BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [NBT EVO/NBT2]can't read fcs code from neither esys nor SW ID reader
proTUNING Freaks
      11-14-2023, 03:08 AM   #23
TheNine90
Drives: bmw
Originally Posted by Xxblinddzxx View Post
matter of fact... i do i screw up my damn gps
NA 340i f30 2017 NBT2 if needed =)
The maps shouldnt affect GPS. If the GPS is faulty or is incorrect then maps will show it the way it is.
You can PM me if you map update FSC.
tkmloh0.00
      12-05-2023, 01:10 AM   #24
redfelix
Drives: Bmw Touring F31 - 2.0d 190CV
Hello everyone and thanks for welcoming me to the forum, I would like to update my maps to the 2024-1 version. I already have the map file, I would need the file with the code to put in the flash drive. Can someone help me? Do I need to extract the FSC with e-sys?
      12-05-2023, 01:23 AM   #25
TheNine90
Drives: bmw
If you have NBT you can extract current DE file. You can send the FSC and i can generate the code for you.
You can use esys to extract the FSC.
For the extract : FSC EXTENDED -> DIAGNOSTIC ADRESS 0x63 -> APPLICATION NUMBER 0xDF -> UPGRADE INDEX 0x1 -> IDENTIFY -> GETFSC -> READ & SAVE
      12-13-2023, 06:27 AM   #26
methor
Drives: bmw e60, F30
Hello everyone, I'm having trouble getting the necessary code to unlock the maps. I've tried two generators, but they haven't worked for me. My car is an F30 2015 NBT2, and I've managed to obtain the FSC code, but I'm unable to get the lifetime code. This is my FSC file: https://mega.nz/file/jdgWXaZZ#htJamL...tD7vsF22Ndd0z4
I've 2023-2 EVO maps EUROPE WEST
Can someone help me? Thank you.
      12-13-2023, 10:18 AM   #27
TheNine90
Drives: bmw
There is no generator for free FSC generator for NBTEVO. NBTevo also uses FSC file instead of FSC code. PM me i can generate for you map update fsc
      01-09-2024, 12:54 AM   #28
TheNine90
Drives: bmw
The free generators available wont work. PM me i can generate for you
      01-12-2024, 02:51 AM   #29
tsbs
tsbs's Avatar
Drives: BMW 6GT
Hi! i've just send you PM ) thanks!
      01-12-2024, 03:44 AM   #30
Siki78
Siki78's Avatar
145
Drives: F30,G30
You can generate nbt evo id4 F0 is possible.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      01-12-2024, 03:52 AM   #31
Siki78
Siki78's Avatar
145
Drives: F30,G30
Write here your fsc F0 file.
      01-12-2024, 05:41 AM   #32
tsbs
tsbs's Avatar
Drives: BMW 6GT
I have NBT EVO id6 - 2017 as shown below the post. is it possible to generate?
      01-12-2024, 05:45 AM   #33
Siki78
Siki78's Avatar
145
Drives: F30,G30
No you can write TheNine90
tsbs0.00
      04-02-2024, 07:56 PM   #34
siwo
siwo's Avatar
Drives: 2016 M235i RWD 6MT
I've got a 2016 F22 with NBT EVO ID4
My nav also is indicating this:
Road Map NORTH AMERICA EVO
2016-2
NBTevo_E16072A
Automatic map update
CAN, AK (2019-2)
I assume I've got 2019-2 map through automatic updates?
Is it possible to get the FSC file off my vehicle? If so, would I be able to use that code to generate a FSC code for map updating?
Haven't thought about map updates until now really...
Thanks in advance
2016 M235i RWD 6MT - Current! as of July 28/16
2015 ES350 6AT - Traded In
2004 RX330 5AT - Sold
2004 Civic Coupe Si(EX) 5MT - Retired
1993 Civic Coupe Si(EX) 5MT - Retired
      05-05-2024, 03:09 PM   #35
goga8goga
Drives: bmw f30
nbt2
Originally Posted by Wibbles View Post
You won't be able to create your own FSC update code using that tool.
Save the F0 FSC from your car to your desktop - upload to Mega or Dropbox then PM me the link, I'll do the rest - no charge.
Hi. Can you generate fsc for NBT2 map i have 2024. I will be very grateful.
https://drive.google.com/drive/folde...Sj?usp=sharing
      05-06-2024, 12:11 AM   #36
Ciobrelis
Drives: BMW 330d Lci Xdrive
Hello,
Could someone help me with the map code for Nbt evo ID4?
Here is the fsc file: https://we.tl/t-55af47cKsU
I'm trying to install Road map Europe Evo 2024-01
Thanks
bimmercode, ecu, esys, esysx, fsc, fsc code
