08-17-2013, 02:17 AM | #4335 |
Rep 41,205
I would contact Patch / Token provider.
08-17-2013, 02:20 AM | #4337 |
Rep 41,205
No. I use Win8 64-Bit with no issues.
08-17-2013, 02:23 AM | #4338 |
Rep 41,205
Did you rename the Patch files before copying them to their folders?
08-17-2013, 04:11 AM | #4341 |
Rep 44
I am having the same problem as kneesliding with my Token and Patch received this morning.
I will also write to the sender. Running Windows Vista 32 bit. edit: Running e-sys 3.22.5 (build 34057)
______________________
Drives: M235i Coupe |
08-17-2013, 09:13 AM | #4342 |
Rep 1,892
08-17-2013, 09:30 AM | #4343 | |
Rep 10
i'am michael, i come from belgium and i'am the brother of thebadboy. My english is a little bit better but not so good. @shawnsheridan: what we want is that "High beam assist" are automatically ON when headlights come on. We already have "high beam assits" option so we don't need add this option, just HBA go ON without pushing the button. I hope my question is understandable Last edited by shinerune; 08-17-2013 at 09:38 AM.. |
08-17-2013, 12:48 PM | #4345 |
Rep 88
Hi,
So, worked out how to change to 6NH, can anyone point me in the right direction for adding Bluetooth Audio Streaming, 2 Phones at the same time, and maybe Office? Cheers, Peter |
08-17-2013, 02:42 PM | #4346 |
Rep 88
08-17-2013, 03:31 PM | #4347 | |
Rep 109
Thanks! |
08-17-2013, 04:10 PM | #4348 | |
Rep 41,205
Glad the new token was the fix.
08-17-2013, 04:16 PM | #4349 | |
Rep 41,205
http://www.f30post.com/forums/showpo...042&postcount= This is how it works on F10, but for F30, I do not know, except to say that if it is possible, the Code should be similar.
08-17-2013, 04:19 PM | #4350 |
Rep 41,205
PM sent.
08-17-2013, 04:24 PM | #4351 | |
Rep 41,205
If you have 6NK in the VO, and VO Code Combox and Head Unit, you should not have to FDL Code A2DP for Bluetooth Streaming to work. That is the whole purpose of modifying the VO and VO Coding ECU's, so you do not have to make all the individual FDL Code changes to support the 6NK Option Code.
08-17-2013, 04:30 PM | #4352 |
Rep 10
@shawnsheridan
ok thanks for the answer, we will try your solution as soon as possible and tell if coding are working or not. Other question, do you know if it's possible to "code" speed limit info. My car was built in june 2013, i have HBA and Lane-change warning, i suppose that SLI work with the same camera that HBA ? |
08-17-2013, 04:38 PM | #4354 |
Rep 109
For Driver-Assist equipped F30 owners who are interested in lowering the speed above which the lane change warning (or blind spot detection) feature is enabled:
ICM 3000 Daten, F8 HcSwcCPar_i_Hc2_Aktiv_v_low change 50kmh to 30kmh (about 20 mph) There are more lower speeds available in the pull-down window, but it was reported that there will be some errors if it is set to any speed lower than 30 kmh. |
08-17-2013, 04:41 PM | #4355 | |
Rep 10
he has already tried to find "FLA_AUTO_AKTIV = aktiv or automatisch" in FEM_BODY but apparently there nothing looks like |
08-17-2013, 05:07 PM | #4356 | |
Rep 41,205
