-2013, 11:10 AM | #3727 | |
Rep 41,178
JBBF->3530 RLS, 0C->RLS_DEF_FLC_SCHWELLWERT_SATZ-> unempfindlich (default is empfindlich) JBBF->3530 RLS, 0C->RLS_FLC_SCHWELLWERT_SATZ unempfindlich (default is empfindlich) The "official" BMW way for both F10 and F30 to change the light control sensitivity is to use K-Words FLCN and FLCS: I have not tested them though, and the underlying FDL Changes may be the same JBBF codes above.
05-31-2013, 12:35 PM | #3728 | |
Rep 1,130
I don't get the unempfindlich (default is empfindlich), so thats also Sensitive or "insensitive", i'm assuming its already defaulted to insensitive, so I think I can only make it more sensitive then what it already is... Last edited by kromix; 05-31-2013 at 12:40 PM.. |
05-31-2013, 12:42 PM | #3729 |
Rep 41,178
Well, if you choose to assume that the underlying coding default is for Normal operation, then I guess not. Myself, I assume nothing about these cars when it comes to coding, and I test everything to prove it out. Nothing ventured, nothing gained.
05-31-2013, 01:33 PM | #3730 | |
Rep 1,892
For me (F30 with I-step F020-12-11-504) the default is "normal". They may have changed the default in other I-steps. The other options are: empfindlich (sensitive) sehr_empfindlich (very sensitive) unempfindlich (insensitive) Tagfahrlicht (DRL) Last edited by Frogman; 05-31-2013 at 01:41 PM.. |
05-31-2013, 01:48 PM | #3731 | |
Rep 41,178
As for the BMW way, by default a VO contains no K-Word for sensitivity, so until one actually tests K-Words FLCN and FLCS, there is no way of definitively knowing if using these set the same JBBF / FEM_BODY FDL Codes, and if so, which K-Word equates to which FDL Code.
05-31-2013, 04:16 PM | #3732 |
Rep 1,027
Shawn.. help I just got my car back from the dealer and it seems the upgraded my SW again.
missing cafd_000000f9-007_006_059 fehler: cafd_000000f9-007_006_059 not found where can I get the newest SW and I was the first one to buy the token months ago.
M Sport Line Estoril Blue
05-31-2013, 10:06 PM | #3733 |
Rep 41,178
PM sent.
06-01-2013, 09:38 PM | #3735 |
Rep 41,178
06-02-2013, 10:00 AM | #3736 |
Rep 1,027
andreas.. he said I don't need newer software..just the files..do I delete all old ones or choose overwrite?
06-02-2013, 10:08 AM | #3737 |
Rep 41,178
Yes, just replace two patched .jar files, and then in E-Sys options, change the EST location to point to your new .EST Token file.
06-03-2013, 02:02 AM | #3738 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Which option I need to choose to headlight switch on at more dark conditions instead of "normal" - "very sensitive" or "insensitive"? |
06-03-2013, 02:05 AM | #3739 |
Rep 41,178
Right now, your lights are coming on when it is still too light out, so your sensors are too sensitive, so you would set it to "insensitive" to decrease the sensitivity.
06-03-2013, 07:34 AM | #3740 |
Rep 1,130
Hey guys, anyone have any idea on this or atleast where to look to test?
From a locked turned off car state, When on Setting #3 (Auto Headlamp control), and I unlock my car the "Angel Eyes" or "Corona Rings" illuminate & stay on and the turn signal indicators flash. When on Setting #4 (Lamps Off/DRL) and I unlock my car the "Angel Eyes" or "Corona Rings" do not illuminate & stay on, but only the turn signal indicators flash. Is there a way via coding to enable the illumination of the "Corona Rings" on Car Unlock when in Setting 4? I'm guessing I'd have to find an area that has to do with the individual lamp settings 3/4/5/6, just not sure where to look? Last edited by kromix; 06-03-2013 at 06:57 PM.. |
