06-09-2013, 02:13 PM | #3785 | |
Rep 1,985
Drives: 2020 G20 320i M Sport
For the E84, you can probably check a thread for the E90s since they both can be coded with NCS Expert. He would need the latest DATEN files as opposed to psdzdata. |
06-09-2013, 10:41 PM | #3786 |
Rep 16
Hi experts,
I need a few explanation with the I-Levels.pdf. Can anyone tell me what F020-12-03-503 is... i read that its related to the chassis no. but after looking at my chassis/VIN no. i dont quite see what their relationship is? I recently bought the F30 328i and its a 2013 manufacturing, am i correct to say that the new versions of F30 may need newer versions of Esys and Datafile in order to have access to new functions? However, older version of Esys and Datafile used for access newer versions of F30 is still fine but only not able to have access to the newest functions....? Chris |
06-09-2013, 10:45 PM | #3787 | |
Rep 41,190
06-09-2013, 11:47 PM | #3788 |
Rep 16
06-09-2013, 11:48 PM | #3789 | |
Rep 41,190
http://www.f30post.com/forums/showpo...postcount=1403 If you have E-Sys 3.22.5 and 49.4 PSdZData, you don't have to worry about the car's I-Step.
06-10-2013, 11:17 AM | #3790 | |
Rep 226
06-10-2013, 11:20 AM | #3791 |
Rep 41,190
You will know if you have a Combox just from reading SVT. If you have a stand alone CMB_MEDIA module, or if you have HU_NBT Head Unit, then you have Combox.
06-11-2013, 09:12 AM | #3792 |
Rep 3
Hi,
After I did some small coding changes with succes I want to activate BT streaming on my F30. I thought that I should adapt my VO to include 6NL and to recode some ECU's afterwards. I did recode HU_NBT, but no result till now. Any other ECU to be recoded? Thanks. Sebastiaan |
06-11-2013, 09:22 AM | #3793 | |
Rep 41,190
Did you VO Code HU_NBT or FDL Code it?
06-11-2013, 09:35 AM | #3794 |
Rep 3
06-11-2013, 10:22 AM | #3795 | |
Rep 1,985
Let us know how it goes. |
06-11-2013, 10:36 AM | #3796 | |
Rep 41,190
I am not sure why his BT Streaming is not working. It should be.
06-11-2013, 10:41 AM | #3797 |
Rep 3
Changed the VO from 6NL to 6NK, recoded HU_NBT & that did it... Me happy!
Quite strange, since 6NK was the option I ordered but they told me immediately that this was without BT streaming audio. Perhaps this is a Belgian modification... Thanks guys! |
06-11-2013, 10:47 AM | #3798 |
Rep 1,985
06-11-2013, 10:54 AM | #3799 |
Rep 41,190
It could be that Coding 6NL without having Telematics Combox in NBT, and just having Media Combox in NBT was the issue.
06-11-2013, 11:23 AM | #3800 |
Rep 3
Drives: 2013 BMW 328i Sport Sedan
Which PSDZData Download?
Hi,
Based on previous comments from shawnsheridan and chris4chelsea, I check my I-Level and I have F020-12-11-505. Which PsdZData files should I download? |
06-11-2013, 12:03 PM | #3801 | |
Rep 1,985
I tried 6NL before on my CIC equipped F30 with factory 6NH and combox media and it took away "contacts" and didn't replace it with "office", I also no longer had access to bluetooth streaming. Under BMW assist, it has the assistance button but it's grey out and says I need to have it activated. |
06-11-2013, 12:11 PM | #3802 |
Rep 1,985
You're going to need 48.3 or higher along with E-Sys 3.22 and a custom code away token. If you had F020-12-11-504, you would be able to code it with E-sys 3.14 along with 48.1 without the need to upgrade or purchase a token.
06-11-2013, 01:21 PM | #3803 |
Rep 214
Guys is it still enough to have ESYS and data files to code? Some guy mentioned I need a "token" and a "patch" for new versions?
Edit: LOL there was a post about the token right before I posted.. Anyways can anyone inform me about this thing?
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
06-11-2013, 01:37 PM | #3804 | |
Rep 41,190
If you need to use >= 49.0 PSDzData, or >= 48.3 PSdZData in the case of F20/F30, then you need to use E-Sys 3.22.5, and obtain a Patch / Token for it. Otherwise, just keep using E-Sys 3.18.4.
06-11-2013, 01:58 PM | #3805 | |
Rep 214
06-11-2013, 06:36 PM | #3806 | |
Rep 59
Drives: 2016 340i MSport (DELIVERED!)
My '13 328i is on the way, and I'm trying to figure out if I can enable BT streaming audio through coding. I've dug through this thread, and am trying to make sense of the acronyms, but at 173 pages, it's a bit daunting. I ordered a 328i w/ Prem Pckg & a few other nontechnical options. So with basic phone-only BT and no nav, no bmw apps, etc. can coding enable BT streaming audio? If it can, I'll put in the time to educate myself and do it. If not, I have an external BT streaming solution I can use, but the integrated option would be preferred... Thanks! |
