BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Anyone tried these halogen -> Xenon+led aftermarket kit?
      06-23-2016, 09:50 AM   #463
jakk
Drives: F34 335
the leds are not so dotty in person, but that is there a little only.
the quality seems just as good as the oem halogens maybe it feels a bit better,
ive got a hid kit but even before the road lights up better with these.
either-way if its down to looks these look a 1000% better than stock halogen they look so 90s and really let the look of the car down.
these are much better and unless there are any other lights out there that are much better than these in a similar price range id go for these all day long over halogen.
      06-23-2016, 01:05 PM   #464
BrennanF30
BMWLad
BrennanF30's Avatar
Ireland
1471
Drives: 320D M Sport
BMW F30 M Sport  [0.00]
Just been told by the UK place selling these that their versions use a separate h7 bulb for high beam
Sorry to be a pain but have you any pics with the HIDs switched on bud?
      06-23-2016, 01:22 PM   #465
jakk
Drives: F34 335
I will upload some later if i remember when it gos dark later, yes that's right that's what we said about the h7 its your high and low beam together with a shutter that shows more light when main beam is needed
      06-23-2016, 01:51 PM   #466
BrennanF30
BMWLad
BrennanF30's Avatar
Ireland
1471
No they told me high and low beam use separate bulbs. So I assume the inner projector is the high beam, the outer one being the low beam. Yet they look identical to your headlights
      06-25-2016, 01:21 PM   #467
asics
Drives: 2012 328i
Hey has anyone noticed any reliability issues thus far?
I'm just about to pull the trigger on a pair of these with Cree 7th generation LEDs (since I can't seem to find the 6th gens anywhere). I think that's the last bit of paranoia I have left...
      06-27-2016, 10:57 AM   #468
jakk
Drives: F34 335
nothing yet would be good to hear from others that have had them more long term, but still 100% better than halogens, page 6 has some great pics of a white f30 like mine with them fitted with decent snaps taken.
      06-28-2016, 05:28 AM   #469
BrennanF30
BMWLad
BrennanF30's Avatar
Ireland
1471
Guys are the LED U's warm white or cool white?
Need to know because I'll need to try and match a set of HIDs to them.
5000k would be best suited to warm white
6000k would be best suited to cool white
      06-28-2016, 05:33 AM   #470
jakk
Drives: F34 335
My ones are a cool white so id say 6k defiantly in my opinion, 5k will be too much yellow
      06-28-2016, 12:24 PM   #471
RarScaryFrosty
Drives: 2013 328i xDrive
They're 5000k. 5k is pure white. 6000k would start to become slightly blue. Yellow lights you guys are thinking of are typically 3-4000k.
      06-28-2016, 01:30 PM   #472
jakk
Drives: F34 335
Well the specs I had on these said the drl were 6000k so on that I brought the 35w hid kit 6000k and it matches just fine.
      07-04-2016, 01:43 PM   #473
BrennanF30
BMWLad
BrennanF30's Avatar
Ireland
1471
Mate do you have a link to the HIDs you bought?
      07-04-2016, 02:35 PM   #474
jakk
Drives: F34 335
Mine did match really well but just already had a ballast fail I'm testing other options Il try and keep updated, is rather more reliability than this.
      11-06-2016, 06:38 PM   #475
mynameisname
mynameisname's Avatar
Drives: FBO F30 328i, Lexus LC500
Has anyone had to code these? I've gotten my second pair of these from protuninglab but they're throwing a DRL error code. During night time in auto setting they work fine but day time auto or off position only one side works correctly. Also in the auxiliary position only one DRL projector works. The company advertises no coding needed but I suspect these do need to be coded to work correctly. Does anyone have the correct coding information for these to work?
      11-17-2016, 01:11 PM   #476
mynameisname
Anyone?
      11-21-2016, 02:04 AM   #477
Diddler
Drives: 2013 F30 328i
I ordered mine from protuning labs and actually just installed them today. I got the HID ones WITH the canbus warning canceler and I've had no errors or flickering. They look awesome and the HIDs make a huge difference vs the stock halogens at night.
http://www.protuninglab.com/hidxe12bmwf31.html
      11-22-2016, 06:02 AM   #478
LTM_BMW
Drives: F30 320D 2013
For those that have installed these headlights. How smooth is the light from the “U” shaped day time running lights in person? Looking at the pics in this thread it seems as if you can see the individual LEDs behind the “U” shaped acrylics. I am hoping this is different in person.
      11-23-2016, 01:59 AM   #479
Diddler
It's definitely a bit dotty (won't be smooth like OEM). Like people said, it's a bit better than the pictures.
I'm not sure if this has happened to someone else, but one person has told me that at night (on auto), the lights look like they flicker and one headlight was brighter than the other. I think coding can get rid of the flicker but I'm not sure about the brightness thing.
      11-24-2016, 01:28 AM   #480
mynameisname
What coding would be needed? About to give up on my second pair of these and ordered OEM style
      11-25-2016, 04:50 PM   #481
Diddler
I think just the cold and hot starts for flickering.
EDIT: Actually no coding is needed - my lights don't flicker at all. I may need to adjust the passenger headlight up a bit.
      12-03-2016, 12:41 PM   #482
mynameisname
Kinda frustrated that even my second pair wasn't a plug-n-play working correctly. I'm going to return these and get OEM ones and code them in.
      12-06-2016, 07:03 PM   #483
Diddler
What was not plug-n-play about them?
      12-08-2016, 10:06 AM   #484
mynameisname
Well, they are plug-n-play by my pairs just seem to have connection issues. Here's a video of mine.
https://goo.gl/photos/KWXPKuq7fLtoMpq57
