07-20-2016, 07:14 AM | #25 |
Rep 263
@Jmdmc5teg06:
With HU Entry the 8,8" screen doesn't work. You need either new Radio Professional from 7/2014 on or Nav Business from 3/2014 on, both HU Entrynav. @catharsis: 609 is Nav Professional which uses a completely different HU (NBT or NBT Evo). You can't just VO code it if you have HU Entrynav. I have tried to VO code 606 (Business Nav) and even this doesn't work. |
07-20-2016, 07:30 AM | #26 |
Rep 2,046
TePee, nice write up. appreciate it. Too bad mine is a 2013.
07-22-2016, 11:12 AM | #27 | |
Rep 35
have you first-hand knowledge of what you posted above? just for the record my car is one of many with 606 business nav running on entrynav so I'm not 100% sure what you mean by "I have tried to code 606 and even this doesn't work" What I'm really interested in trying to figure out (as it would be a great coding 'coup' if possible) is whether after adding an 8.8 screen and VO coding to 609 to 'unlock' 609 features, whether it would then be possible to change HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display and the resolution value and thus change BACK to an 6.5. screen while retaining the 609 features :-) even just doing a comparison of all of the before and after .ncd files might provide some interesting insights into how to unlock 'professional' features on the entrynav box. |
07-22-2016, 01:24 PM | #28 |
Rep 263
I don't know all markets but in F30 series I'm not aware of Entrynav based Nav Prof /609. Maybe in other series like F45 or so, but then it won't be the same I guess. But you just have to check online parts catalog to make sure. Instead of read or hear something
I have new Radio Prof which uses also Entrynav HU but without nav. Coding to 8,8" CID was no problem. But when I was trying to VO code 606 nav, it didn't work and the HU even lost its CAFD file. So if you want to VO code 609 at Entrynav I can't imagine how it is supposed to work. But if you are sceptical, just try it. Then you will see and have your first hand knowledge |
08-18-2016, 05:47 AM | #29 |
Rep 2,152
hello sorry to ask but i have just bought a 64 plate 435d. it has Business Nav but i want to upgrade to the 8.8 screen. how do i find out if my car has the HU_Champ2 or HU_entrynav
08-20-2016, 12:58 AM | #31 |
Rep 380
Hi Guys ... Can some one help me here .. i am also trying to upgrade my 6.5 inch screen to 8.8 in 2015 f30 328xi base model without business or professional navigation... got the 8.8 inch screen with part number 65509292248 and did the below 2 coding changes .. but its not working
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display Is there any other coding changes i should do ? Or am I missing any hardware parts ? Regards, Kishore. |
08-20-2016, 08:00 AM | #32 | |
Rep 565
Here's the link for the older screen (see the "Superseded by" note) Last edited by MarkoSK; 08-20-2016 at 08:13 AM.. Reason: Fixed typo and link |
Halfb8d95.50 |
08-20-2016, 10:16 AM | #33 |
Rep 380
Thanks marko and everyone contributed to this thread ... I could successfully upgrade to 8.8 .... One thing I was missing earlier was that the display from my head unit was going through Bimmertech mmi HD unit to 8.8 and there is one toggle switch I should put to off for 8.8 to work.
Only problem I see now is the display brightness... Its dim and have blue tint ... My 6.5 display was so sharp bright and crisp ... Any reasons for this?
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
08-20-2016, 05:53 PM | #34 |
Rep 2,152
hello i want to give this upgrade a try but i have a few questions.
what is LCI and how do i know if i have LCI or not? my car is a 64 plate 435d 65509292248 is the part number on here. i have checked Ebay and here is a link to one. http://www.ebay.co.uk/itm/1621638321...%3AMEBIDX%3AIT when checking the pictures i can see the 9292248 as the part number but where is the 6550 part in front of it? |
08-22-2016, 08:24 PM | #36 | |
Rep 8
08-22-2016, 09:29 PM | #37 | |
Rep 380
One more hint to you ... whats the resolution you have set ? are u using 8.8_1280 by xxx as said in this forum ? reason i am asking is .. after watching few videos i felt very disappointed with this resolution ... so as a try i used 10.25_1600x600 resolution and it feels way better. trying to see if there is any temperature related FDL ... so brightness can be increased ... let me know if you come across any. |
09-19-2016, 05:16 PM | #38 | |
Rep 35
Coding 609 instead of 606 appears to have worked for me in terms of resetting the screen resolution to drive the 8.8 screen (model 9292248, so pre-LCI screens WILL work in LCI cars). However not all of the features so 'unlocked' appear to work. Specifically nothing which involves 'local storage' such as 'music collection' or 'voice memo' seems to work correctly. I'm not sure which other features are supposed to be '609-only' but I'm happy to check out anything anyone specifically wants investigated. |
09-20-2016, 05:30 PM | #39 | |
Rep 565
Pre-LCI screen (part no. 9292248): LCI screen (part no. 9387453): As you can see: - both screens work , - the pre-LCI screen has a blue tint whereas the LCI one doesn't EDIT: As a side note - my F34 with a 6.5" screen had the DISPLAY_SIZE_RESOLUTION value set to "10.25_1280x480" by default... and the 6.5" screen worked okay . The 8.8" screen also works okay without having to change this setting, so all you really need to change is EXBOX > DISPLAY_VARIANTE -> "breites_display" Last edited by MarkoSK; 09-23-2016 at 06:21 PM.. Reason: Added more text |
FeelinBlessed226.50 Krenforum4.50 |
09-20-2016, 08:26 PM | #41 | |
Rep 3,320
Don't give up there are plenty out there ! |
FeelinBlessed226.50 |
09-20-2016, 11:47 PM | #42 |
Rep 418
Is this the right lci screen model?
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
09-21-2016, 06:40 AM | #43 |
Rep 565
That's the LCI model (part no. 9387453). It worked in my car. What model and build date do you have?
09-21-2016, 10:01 AM | #44 |
Rep 418
I have the 17' 340i with the 6.5" screen
