BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > HP70 Swap into FXX N55 BMW DIY
      01-21-2022, 09:28 AM   #23
armenh7
Drives: 2017 340i
Do you have an idea of how much torque you were putting down? I am in the process of 8HP45 swapping my turbo E46 and had the same justification that it's overbuilt and will be fine. The main reason I'm using a 8HP45 is because it's PNP and much more accessible than a M57 8HP70. I've never dyno'd my car but it puts out an estimated 430-460ft/lbs. I never launch and I believe this will help prolong the life of the transmission vs you. Thanks.
      01-21-2022, 12:14 PM   #24
jq_f22
Drives: BMW M235xi
I never dynoed my car either but ots+ cars dyno close to 500wtq and my custom map was quite a bit quicker so north of 550 ft/lbs at the crank would be my guess. Cool stuff M54? I would say you're fine if you don't go past 460lb ft but if you want the headroom for future power definitely consider a HP70.
IG @jq_f22
      03-13-2022, 02:24 PM   #25
BmwM140i
Drives: M140i
How was comfort to sport plus shifting with the hp70.
Have a hp70 installed in my m140i and comfort to sports plus in D mode feels lazy sluggish won’t downshift till half throttle is applied makes daily driving bit crappy. Have xhp installed
      03-14-2022, 01:27 PM   #26
thejeremyman9
thejeremyman9's Avatar
4392
Drives: 2015 BMW 335i
You should be able to use XHP custom settings to change that behavior
      03-14-2022, 02:16 PM   #27
jq_f22
Drives: BMW M235xi
It felt very responsive, I would contact RBT and get their input.
IG @jq_f22
      03-23-2022, 03:49 PM   #28
BmwM140i
Drives: M140i
Can’t use the shift editor it’s disabled
      03-23-2022, 03:53 PM   #29
BmwM140i
Drives: M140i
Spoke to a few people with a hp70 and they all said the same thing feels really bad in D comfort to sport plus most people said they just resorted to using Manual.
It’s responsive in S but all that’s good for it basically track gear changes hang out too long
Either super sluggish D mode or harsh S.
miss the daily spirited mode from the hp50 D sport / plus
Seriously considering putting the hp50 back
      03-29-2022, 08:34 AM   #30
jq_f22
Drives: BMW M235xi
Again, contact RBT the difference you might be feeling sounds like tcu mapping. Your map is different from what I was running. Not sure why you did all the work of pulling out the hp50 if it wasn't needed... Cheers
IG @jq_f22
      04-09-2022, 05:24 AM   #31
BmwM140i
Drives: M140i
Was def needed running well
Over what the hp50 is recommended for
I’ll give them a shout see if anything can be done.. it’s not just me though that has the issue seems like everyone has. Just feels like the shift points haven’t been changed from the diesel ones. Under whelming is an understatement. Diesel shifts points in a 140i is hard to live with
      04-10-2022, 08:51 AM   #32
jq_f22
Drives: BMW M235xi
Yeah contact them super responsive team at RBT. You should be running the b58 only hp70 swap map that was developed a while back. They are a few other b58 owners with that map on this forum ask them about their experience. It's also just possible your transmission is a dud, swap wasn't completed correctly, fill procedure not completed properly etc ...
IG @jq_f22
      05-26-2022, 08:58 PM   #33
Kdebraux
Drives: 2014 bmw 335i
If anyone would like to buy the Transmission from this thread, I purchased it off of OP back in February to put in my car. Life has kinda hit my whole family with a curve ball and I will no longer be building my car at least for the time being. I have put zero miles on it as I have just been accumulating parts for the build since the time of purchase. I will sell it for $2500 which is what I bought it for. It can be picked up in SW Ohio or shipped at the buyers expense.
jq_f2274.00
      05-26-2022, 09:23 PM   #34
Pussiwillow
Drives: Alpine white 2014 335i msport
Hey just chiming in to say I hope all is ok with you and the family, curve balls happen, family is always most important, sending all positive vibes I got !
jq_f2274.00
      05-27-2022, 03:30 PM   #35
jq_f22
Drives: BMW M235xi
Same here brother, hope all will be well, GLWS.
IG @jq_f22
      02-14-2023, 05:16 PM   #36
scottygrape
Drives: F30 335i Xdrive
Hey jq_f22 I came across your post and I am trying to acquire a 8hp70 for the same thing you did. Are you in the UK? I can’t seem to source one from a 330d.
      07-12-2023, 11:19 AM   #37
rlesko
Drives: F30 335i
2012 335i  [0.00]
Did you need a different transmission support bracket? Also did you try flashing Alpina transmission software?
      08-06-2023, 09:22 AM   #38
rlesko
Drives: F30 335i
2012 335i  [0.00]
Did you ever find a way to source one? It seems these transmissions are mostly off european model only cars- though you might be able to find one off an F10 diesel model stateside.
      08-20-2023, 10:49 AM   #39
Mbrinker7
Drives: Bmw m235i
  [0.00]
You still selling it?
      08-20-2023, 12:01 PM   #40
Kdebraux
Yes
      08-20-2023, 12:07 PM   #41
Mbrinker7
Drives: Bmw m235i
  [0.00]
Yes
Message me on instagram. I’ll give you my number. Estoril.n55
      05-05-2024, 12:38 PM   #42
rlesko
Drives: F30 335i
2012 335i  [0.00]
As you can see from the above the bell housing of the two differs not only in bolt pattern but in starter location, another key difference is that oil cooler line ports on the HP70 are smaller than the HP45, 18.2mm vs 16.4mm. Both of these issues are easily taken care of with a quick visit to your local metal fabricator/machinist. A buddy's shop took care of this for me in half an hour.
I wonder if the ActiveHybrid3 transmission oil cooler lines can be used if fabricating larger holes is not an option / prohibitive.
https://www.realoem.com/bmw/enUS/sho...38#17227607160
The AH3 comes with a special "8P70H" transmission, which is a special 8HP70 transmission with an electric motor in place of the torque converter.
The Alpina B3 uses BMW part 17 22 7 626 316 for the oil cooler lines, but according to OP it seems like those would not fit without additional fabrication.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
