03-10-2016, 04:44 AM | #23 | |
Rep 144
I hope it will not fit on F30. It will safe me lots money Last edited by F30_335; 03-10-2016 at 05:08 AM.. |
Tr0y119.00 |
03-10-2016, 07:28 AM | #24 |
Rep 234
03-10-2016, 08:40 AM | #25 |
Rep 410
Drives: One car with good steering ;)
03-11-2016, 05:25 AM | #27 |
Rep 144
03-11-2016, 06:43 AM | #28 |
Rep 234
Engine room size exactly same ... no interference .. Only thing why M4 has loger hood than F30/F32 is that front bumper is expanded 30~40mm more than F30/F32 ...
peopleschoice135.00 |
03-11-2016, 07:27 AM | #29 |
Rep 234
Mount covering finished ...
03-11-2016, 06:03 PM | #31 |
Rep 501
Awesome
2021 F87 M2C HS DCT/MPE (Nov 2020 - Present)
2018 F32 440i MR/CR MPPSK (Mar 2018 - Nov 2020) 2014 F32 435i EB/CR (May 2014 - May 2017) 2011 E92 335is AW/CR (Nov 2010 - Nov 2013) 2008 E92 328i JB/BL (Feb 2008 - Nov 2010) |
03-12-2016, 07:44 PM | #32 |
Rep 234
[Quick update]
When you try installing alloy strut brace, you couldn't find any tightened nut assembled with the strut through the edge hole .. (Only M4 has this blind rivet nut) I found yesterday what I need to add for tightening. You need to order below screw and rivet nut Fillister head screw M10 (alloy SB - edge) 34Nm 2EA : 07147162464 Blind rivet nut, flat headed 2EA : 51718065070 Last edited by Steve_Jr; 03-12-2016 at 08:00 PM.. |
03-17-2016, 09:16 AM | #33 | |
Rep 4,529
Great write up and photos. How much disassembly of engine bulkhead plastic trims and fittings was required to install stage 2 alloy brace ? Thanks, BP
Current '22 X3M LCI.. |
03-17-2016, 07:22 PM | #36 | |
Rep 234
below items must be moved to stage 2 .. It's my bad .. Cover, windsheild panel, Left : 51718059699 Cover, windsheild panel, Right : 64318059697 Engine hood sealing, Left : 51768058561 Engine hood sealing, Right : 51768058562 Expanding rivet 6EA : 51118174185 Last edited by Steve_Jr; 03-17-2016 at 07:27 PM.. |
03-17-2016, 07:27 PM | #37 |
Rep 234
05-09-2016, 05:55 AM | #38 | |
Rep 4,529
For stage 1 - What bolt torques for 3 x m10 bolts into top mounts ? Cheers, BP
07-09-2016, 10:30 AM | #40 |
Rep 234
If you want to tighten 3,4 into body, you need to drill your body what you wouldn't do that. So, I used rubber bushing to body side for absorbing shock from strut .. ^^
07-23-2016, 08:44 AM | #41 |
Rep 1,296
Hi
Thanks for this tutorial, I think I'm going to give it a try too. Was the replacement of the struts support with 31302284702 absolutely necessary? I can't see where this would be a problem to use the original F30 part? This seems to be the most annoying part to manage with the necessity to remove the shocks etc. if I can skip it I'll go ahead. Thanks!!
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
07-24-2016, 02:01 AM | #42 |
Rep 1,296
Got it now, required to bolt the alloy strut brace on.
I need to understand if I can change these without dismounting the entire wheel etc, first time for me.
08-16-2016, 06:43 AM | #43 |
Rep 80
I was quoted:
stage 1 : 212 euros stage 2 : 601 euros stage 3 : 995 euros Maybe i will make stage 1 and 2, because Engine hood sealing left and right are not available. Can you please tell us more about handling, how is it now, after installing the cfrp strut what is the difference? |
