08-31-2013, 12:52 PM | #4489 |
Rep 41,195
I know, and it is unfortunate, but given the nature of the software, and the powers that be, there is little that can be done to rectify that. It seems sooner or later, every thread at some point becomes an avenue for software requests.
08-31-2013, 07:14 PM | #4491 |
Rep 41,195
08-31-2013, 09:05 PM | #4492 |
Rep 453
I am getting an error message:
FEM_BODY [40] readCPS o.k. cafd_00000794-007_029_101 Fehler: File for "cafd_00000794-007_029_101" not found! Can anybody give me some advice please? Thanks!!! |
08-31-2013, 09:27 PM | #4493 | |
Rep 41,195
http://www.f30post.com/forums/showpo...postcount=1403
08-31-2013, 09:48 PM | #4494 | |
Rep 453
I am I-step f020-13-07-505 pszdata 50.2 |
08-31-2013, 09:54 PM | #4495 | |
Rep 41,195
PM sent.
09-01-2013, 07:17 AM | #4496 |
Rep 4
hi guys
I have been coding with success for some functions. is it possible to have a auto fog light coded? at night both the low beam and the fog light turn on together. I cannot find the function. Any advise? Many thanks. |
09-01-2013, 09:17 AM | #4497 |
Rep 28
Shawn, just joined. If you have the time to email links, I'm "rnoonan" at the Google email service. I will PM tomorrow assuming this post gets me cleared.
Anyone coding from a Mac? I saw there's a PDF for Mac tips, but just curious of anyone still active here is doing it. Any suggests for a currently active, legit cable seller? Or, if needed, a source for the connector? I can solder and build, but would rather buy. Thanks all for the great info. First BMW and so far thrilled, but would love to make many of the standard tweaks like ASS off by default. |
09-01-2013, 09:21 AM | #4498 | |
Rep 41,195
09-01-2013, 09:48 AM | #4499 |
Rep 88
Hi,
so, just wanted to check a couple of things. When I try and connect, in the connect selection the VIN is greyed out. Now it says No ZGW Available. Any ideas? |
09-01-2013, 09:53 AM | #4500 | |
Rep 41,195
Is the car engine running?
09-01-2013, 10:48 AM | #4501 |
Rep 88
Hi Shawn
Had to register the dll. Never had to before, always worked with the default VIN shown after installation. But found one of your posts regarding the same problem. Now in the connection its listing my vin at least. Wonder if this might make a difference when coding? Pete |
09-01-2013, 10:52 AM | #4502 | |
Rep 41,195
You wonder if what will make a difference when coding?
09-01-2013, 11:01 AM | #4503 | |
Rep 88
As for an error message, all I saw was No ZGW Availble, that was it. and the ZGW Search tool has never worked for me. I meant with the coding thing, here: It always listed a different VIN to my car. But still connected OK, just some of the things I have coded, dont seem to work properly, and I thought it might be something to do with the wrong VIN. guess not though. PEte |
09-01-2013, 11:04 AM | #4504 | |
Rep 41,195
If you get a coding error, let me know.
09-01-2013, 11:07 AM | #4505 |
Rep 88
Nope,
always showed a different VIN. I thought it was a hard coded VIN seeing as the Software is boot legged. Only after just registering the DLL's is it now showing the correct VIN. Must be the aliens |
09-02-2013, 08:38 AM | #4506 |
Rep 6
Hello shawnsheridan,
This is my first post on this forum and I'm highly interested in starting coding my 2013 F30 Could you tell me If I have an NBT? My F30 is from march 2013 and it is a belgian car. I have a pro nav and the advanced bleutooth options. I would really like to code the video player from usb. Thanks for your answer!! |
09-02-2013, 01:12 PM | #4507 | |
Rep 41,195
If you have E-Sys, it is very easy to know. The ECU will be either HU_CIC or HU_NBT, which is self explanatory. But, you can also easily tell, just by looking at the screen. This is a small picture comparison; however, the difference is immediately recognizable just from how the selection highlight differs:
09-02-2013, 01:54 PM | #4508 |
Rep 173
F30 Automatic Cruise Control initial following distance
On the F30 (2014 at least) you can code the ICM ECU, under '3000 Daten', option C_Abstandsstufe_init to Stufe_1 and your default ACC lead distance will be the minimum instead of the maximum.
I know there's already a known code for the F10 that does this but the F30 is just a little bit different. |
09-02-2013, 04:06 PM | #4509 |
Rep 1,044
Does anyone know what FZD is all about?
My car has started throwing airbag warning lights and codes. The dealer first re-programmed the car (giving me a nice fresh install to re-code only the my favorite changes!) and then said the FZD module is bad. I found an "FZD_07" module in the loaner -- but it look as boring as hell. Any ideas on why this thing is part of the airbag inoperable warning system?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
