04-16-2014, 03:43 PM | #23 |
Rep 66
ok someone please walk me through this. Im using Windows 7 32bit.
1. I have EDIABAS install per the instructions. http://bmwcoders.com/forum/bmw-gt1-o...-software-328/ 2. I have ENET cable from One-Stop-Electronics 3. I changed change FSC.bat to "0x2D ox08" 4. I have North America Premium 2014-2 extracted on flash drive. What now? Do i just connect the eNet cable to the car and USB to the laptop? Any left to configure? |
FlorinQCK-2.50 |
04-16-2014, 04:32 PM | #24 | |
Rep 524
PrideRock870.00 FlorinQCK-2.50 |
04-16-2014, 04:36 PM | #25 | |
Rep 1,892
http://www.f30post.com/forums/showpo...6&postcount=22 Basic Steps: 1. Read the navi FSC using the swid_reader. 2. Disconnect your latptop from the car (it's no longer needed). 3. Decode the FSC code using the supplied b64dec tool. 4. Feed the decoded fsc code to fsc.exe along with the region (0x2d) and map sequence code (0x08 for NA Premium 2014-2). 5. This will output the "short" FSC code for your car. 6. Plug the USB stick with the maps into the glovebox USB port with the ignition on. 7. The car will say that an updated map is available. Click OK and it will prompt you to enter the short FSC via iDirve. 8. Enter the code output by the FSC generator and if everything is good, it will start loading. |
04-17-2014, 02:07 PM | #27 |
Rep 66
I'm running into a problem. When I hit "connect" on the SWID, I get an error. It will not connect. Is there additional configuration on EDIABAS other than the install?
I was reading on another forum and they said to change a few settings on the EDIABAS.ini? What settings are those? IP? Server? |
FlorinQCK-2.50 |
04-17-2014, 07:21 PM | #28 | |
Rep 524
I am also having issues. I can connect but does not read the VIN. Only settings that needed changing, if at all, was INTERFACE = ENET in Ediabas.ini Everything else at default should be ok according to other forums. this is my error message: Starting...F-serie... Ediabas version: 7.3.0 Ignition: = OKAY ------------------------------------ Trying... Reading CAS... System.Exception: SYS-0005: OBJECT FILE NOT FOUND CAS: VIN - SYS-0005: OBJECT FILE NOT FOUND Reading CIC... System.Exception: SYS-0005: OBJECT FILE NOT FOUND CIC: VIN - Last edited by hsk1610; 04-17-2014 at 07:36 PM.. Reason: additional info |
FlorinQCK-2.50 |
04-18-2014, 02:25 PM | #29 | |
Rep 93
EDIABAS folder and dropped it on the newer one. I only let it add new files and kept the newer files, do not overwrite files. I ran the program again, and it worked. |
FlorinQCK-2.50 |
04-18-2014, 04:10 PM | #30 | |
Rep 524
Thanks, from the BMW Standard Tool, also needed to install NCSEXPER. Also if you manually installed or copied api32.dll into your Windows directory, that should be removed as well. Finally got it to work. |
FlorinQCK-2.50 |
04-23-2014, 04:32 PM | #33 | ||
Rep 16
FlorinQCK-2.50 |
04-24-2014, 12:13 PM | #35 |
Rep 708
OK, I managed to get the fsc code out of car using E-Sys.
problem is I cannot use the other tools as I have 64bit system Could someone generate the code if I send the car fsc code to them? I have NBT and require Europe NEXT map. |
FlorinQCK-2.50 |
04-24-2014, 01:21 PM | #36 | |
Rep 16
Or download the new Version, capable of reading CIC and NBT: FSC Code Generator Last edited by Dr.Ho; 04-24-2014 at 04:43 PM.. |
FlorinQCK-2.50 |
05-05-2014, 10:30 PM | #37 |
Now in the dark side !
66
Rep 1,136
Does someone have a link to download EDIABAS ?
Been searching, and can't seem to find a viable one. Thanks in advance !
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
FlorinQCK-2.50 |
06-04-2014, 12:06 PM | #39 | |
Rep 5,262
the fsc looks weird and the decoder says it has no base64 data |
FlorinQCK-2.50 |
06-04-2014, 07:14 PM | #40 | |
Rep 1,985
Drives: 2020 G20 320i M Sport
http://www.motobit.com/util/base64-decoder-encoder.asp Use this website, load the .fsc file in there then convert and open a new text fiew and copy everything into one line and copy the new file over the old .fsc file.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
06-05-2014, 04:14 PM | #44 | |
Rep 1,892
That's the equivalent file that is read from the car using the reader program. |
