BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      05-02-2024, 01:11 PM   #4181
Cytoplasm0671
Armchair Aristocrat
Cytoplasm0671's Avatar
341
Drives: 340i 6MT
Originally Posted by Cytoplasm0671 View Post
Tune: BM3 OTS Stage 1 E30 map
Mix: E38 using 93-octane Shell gas (see log flexfuel sensor)
Equipment: Active Autowerke downpipe, TU HPFP, Pennzoil Plat Euro 5w40 oil, new NGK plugs (stock gapped)
Have had engine knock at low-RPM in the past. On advice of this forum am running E38 on the E30 tune to try and clear up the knock.
2 logs still have engine knock
Log 1: https://www.bootmod3.net/log?id=662f...7ee711b7e3d41b
Log 2 (knock): https://www.bootmod3.net/log?id=662f...7ee711b7e3d47a
Log 3 (knock): https://www.bootmod3.net/log?id=662f...a8bf21c558e861
Log 4: https://www.bootmod3.net/log?id=662f...a8bf21c558e869
Any ideas what to try next?
**EDIT**
I think it might be something on cylinder 5. For both knock logs, it seems cylinder 5 that is knocking. Also see this E30 Stage 1 Map w/E43 from September: https://www.bootmod3.net/log?id=6502...90c6120936bbcd this Stage 2 map: https://www.bootmod3.net/log?id=6502...0b435ca6e0a8cc and this Stage 2+ map: https://www.bootmod3.net/log?id=6502...729b152462c3f5
It is always cylinder 5 that is most affected. Already replaced plugs so it might be time for some new coils or injectors? Anyone have any thoughts?
Any thoughts? Does cylinder 5 also look like the leading problem to others? Should I replace the coils and see if that helps?
      05-02-2024, 02:22 PM   #4182
Michalt
Michalt's Avatar
Drives: 340i
Originally Posted by DieselDuck View Post
Not looking the best, looks like low quality gas. Try some premium fuels like Total or Shell and see if it improves. If not you could flash the 95 ron map.
Now I changed to 95 ron map
https://datazap.me/u/black340i/log-1...?log=0&data=22
      05-02-2024, 03:47 PM   #4183
DieselDuck
DieselDuck's Avatar
94
Drives: BMWB58
Originally Posted by Michalt View Post
Looking lovely! Your car is much, much happier now and you're probably not even making less power as at least your timing profile is better.
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
      05-02-2024, 04:04 PM   #4184
Michalt
Michalt's Avatar
Drives: 340i
Thanks buddy!
I need to check other fuel ron98 for sure or ron100 to map ron98.
      05-02-2024, 07:10 PM   #4185
SimonO
Drives: 340i
Originally Posted by WrxToBeamerGuy View Post
Timing does not look okay. I would try another gas station, adding ethanol, or flashing a lower map.
Did another run on the 95 map but with 99 fuel. Generally things look cleaner now with considerably less corrections. I'll try different fuel next time I fill up.
https://datazap.me/u/simonocr/020524...35-36-37-38-39
Thanks
      05-02-2024, 10:07 PM   #4186
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
498
Drives: BMW 340i xDrive
Thanks
Yes this to me is perfect timing as the corrections are so minor.
Dustin Braun @ Braun Performance Tuning
SimonO11.50
      05-03-2024, 03:37 PM   #4187
Polyhedr0n
Drives: BMW M340i 2020
2020 BMW M340i  [0.00]
Did my first pull using 91 OTS MHD.. Bad Costco gas?
https://datazap.me/u/polyhedron/0503...23-24-25-26-27
      05-03-2024, 04:22 PM   #4188
DieselDuck
DieselDuck's Avatar
94
Drives: BMWB58
my goodness that is bad what is wrong with your guys fuel haha
      05-03-2024, 06:40 PM   #4189
Polyhedr0n
Guess I have to live with it. Cost of saying in California. Will try Chevron E25 mix next time.
