06-26-2020, 09:07 AM | #419 |
Rep 54
Well got the differnet model screen its works, but seems to be only half the screen.... when the boot up screen comes it is the whole screen. I have changed the two settings too
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display Any Suggestions? |
06-26-2020, 11:16 AM | #420 | |
Rep 256
06-26-2020, 11:47 AM | #421 |
Rep 54
06-26-2020, 01:57 PM | #422 |
Rep 256
06-29-2020, 07:00 PM | #424 | |
Rep 919
Drives: F30 328d Sport Line
Screen part number ending in 2626 is for nbt Evo iDrive-5. If you have nbt or nbt Evo iDrive-4 7453 is the screen you need (I have a pristine screen ending in 7453 for sale if you need one). |
07-18-2020, 02:22 PM | #425 |
Rep 2
Hello & Wow! These upgrades look great!
Looks like there may be another option to upgrade screens that is coming out soon... showbox.bio/ tutuapp.uno/ https://vidmate.cool/ http://www.businesswire.com/news/hom...Retrofit-Touch Last edited by KlausMikalson; 07-19-2020 at 12:12 AM.. |
07-27-2020, 03:36 PM | #426 |
Rep 380
I have a good screen ending in 7453 for sale. If interested pm me.
Thanks
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
10-14-2020, 05:14 AM | #427 |
Rep 58
Success story, with quick specs:
2016 F36, built 12.2015 - HU: NBT/Entrynav (No navigation, but extended bluetooth and calling, Magneti Marelli / 8791783) Original 6.5" display: 65509270393 Replacement 8.8" display: 65509387453 Only thing I needed to code was: HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display (from schmales) Resolution was set, as per default, to: HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 10.25_1280x480 Last edited by ckarv; 10-14-2020 at 06:10 AM.. |
jomigo6.00 |
10-14-2020, 06:43 AM | #428 | |
Rep 5
10-17-2020, 12:59 AM | #430 |
Rep 25
Hello,
I am new to this forum. I have a 2015 320i with a production date of 2015/04. I would like to upgrade to the 8.8" screen and can someone please tell me if I should get part number 65509387453 or 65509385202. Thanks in advance for your help! |
10-17-2020, 04:05 PM | #431 |
Rep 5
Hey all,
I just wanted to share my experience with the installation. Quick specs: 2016 F31, built 09.2015 HU: NBT/Entrynav with business navigation Original 6.5" display: 9322120 Replacement 8.8" display: 9387453 Hardware installation was very quick and easy. Coding part was a bit more tricky. I initially used Bimmercode with ENET cable to code: HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display (from schmales) HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 After coding, black screen. Tried to go back via the backup files and tried coding again. Got the screen up and running, but not full screen only one side I then took a quick crash course in E-SYS Hoked up my laptop with E-SYS and looked at the coding. Both codings was enabled when I looked through E-SYS. HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 I then coded all back to factory settings with 6.5" size and schmales_display through E-SYS. Turned everything on and black screen. Coded it again through E-SYS to 8.8" size and breites display. Everything worked liked supposed to and looks awesome So, my experience is Bimmercode didn't do the proper coding, why I don't know? Last edited by RFN; 10-17-2020 at 04:14 PM.. |
10-17-2020, 04:12 PM | #432 | |
Rep 5
10-20-2020, 10:52 PM | #433 |
Rep 25
Sorry for the newbie question. Does retrofitting a 8.8" screen to a car originally came with a 6.5" will cause any problems with the ConnectedDrive services? Thanks!
10-23-2020, 09:58 PM | #434 | |
Rep 380
Just think of it like this your headunit is the CPU and your screen is a monitor
makkuro1.50 |
10-28-2020, 02:22 PM | #435 |
Rep 32
Can I ask a question.
Some older screens are being sold with the cable. Some come with a cable that is split at the Head unit end into the video signal plug and power plug. On the screen side they are combined together into one plug. If I have a head-unit with the combined plug only, will the screen work? Thanks |
12-01-2020, 08:42 AM | #437 |
Rep 1,485
I have a super weird issue. My 228i 2015 model came with BMW LK CID 8.8 made by Kyocera, part number 938103902. I am looking to replace it as it had bubbling on the glass.
I bought one from ebay BMW LK CID 8.8 part number 938754702 which looks identical just has different part numbers. The new one says no signal when plugged in. I transferred the board over inside the unit, and it is just black display. Any ideas what to check next? |
12-01-2020, 10:55 AM | #438 | |
Rep 380
12-01-2020, 12:34 PM | #439 | |
Rep 1,485
the part that I bought was a ID5 from a 2017 2 series. I need an ID4 NBT EVO unit. Its a hardware issue due to voltage and apix and resolution. Swapping the board didnt fix it even though I hoped it would |
03-24-2021, 10:38 AM | #440 |
Karel
Rep 2
8.8 touch (0709339) + HU_NBT = NO SIGNAL ?
Hi gurus.
I have LCI F34 320i GT from 11/2016. It has 6,5" screen without navigation. I ordered LCI screen 9387453, but for me was sent even newer 0709339 which is touch. Other problem is that actually I do not understand, what is my headunit. Bimmercode shows HU_NBT. Is this same as HU_ENTRYNAV? Anyways, I installed it, coded with Bimmercode + Veepak these two famous lines... HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display ...and only thing I got was red "NO SIGNAL" message on new screen? Switched on/off/on - no change. So questions: 1. What is HU_NBT ? Is it different unit than HU_ENTRYNAV and is so shitty that cannot accept any better display? 2. Would LCI screen 9387453 work with that? 3. Or is it possible that this newer touch 8.8 display cannot work with that? (different voltage, protocol, etc maybe problem?) I switched back old 6.5" and restored old coding and old display works. One picture shows all options what bimmercode gives when I go into Headunit menu. Maybe someone can figure from this, what headunit I acutally have? One picture is the current 6.5" Two pics are new 8.8 backside. Thanks in advance. Last edited by Karelka; 03-24-2021 at 02:53 PM.. |
