BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Passing inspection with Catless downpipe
      03-06-2024, 08:50 AM   #23
M3SQRD
M3SQRD's Avatar
2485
Drives: E92 M3,G20 330ix,F22 240iX,F82
Originally Posted by JustcallmeToby View Post
well i thought in NY you can have 1 non ready still pass
That may be true but the cat absolutely must show ready. The cat showing not ready is an automatic fail in all states with emissions testing.
      03-06-2024, 09:01 AM   #24
JustcallmeToby
Drives: BMW 335I Xdrive
oh okay gotcha, so looks like the best bet is this o2 spacer n then drive light till it ready's up
      03-06-2024, 09:08 AM   #25
JustcallmeToby
do you know if the spacer goes in the upstream hole closest to turbo side or the hole closest to the exhaust and vband to exhaust side ?
      03-06-2024, 09:17 AM   #26
M3SQRD
M3SQRD's Avatar
2485
I have no personal experience with using o2 extenders or mini o2 cats. However, it’s the post-cat o2 locations (the holes closest to the midpipe/exhaust).
      03-06-2024, 09:20 AM   #27
JustcallmeToby
bet ill give you guys an update after i pass inspection. Thanks man for all the input. much appreciated.
      03-06-2024, 10:58 AM   #28
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
O2 spacers don’t seem to work with late model BMW. There are mini-cat O2 spacers that also have mixed results though I like the theory better.
      03-16-2024, 03:55 PM   #29
SpeedOften
Cone Killing E90
47
Drives: 19 X3 M40i
2019 BMW X3 M40i  [10.00]
Looking at getting one of these from Turner...
https://www.turnermotorsport.com/p-5...ensor-adaptor/
      03-17-2024, 08:35 AM   #30
cooolone2
cooolone2's Avatar
639
Drives: 20' M240iX B58, 01' 330XI E46
The upstream, or O2-1 is the O2 that matters... The second one is just measuring difference pre and post cat. But O2-1 is measuring what the engine is doing, ie, fuel ratio, efficiency of burn cycle, ie, making sure engine air/fuel is reaching stoich...
Depending on what your tolerance is, there are ways to try and prevent the code while catless. Not sure on tuning availability with this platform but some 'older' platforms allowed for the turning off of code checks via the ECU, and would report all as normal. Not a good idea while driving of course, but for certain diagnostics, worked great. Get what I mean!? Unfortunately, newer ECU's or the programmers might not tweak these sections of an ECU either, so there's that. Down pipe really isn't hard to pop in/out and as a last resort, could just get the car up in the air, swap out the DP, drop a stock tune on it and get it inspected. Price of doing business...
Gotta PAY if ya wanna PLAY! Sometimes there's no easy way, but there's still a way!
Good Luck
      04-15-2024, 08:37 AM   #31
JustcallmeToby
*UPDATE * Anybody that said you couldn't pass with Catless downpipe AND A Tune was spreading misinformation. if your rocking a downpipe with MHD just click aftermarket downpipe in the MHD Menu. Drive around to ready the monitors and go get it inspected. Super simple
BIGW0RM3254.50
      04-15-2024, 08:38 AM   #32
JustcallmeToby
you guys dont need any o2 spacers with the mini cat. its all not needed. just click aftermarket downpipe , drive around to get the monitors ready n go get it inspected.
      04-15-2024, 08:51 AM   #33
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
lol. wow. Smog Safe Tunes are here...lol.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
      04-15-2024, 09:10 AM   #34
MADBMWX5MC
MADBMWX5MC's Avatar
1050
Drives: 2023 BMW X5MC
So it all worked out for you, good deal, even better that you shared the experience.
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
      04-15-2024, 09:34 AM   #35
JustcallmeToby
. Yes sir. I was nervous at first because everybody telling me about the ready monitors but i went to autozone and hooked up there scanner yesterday to just see if the monitors were ready and the foxwell scanner they have said all monitors ready. so were good for another 364.
      04-15-2024, 09:35 AM   #36
JustcallmeToby
lmaooo i was like i hope i dont have put the stock downpipe back on just to pass. so thankfully 5 min later n were all good to go
      04-15-2024, 09:55 AM   #37
MADBMWX5MC
MADBMWX5MC's Avatar
1050
Good deal, here where I live, that's all the tech cares...if all monitors are ready, I am good.
      05-13-2024, 11:47 AM   #38
Burjak
Drives: 2017 330i
Does anyone know if this is a feature on BM3, really don’t feel like adding a spacer to pass 🥲
      05-13-2024, 03:58 PM   #39
pbonsalb
It was a feature and maybe still is since BM3 is downloaded from outside the USA.
      05-13-2024, 05:26 PM   #40
M3SQRD
M3SQRD's Avatar
2485
Not true. Only MHD tunes have an option to modify emissions settings in the ecu which is against the law. They’ve gotten away with it for now because they aren’t a US tuning company. No US tuner will alter ecu parameters to allow you to pass without cats. It’s not spreading misinformation. What you’ve done is against US law and you openly admit it. Way to go.
Here’s a link to the EPA emissions tampering:
https://www.epa.gov/sites/default/fi...s-enfalert.pdf
      05-14-2024, 06:31 AM   #41
Leucosticte
Leucosticte's Avatar
224
Drives: 2007 BMW 328xi E92 6mt swap
2007 BMW 328xi  [0.00]
Will they really bust down his door over an anonymous comment on an internet forum?
My issue with this sort of discussion in a public domain is not the FBI knocking down your door at 4AM, it's that the government might pick up on what people are doing to get around it and then make it harder to get around it. E.g. Adding a way for the OBDII software to compare the software checksums between stock and aftermarket tunes. This is already a reality in California.
      05-14-2024, 06:51 AM   #42
M3SQRD
M3SQRD's Avatar
2485
They’re going after vendors for selling the smallest emissions mods including intakes. If someone were to say to the epa there’s a car forum openly discussing how to defeat emissions testing and effectively saying it’s “legal”, I could see them amending the document to stating any vendor, regardless of their location, must not defeat/alter emissions equipment in the ecu. To state telling the guy that passing emissions testing without cats is misinformation is a child who doesn’t know the effects of a catless system on emissions or doesn’t care what his contribution to global emissions is. It’s just him so how bad can it be? The problem is it’s NOT just him. What I don’t understand , BM3, Cary Jordan, BimmerWorld (actually they no longer sell tunes to state registered cars due to the epa), etc, sell stage 2 tunes that use stock cars. Don’t believe me, ask them. So other than wanting to be obnoxiously loud, there’s no reason to remove cats or if you do buy the AA EPA-certified HFC DP. You gotta pay to play properly.
AmuroRay2379.00
      05-14-2024, 07:40 AM   #43
Leucosticte
224
I agree with most of what you said, talking about this stuff in public will just ruin everything for enthusiasts.
MADBMWX5MC1049.50
AmuroRay2379.00
      05-20-2024, 08:07 AM   #44
JustcallmeToby
i thought this was a safe place to talk. if me giving information merits the FBI kicking down my door then so be it.
