05-03-2019, 05:10 PM | #23 |
Rep 790
probly not, if I did any autix, hpde, or track days I would probly jump on this. but for my daily driver and occassionaly running through the gears, I think the oem eLSD should hold up fine. for that price tho, lol...
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
TK335iMSPT299.00 Kaceyjames60.50 |
05-03-2019, 07:31 PM | #25 | |||
Rep 10,473
They are clearing out excess inventory on the 3.15 ratios as those cars are long out of production. Realoem does not list the LSD as working with the 328, but the original differential is the same part in the 335 and the 328 for the 3.15 final, which is the key. Quote:
See above. If it was produced on or before 6/2016 non-LCI and has an automatic transmission with a 3.15 final it would. All the F3x non-LCI Models used one of 4 differentials. 2.81 for the ActiveHybrid 3 3.15 for Automatics 3.23 for manuals 3.91 for some automatics You guys really need to learn how to use realoem. http://www.realoem.com/bmw/enUS/partxref?q=33107555607 |
05-03-2019, 09:19 PM | #27 |
Rep 681
So I think for the LSD to work with my f31, I need some parts beyond just the pumpkin. RealOEM shows my car has different half shafts and dust guard rings so I'd need those as well to mate the LSD to the rest of my drivetrain. Still very tempting to do though. There's also still the xdrive bit. Haven't seen any clear info on how adding an LSD plays with xdrive.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
05-03-2019, 09:25 PM | #28 | |
Rep 10,473
05-03-2019, 09:49 PM | #29 |
Rep 681
Its in my signature. 16 f31 328ix. I think my driveshaft might also be a problem based on the 335ix diagram I've been looking at. Hard to tell though as the realoem diagrams for my driveline aren't as detailed as the 335ix one. It could also very well be my ability to dig through realoem though!
2006 997.1 C4S |
05-03-2019, 10:08 PM | #30 |
Rep 943
Drives: F30 328i Msport
I'm scared of wasting 600$ if it doesnt fit for some reason my 328i. what about the half shafts? i read they are thicker on the 335i, but the mating surface might be the same going into the diff?
05-03-2019, 10:10 PM | #31 | |
Rep 553
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
05-03-2019, 10:27 PM | #32 | |
Rep 10,473
Realoem diagrams uses generic drawings so don't always use that as gospel. Actual part numbers and compatibility tell the tale. |
andino479.50 |
05-03-2019, 10:29 PM | #33 | ||
Rep 10,473
05-03-2019, 10:34 PM | #34 | |||
Rep 553
05-03-2019, 10:35 PM | #35 | |
Rep 10,473
http://www.realoem.com/bmw/enUS/part...#38;series=F30 33107603748 Rear-axle-drive I=3,15 From:07/01/2011To:-Weight:28.500 kg Supersedes 33107603749 (07/01/2011 — 11/20/2014) Part 33107603748 was found on the following F30 vehicles: 3' F30, 316d, Sedan, N47N, EUR, (3D91) : Rear-axle-drive 3' F30, 316d, Sedan, N47N, EUR, (3D92) : Rear-axle-drive 3' F30, 320iX, Sedan, N20, EUR, (3C31) : Rear-axle-drive 3' F30, 320iX, Sedan, N20, EUR, (3C32) : Rear-axle-drive 3' F30, 320iX, Sedan, N20, USA, (3C33) : Rear-axle-drive 3' F30, 320iX, Sedan, N20, EUR, (3C36) : Rear-axle-drive 3' F30, 320iX, Sedan, N20, USA, (3C37) : Rear-axle-drive 3' F30, 328i, Sedan, N20, EUR, (3A51) : Rear-axle-drive 3' F30, 328i, Sedan, N20, EUR, (3A52) : Rear-axle-drive 3' F30, 328i, Sedan, N20, USA, (3A53) : Rear-axle-drive 3' F30, 328i, Sedan, N20, USA, (3A53) : Rear-axle-drive 3' F30, 328i, Sedan, N20, USA, (3A53) : Rear-axle-drive 3' F30, 328i, Sedan, N20, EUR, (3A55) : Rear-axle-drive 3' F30, 328i, Sedan, N20, EUR, (3A56) : Rear-axle-drive 3' F30, 328i, Sedan, N20, USA, (3A57) : Rear-axle-drive 3' F30, 328i, Sedan, N20, USA, (3A57) : Rear-axle-drive 3' F30, 328i, Sedan, N20, USA, (3A57) : Rear-axle-drive 3' F30, 328i, Sedan, N26, EUR, (3C11) : Rear-axle-drive 3' F30, 328i, Sedan, N26, EUR, (3C11) : Rear-axle-drive 3' F30, 328i, Sedan, N26, EUR, (3C11) : Rear-axle-drive 3' F30, 328i, Sedan, N26, USA, (3C13) : Rear-axle-drive 