04-17-2014, 02:20 PM | #23 | |
Rep 255
I'm in a 2013 335i M Sport 8AT with ECU Tuning Group tune, Challenge HFC DP, ER CP, and BMS intake (and muffler delete just to complete the list). I have a JB4 that I bought from someone on the forums which I found problematic. I might patch it up and play around with it. Boost was cutting in and out, I don't really know what's wrong and the BMS guys don't want to help me out since I didn't buy it new (which is completely understandable). |
04-17-2014, 05:41 PM | #24 | |
Rep 287
Drives: '15 GT-R, '02 996TT
04-17-2014, 06:06 PM | #25 |
Rep 51
No, I like the jerkiness and aggressive shifting that is normal in sport plus mode and a heavy foot. It is what the ZF is all about...
This is hesitating and slowly shifting grabbing and then going. When I fully accelerate from dead stop in 1 .. the tranny goes to shift into 2 and it throws you forward because it breaks the momentum of going forward then once it catches it continues to accelerate into 2nd. The car literally shakes as it tries to catch the next gear, sort of like a stuttering person trying to get the next word out. |
04-17-2014, 07:45 PM | #26 | |
Rep 287
04-17-2014, 08:22 PM | #27 | |
Rep 116,037
Mike |
04-19-2014, 01:08 PM | #28 |
Rep 51
I am not sure of the problem any more. I am getting a "BOV plausability -- tuner code ignore" reading on the JB4 .. there was this very weird humming coming from the car and it was running very hot. I think it was the water pump. The car was not boosting right and the transmission was slipping or not engaging correctly.
I took out the tune and will take out the downpipe and bring it in for service. Could the water pump be causing both overheating problems AND transmission problems. I was reading that it does provide cooling for transmission. Something is either broken or not working efficiently. I could of cracked the charge pipe ... could be anything as of now. From the humming to the tranny to the temp -- the best bet is to delete codes with BT tool, return to stock and bring her into the dealer and have everything looked at. Will update everyone. |
04-21-2014, 11:06 PM | #30 |
Rep 116
I've been running map 5 for a few days now on 94 octane and it definitely feels stronger than map2.
Gonna try to capture a few logs this week. So far so good. |
04-26-2014, 02:53 AM | #31 | |
Rep 78
You have the same set-up I'm considering doing to my 13 MSport 335ix. Can you provide me with any pros/cons and maybe some videos? Excuse me if I'm clumsy gents I've been using f30post for research for the past two years on my previous F30's but never joined in the discussion... Cheers ? ? My bad! |
04-26-2014, 06:31 AM | #32 | ||
Rep 883
Been running MAP 5 with E85 wires with no issues at all. I've done about 3 dozen logs and it appears to be working.
04-28-2014, 08:58 AM | #33 | |
Rep 255
04-28-2014, 08:58 AM | #34 | |
Rep 255
04-30-2014, 10:27 AM | #35 |
Rep 271
I take is your are not mixing with E85 so you don't have the flex fuel wires installed correct? What does FBO mean?
2021 M550i
BMS Pedal tuner JB4 Last edited by BimmerFan; 04-30-2014 at 10:42 AM.. |
04-30-2014, 10:33 AM | #36 | |
Rep 271
EDIT: Nevermind. This is for cars with the pneumatic Solenoid.
2021 M550i
BMS Pedal tuner JB4 Last edited by BimmerFan; 04-30-2014 at 10:41 AM.. |
05-06-2014, 02:35 PM | #38 |
Rep 116
05-06-2014, 03:02 PM | #39 |
Rep 271
N55 with electronic solenoid?
2021 M550i
BMS Pedal tuner JB4 |
06-05-2014, 05:23 AM | #40 |
Rep 556
Drives: 2012 BMW 335I
Any updates on map 5? Can you get the link still?
I have pneumatic (I think), if so I can run map 5? My 2 cents, even though I run e85 with the FF wires, I only put (now) a max of like 3 gallons and the rest either with all 91 or a combo of 91 and 100 octane.. Personally, my car hauls way more ass with 100 octane, although I have felt the beast/power of e85, but I honestly think e85 is way too lean, compared to gas, you can feel it. And don't put too much e85 in bc I did before I made the 3 gallon rule, filled up half a tank, and had many problems until I got all the gas out of there, new fuel injectors, and new spark plugs. So beware. Also, I definitely have hit 130+, and it wasn't stopping, it would of kept going up but it was getting scary fast at that point LOL
2012 BMW 335I F30-- KWV2, VOLK TTA-TE37, HANKOOK V12'S, MEISTERSCHAFT SUPER GT RACING EXHAUST, JB4 STAGE 2 MAP 2, CHALLENGE HFC DOWNPIPE, M-PERF SIDE SKIRTS, M-PERF REAR BUMPER, CUSTOM LTMW F30/F12 FRONT BUMPER (THANKS LONG!!), HID FOG LIGHTS, MATTE BLACK GRILLE, UNDERGROUND EURO WHITE SIDE BULBS, GLOSS VINYL ROOF WRAP AND WINDOW TRIM, CUSTOM STRUT BAR
06-12-2014, 10:06 PM | #42 | |
Rep 161
I got one run in before the rain got bad, and hit 15.2 in the new map 5 beta, BMS intake, MPE, and 93 octane plus booster...I need to do a couple good runs in both map 2 and 5. |
06-15-2014, 11:24 PM | #43 | |
Rep 116
I have similar mods. -BMS Intake -MPE -Catless DP |
06-16-2014, 12:33 AM | #44 |
Rep 4,529
EWG - electric waste gate - fitted to post July 13 cars
Harness - JB4 extra wiring to control EWG - currently under going tests so limited release to the public from BMS
Current '22 X3M LCI.. |
