07-30-2012, 02:06 PM | #441 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
anyone know if this can be coded? I am feeling the same way. Wipers arent sensitive enough when raining. I live in SOFLA and it rains all the time. When its not a heavy downpour i find myself manually wiping the window a lot.
http://www.f30post.com/forums/showthread.php?t=718500 |
07-30-2012, 02:09 PM | #442 | |
Rep 343
No I do not have the adaptive headlights... They're auto leveling but don't move when I corner...
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
07-30-2012, 02:17 PM | #443 | |
Rep 145
Drives: F30 320ed
There are a couple of folders in FEM BODY that seem to be for the wipers... maybe have a search through there might be something. |
07-30-2012, 02:21 PM | #444 |
Rep 1,309
Drives: YMB M3
yeah its all the way up...just wish it had a few more clicks! lol
I will check the Fem Body module when i get home.. hopefully its something that can be coded. |
07-30-2012, 02:25 PM | #445 | |
Rep 145
Drives: F30 320ed
Mine is set to: F015disable, F020disable, F030disable, F045disable, F056disable, I001disable Thats the main folder and there are a few more underneath. Also there are 3 folders: EM_FEMODE_0x71_LA_ADAPTIVEHEADLIGHT_ACT EM_TRAMODE_0x71_LA_ADAPTIVEHEADLIGHT_ACT EM_FLAMODE_0x71_LA_ADAPTIVEHEADLIGHT_ACT Mine all nicht activ... If you get the chance that would be appreciated.. in the meantime i'll keep searching. |
07-30-2012, 02:27 PM | #446 |
Rep 1,309
Drives: YMB M3
sure thing.. i will play it with tonight once i get done with my chores!!
07-30-2012, 02:35 PM | #447 |
woof
84
Rep 1,233
I do believe that is the normal functionality. Part of the Adaptive lighting includes having the fogs/side lamps enable upon turning or reversing.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
07-30-2012, 02:57 PM | #448 | |
Rep 145
Drives: F30 320ed
Yes the fogs are working for cornering and reversing function they come on together. I wasnt sure about the benefits of this feature at first but have changed my mind, plus you can switch it off i theory by putting lights out of auto mode. |
07-30-2012, 05:58 PM | #449 |
Rep 135
07-31-2012, 02:02 AM | #450 |
Rep 411
I think i setup everything correctly but when I run zgw_search, nothing comes up. Well I got something to show once or twice in zgw_search but it wasn't consistent. Then I followed instructions up to the point where I launch e-sys, click connect, select f020.. but the radio button for vin is grayed out. It says "no zgw found."
Thoughts? I'm running windows 7 32 bit. Thanks. |
07-31-2012, 10:18 AM | #451 | |
Rep 1,892
1. Did you verify the EDIABAS.INI Interface setting is set to ENET? 2. If you have wifi on the computer, try disabling the adapter so that the only enabled network interface is the Ethernet adapter. Then try zgw_search again. If that doesn't do it, then we need screen shots. |
07-31-2012, 10:47 AM | #452 | |
Rep 41,205
07-31-2012, 11:03 AM | #453 | |
Rep 41,205
Also, make sure you are selecting F020 and not F020 direct as your target. Lastly, make sure that there is a "Dist" folder in each of the Chassis (F01/F10/F25) folders etc.: e.g. "C:\ESysData\psdzdata\mainseries\F010\F010_12_03_5 1 1\odx\dist" The folders should be empty, but they need to be there.
07-31-2012, 09:22 PM | #454 | |
Rep 43
Is it the 1st one under [Configuration] or further down the list under [Interface] or both? Cheers
F30 328i Luxury "Glacier Silver"
07-31-2012, 10:54 PM | #455 | |
Rep 1,892
Mine shows: [Configuration] Interface = ENET My EDIABAS.INI file does not have an [Interface] section. This .ini file is in the C:\EDIABAS\bin directory and is NOT the file that starts with _ (underscore). |
07-31-2012, 11:25 PM | #456 | |
Rep 28
what is the parameters you have set to activate the adaptive lights feature? TIA. |
08-01-2012, 12:11 AM | #457 | ||
Rep 145
Drives: F30 320ed
See my earlier post on that. |
08-01-2012, 12:19 AM | #458 | |
Rep 411
Thanks all! |
08-01-2012, 01:14 AM | #459 | |
Rep 43
08-01-2012, 08:05 AM | #460 |
Rep 69
Anyone know how to remove digital clock from BC? It's not needed since its on center screen. I would like to show miles to empty & digital speed (already coded) at same time on BC.
08-01-2012, 09:47 AM | #461 |
bimmaboy
Rep 27
Big shout out to ShawnSheridan for coding my F30! Disclaimer gone: Check!.. Folding Mirrors on fob: Check! Seatbelt warning gone: Check! DVD in motion: Check!!! Tire pressure: Check! Loving the changes. Thanks, again, Shawn! Anyone in the Houston area should drop him a note.
08-01-2012, 12:57 PM | #462 |
Rep 411
Question: Does it matter that in step 4 and the est path in step 10 doesn't match?
Step 4) Copy "est" folder from "\\E-sys 3.18.4\est" to "C:\ESysData\e-sys est" Step 10) Run "C:\EC-Apps\ESG\E-Sys\E-Sys.exe" (It will take E-Sys a while to write the log file) and Under Options, Settings: On the ODX Tab, set the ODX Rule Path to "C:\ESysData\Rules" On the EST Tab, set the Developer-Soft-Token EST Path to "C:\ESysData\est\Code Away.est" |