3' F30, 328i, Sedan, N26, USA, (3C13) : Rear-axle-drive 3' F30, 328i, Sedan, N26, USA, (3C13) : Rear-axle-drive 3' F30, 328i, Sedan, N26, EUR, (3C15) : Rear-axle-drive 3' F30, 328i, Sedan, N26, EUR, (3C15) : Rear-axle-drive 3' F30, 328i, Sedan, N26, EUR, (3C15) : Rear-axle-drive 3' F30, 328i, Sedan, N26, USA, (3C17) : Rear-axle-drive 3' F30, 328i, Sedan, N26, USA, (3C17) : Rear-axle-drive 3' F30, 328i, Sedan, N26, USA, (3C17) : Rear-axle-drive 3' F30, 328iX, Sedan, N20, USA, (3B33) : Rear-axle-drive 3' F30, 328iX, Sedan, N20, USA, (3B33) : Rear-axle-drive 3' F30, 328iX, Sedan, N20, USA, (3B37) : Rear-axle-drive 3' F30, 328iX, Sedan, N20, USA, (3B37) : Rear-axle-drive 3' F30, 328iX, Sedan, N20, EUR, (3B51) : Rear-axle-drive 3' F30, 328iX, Sedan, N20, EUR, (3B51) : Rear-axle-drive 3' F30, 328iX, Sedan, N26, USA, (3B53) : Rear-axle-drive 3' F30, 328iX, Sedan, N26, USA, (3B53) : Rear-axle-drive 3' F30, 328iX, Sedan, N26, USA, (3B53) : Rear-axle-drive 3' F30, 328iX, Sedan, N26, USA, (3B57) : Rear-axle-drive 3' F30, 328iX, Sedan, N26, USA, (3B57) : Rear-axle-drive 3' F30, 328iX, Sedan, N26, USA, (3B57) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A91) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A91) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A91) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A92) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A92) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A92) : Rear-axle-drive 3' F30, 335i, Sedan, N55, USA, (3A93) : Rear-axle-drive 3' F30, 335i, Sedan, N55, USA, (3A93) : Rear-axle-drive 3' F30, 335i, Sedan, N55, USA, (3A93) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A95) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A95) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A95) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A96) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A96) : Rear-axle-drive 3' F30, 335i, Sedan, N55, EUR, (3A96) : Rear-axle-drive 3' F30, 335i, Sedan, N55, USA, (3A97) : Rear-axle-drive 3' F30, 335i, Sedan, N55, USA, (3A97) : Rear-axle-drive 3' F30, 335i, Sedan, N55, USA, (3A97) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, EUR, (3B91) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, EUR, (3B91) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, EUR, (3B91) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, USA, (3B93) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, USA, (3B93) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, USA, (3B93) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, USA, (3B97) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, USA, (3B97) : Rear-axle-drive 3' F30, 335iX, Sedan, N55, USA, (3B97) : Rear-axle-drive |
andino479.50 |
05-03-2019, 10:43 PM | #36 | |
Rep 891
No MPerformance LSD is offered with this final drive, unsurprisingly.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
IK6SPEED4499.00 |
05-03-2019, 10:51 PM | #37 | ||
Rep 10,473
Again, the key is knowing what is on your current F30/F31/F32/F33/F36. If it's 3.15, it will work If it's 2.81, 3.23 manual or a 3.91, this part will not. |
MacklinUSOB519.00 |
05-03-2019, 11:41 PM | #38 | |
Rep 681
2006 997.1 C4S |
05-03-2019, 11:43 PM | #39 | ||
Rep 10,473
05-03-2019, 11:45 PM | #40 |
Rep 681
2006 997.1 C4S |
05-03-2019, 11:47 PM | #41 | |
Rep 10,473
I've been wondering about that for the last hour as you stated you had a non-LCI but a 2016. The F31 non-LCI stopped production in 6/2015. By putting in your VIN, you have a 8H53 which is a USA F31 LCI. |
05-03-2019, 11:52 PM | #42 |
Rep 681
Ah gotcha. Mine seems like a weird limbo because I still have the n20 and ID4 NBT Evo. But yeah, I guess mine is actually LCI but with a 3.15 final drive still. That's my bad!
2006 997.1 C4S |
05-04-2019, 01:09 AM | #43 |
Rep 943
ordered from BMW of Monterey, cheaper than the other places at 505.80$+shipping.
TheJungatron363.00 |
05-04-2019, 10:44 AM | #44 |
Rep 10,473