      05-03-2024, 07:58 PM   #4190
WrxToBeamerGuy
498
Youre in california though you should always use a gas station where you can mix in some E because why not
      05-03-2024, 10:36 PM   #4191
BryanB58
Drives: 2016 340i
https://datazap.me/u/elb58/4th-%E2%9...35-36-37-39-66
anybody can take a look?
california 91 mixed with E85
      05-03-2024, 10:42 PM   #4192
BryanB58
Drives: 2016 340i
Originally Posted by Skyhigh View Post
Used to happen up to 4 out of 5 times with the black MHD adapter! It was absolutely terrible as most of my logs were unusable!
Tried with a second one - same/similar thing.
Since I moved to the MHD Universal one - the problem disappeared completely.
The mhd universal is the red one right. I will definitely order that one cause it used to be fine but recently has really been cutting out smh everytime i think i hit a perfect log i check and see cuts out between 4k and 6k rpm
      05-04-2024, 02:31 AM   #4193
Skyhigh
Skyhigh's Avatar
1927
Drives: BMW F36
Yes, the red semi-transparent one
      05-05-2024, 12:28 AM   #4194
WrxToBeamerGuy
498
I dont love the timing corrections up top. When you shift into the next gear do they disappear or get worse?
      05-06-2024, 12:26 AM   #4195
BryanB58
Drives: 2016 340i
Heres the revision on E30
https://datazap.me/u/elb58/proper-4t...48-49-50-51-52
I added 2.5 gallons more e85 got it to E40, now seems better w revision
https://datazap.me/u/elb58/e40-4th?l...49-50-51-52-67
      05-06-2024, 09:55 PM   #4196
WrxToBeamerGuy
498
Both of those logs look perfect timing correction wise.
      05-07-2024, 08:20 PM   #4197
noblinka
noblinka's Avatar
Drives: X3 M40i
Would love some help from yall. Noob here and first time bmw owner and tuner. 2018 x3 m40i. Catted downpipe. BM3 stage 2 tune. Shell 93 gas in tank. (Ontario Canada)
Did some logs today. One of them was in 91 tune and the others were 93 but I lost track of which was which lmao. Posting links here as I have zero clue how to make sense of the logs.Hopefully someone can help!
https://www.bootmod3.net/log?id=663a...b3016b562355e5
https://www.bootmod3.net/log?id=663a...b3016b56235615
https://www.bootmod3.net/log?id=663a...bd5c26d0f66073
https://www.bootmod3.net/log?id=663a...b3016b56235636
https://www.bootmod3.net/log?id=663a...bd5c26d0f6611c
      05-08-2024, 10:00 AM   #4198
Dom147
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
Chasing a timing correction issue here. I keep getting such high correction values. I'm running the stage 2 93 map OTS with 2 gallons of E85 making it about E20 so it is surely not a fueling issue. I have my vanos parameters logged, could it be that? if it's not that, what else could it be? Maybe someone here sees something that I dont.
I'm at 77k miles.
https://www.bootmod3.net/log?id=663b...bc091026be86fd
Edit: Looking though I noticed my fuel pump having fluctuations toward redline, could this be it?
      05-08-2024, 01:57 PM   #4199
luisnazario
luisnazario's Avatar
Drives: BMW M240i 2017
https://datazap.me/u/luisnazario23/v...og=0&data=3-20
This is my log. My car is super slow and has slight hesitation on idle.
Any help will be appreciated!
Car has catless downpipe, kn drop in filter, tu hpfp, xHP and MHD stage 2 HPFP 93.
      05-08-2024, 08:08 PM   #4200
Tricki
Tricki's Avatar
215
Drives: BMW 340i B58 Gen1
Hi Guys.
2016 340i B58 Gen1 with 87K Miles. TUPUMP E40 OTS MHD Catted DP.
Boost & Target is about 3PSI different
Anyone see why you think its not reaching target? Need a catless DP instead of Catted?
https://datazap.me/u/mattspies/log-1...38&zoom=35-127
      05-08-2024, 10:37 PM   #4201
WrxToBeamerGuy
498
This is really bad... is it a custom tune? Has it always felt slow? I can tell its slow because your actual timing is all negative which is crazy. If you have a stage 1 tune try flashing to that... try switching gas stations as well... also reset your adaptations on the car.
      05-08-2024, 10:38 PM   #4202
WrxToBeamerGuy
498
Originally Posted by Tricki View Post
Hi Guys.
Perfectly normal if you are stock turbo. They just cant produce that much airflow.
