09-08-2013, 08:23 PM | #4577 | |
Rep 173
09-08-2013, 08:24 PM | #4578 |
Rep 41,232
No. Your issues is your patch / token is not installed correctly. You have to replace the two java files with the patched versions, and you have to set E-Sys EST options to point to your .EST Token file.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 09-10-2013 at 07:14 AM.. |
09-08-2013, 09:07 PM | #4579 | |
Rep 28
Would prefer to track down the faulty config point, but this got me up and coding tonight |
09-09-2013, 12:32 PM | #4580 |
Rep 258
Where and how do I that?
09-09-2013, 02:10 PM | #4581 |
Rep 41,232
Edit FA as follows:
You must use Valid Date though.
09-09-2013, 04:15 PM | #4583 |
Rep 258
It codes into the system, but the functionality hasn't appeared in idrive. It makes me wonder if some FDL coding is needed on MY2014 cars.
At least 3-4 people have been able to code 6NS successfully just by altering the VO as per the instructions. Here's my VO as read from the ECU. I also tried adding Internet, which also codes across fine but doesn't appear in Idrive, although to be honest I don't know if this works just by adding it to the VO. |
09-09-2013, 05:08 PM | #4584 | |
Rep 1,892
Right click the HU_NBT CAFD in the SVT list, and select Code instead of Read Coding Data. |
09-09-2013, 07:56 PM | #4585 | |
Rep 49
09-09-2013, 09:11 PM | #4586 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
thanks shawn... i found out that one of those files was misspelled. i correct it and it works!
09-09-2013, 09:13 PM | #4587 |
Rep 1,309
Drives: YMB M3
odd question..maybe someone will be able to help me out..
One of my PDC sensors was hit by a rock or something and now my PDC doesnt work. the part is unavailable right now so i am wanting to see if there is a way to take that one sensor out of the system so that the rest of them will work. There are a ton of PDC settings in the REM module but i dont see anything that looks like it will do what i want. |
09-10-2013, 04:25 AM | #4589 |
Rep 41,232
PM sent.
09-10-2013, 07:11 AM | #4590 |
Rep 258
Yes, that what what I missed out, I now have it working. Thanks Frogman and thanks Shawn for helping a nub.
09-10-2013, 10:06 AM | #4591 |
Rep 74
I was trying to code 6NS to my 6NH. When I did the vo coding and then clicked Hu_entry cadf code, head unit went out black and it closed saying "no signal". Then I thought maybe I should change it to 6nk. Now the cadf completely disappeared under the hu_entry and my headunit keeps on restarting. Only BMW logo appears then it turns off. What should I do? Help me :'(
09-10-2013, 10:38 AM | #4592 | |
Rep 1,892
If you have HU_ENTRY or HU_CIC (with the combox), then you want to change 6NH to 6NK. |
09-10-2013, 10:39 AM | #4593 | |
Rep 1,985
Drives: 2020 G20 320i M Sport
Also, HU_ENTRY is not compatible with 6NS. You need HU_NBT for 6NS or HU_CIC for 6NK. If this does not work, you can always take it back to the dealer and pretend you don't know anything. They should be able to fix it by flashing the firmware back in. |
09-10-2013, 10:41 AM | #4595 | ||
Rep 74
09-10-2013, 10:47 AM | #4596 |
Rep 1,892
Here's the procedure (just change the references from FEM_BODY to HU_ENTRY): http://www.f30post.com/forums/showpo...postcount=3018 This post has a link to a .pdf with an alternate method to do this. http://www.f30post.com/forums/showpo...postcount=4153 |
09-10-2013, 12:27 PM | #4597 | |
Rep 74
09-10-2013, 02:12 PM | #4598 |
Rep 1,985
For weather, you need bmw live and therefore you need a combox. If you're on basic bluetooth and HU_ENTRY, you don't have the necessary hardware/options to enable it via coding.
