12-14-2014, 12:07 PM | #375 |
Rep 1,555
I get the trim part, but what do you mean by "move the pick up point"? I don't rub at my height tucking about 1/2" of tire but would like to get the front down a little lower. I pulled the fenders out a little, as far as I think it is possible without looking noticeable.
12-14-2014, 12:19 PM | #377 | |
Rep 1,555
I would be curious how you did this as well. When I switched to KW V2 coils from H&R coils, even at the hardest setting I was rubbing on the rear with a ET42 10.5" wheel. I shaved the hubs so they would be ET44.5 (shaved off 2.5mm) and not rubbing anymore. Wonder if the Toyo tires have a slimmer profile than the Hankooks on the 275. You are running a lower profile so I get why you can get that low there, BUT when I looked for a 240/30 nothing came up. Do you have a 245/30? |
12-14-2014, 01:10 PM | #379 |
Automotive Photography
45
Rep 107
12-14-2014, 01:12 PM | #380 |
45
Rep 107
Thanks man. Getting the car back today with the BBK on, pictures will be posted sometime this week hopefully
12-14-2014, 01:23 PM | #381 | |
45
Rep 107
Onto the rear, I remember you saying you shaved your hubs. I was going to do that as well, but instead I just started modifying the liner where the tire was rubbing. Once I did that, I was good to go. Don't be scared to take some liner out And yes, Toyo's have a much more round side wall than any other tire that I have had. The T1 sport also has much more stretch for a 275/30 in my opinion. A lot of thought went into this fitment, so I wanted to get it right. Unfortunately, you have to modifying everything. Keep an eye on this thread, pics and full write up coming soon.
12-14-2014, 06:58 PM | #382 | |
wannabe
252
Rep 819
New setup is going to be 20x10 et 35 up front and 20x11 et 42 out back, I will be doing aftermarket arms in the rear to get it dialed in. |
12-14-2014, 11:18 PM | #383 | |
45
Rep 107
Where did you relocate the front bolts? Do you have any pics you could PM to me?
12-15-2014, 07:37 AM | #385 | |
Rep 1,555
OK all makes since and is all familiar. LOL... I am about the same height as you on the rear. Before shaving the hubs 2.5mm I was rubbing at 10 oclock right below where the bumper meets the metal fender. Never rubs the rear fender liners. Changing the offset to a 44.5 solved all my rear rubbing issues and I can ride with the KWs in the middle of the rebound setting so it rides very smooth. On the front I still rub a little on the fender lip at full compression but just barely and the fender liner but it has to be a pretty good jolt. If I go to the Toyo from the way it sounds, that should eliminate that. The front lip I pulled just slightly like I said. It is not noticeable at all and gives it that little extra clearance but the outer lip before the rim will graze the fender lip. When I switch back to the summers, I will take a heat gun to the areas where the liner was being hit and that should solve the rest. Just have to remold it, shouldnt have to cut it. Show a profile pic of your car. Looks sharp. Last edited by Dippydo; 12-15-2014 at 09:02 AM.. |
12-15-2014, 08:48 AM | #386 | |
wannabe
252
Rep 819
gonna go back with a 235/35/20 on the 20x10 and a 255/30/20 on the 20x11, gonna try a 265 first and then see if i can keep the camber at -3, if not ill swap for the 255. Ill try to get some pics of the fronts. |
12-15-2014, 09:08 AM | #387 | |
Rep 1,555
How's your tire wear at -3 camber? I was at -2.3 when I had my H&R coils with no rub, then when I got my KWs installed I tried to run at -3 to solve the rubbing and it didn't help and within 500 miles the inner tires were very noticeable of tire wear in just that short of time. Went back to -2.3 after my hubs were shaved, I swapped the tires around so the unworn was on the insides and after all summer driving 4000 miles they are back to wearing normal. So it seems the sweet spot for normal tire wear with neg camber is at about -2.3/.4. The shop is good at aligning but couldnt get it to stop the tire from eating away. Which is fine, going from -2 ish to -3 was a noticeable difference visually, so I was glad the shaving worked and to have the tire a little more upright. LOL. Here's how far my rear is down with the ET44.5 on a 10.5" If I go just a 1/8" lower it will start to rub. I would like to bring the front a little lower. Last edited by Dippydo; 12-15-2014 at 09:16 AM.. |
12-15-2014, 12:10 PM | #388 | |
45
Rep 107
Can't wait to see your new setup. 20X10 Also, what suspension and camber plates were you running?
12-15-2014, 12:40 PM | #389 | |
Rep 221
12-17-2014, 10:50 AM | #390 |
45
Rep 107
OCAUTO BMW 328i F30 - Daily Driven
I am writing about my full setup and what I did for the guys who are stalking this thread like I did looking for the "How the hell is he running that spec and sitting that low" question. Basically, you need to do a lot of modifying to get there. I took the precautionary approach from my experience and there was still things I needed to modify. There is no way to throw on a set of aggressive 20" wheels, lower the car and expect the car not to rub. It's impossible. And, from what I have seen on this thread, my wheels aren't that aggressive. Here are my specs: Wheels: SSR SP4 20X9 et29 (F) 20X10.5 et43 (R) Tires: Toyo T1 Sport 245/30/20 (F) 275/30/20 (R) Suspension: KW V2 Coilover So far this is how the car is sitting. I do a lot of driving from OC to Los Angeles with photo gear in the back. Adding the slightest bit of weight brings the rear down another 1/4-1/2". My photo equipment weighs around 150-200lbs depending on what I bring. I am running KW V2's with the rebound all the way up on the front and the rear. I modified the rear liner and rear bumper connecting points and currently have no rubbing issues. My front fenders were slightly rolled for extra clearance along with modifying the front fender connecting points and it still rubs. I need maybe a half degree of negative camber to fix the issue. Currently I do not have camber plates installed. IMO the car rides better with this current setup than it did at stock height with the BMW run flats it comes with. As far as rear camber, I am running -3.3 in the rear. It's a little aggressive, but we wanted to make sure I wasn't going to rub. Depending on tire wear, I will most likely have it adjusted back to -3/-2.75. I do have a little bit of room in the rear, but not much, maybe an 1/8". Ground Control Street Camber plates are being installed after the new year and I will be adjusting for slight rubbing of the fenders when hitting dips at higher speeds and turning lock to lock into parking lots with those awesome rain gutter dips. If the camber plates fix the rubbing issues, I will most likely lower the car to where I originally had it, which is another 1/4" all around. I'll be posting more pics as soon as I get a chance to take some. Hopefully this write up helps a little bit. Thanks for reading.
Atrain300027.50 |
12-17-2014, 11:45 PM | #391 |
Rep 221
^So how did you modify the front connecting points? The only easy solution I can think of is shave them off and put the quick release on the outside somehow, though I know lots of people won't like that
12-18-2014, 12:42 PM | #392 |
45
Rep 107
You can shave them down, don't shave them off completely
12-19-2014, 11:43 AM | #394 | |
Team Nemesis
48
Rep 276
12-19-2014, 12:26 PM | #395 | |
45
Rep 107
12-19-2014, 01:32 PM | #396 |
Team Nemesis
48
Rep 276
KendrickOak358.50 HondaGoneRogue432.50 |
aggressive, f30, low, slammed, stance |
