07-27-2021, 08:58 PM | #463 | |
Rep 1,004
thanks |
07-27-2021, 09:45 PM | #464 |
Rep 16,200
You'd have to do a major reworking of the doors, as they wouldn't even fit into the holes. Experience working with sheet metal would be a must.
If you wanted to go all out this one is even better, if you can figure out how to fit it: https://usspeaker.com/faital%20pro%206pr110-1.htm Last edited by Billfitz; 07-27-2021 at 10:01 PM.. |
07-30-2021, 08:47 AM | #465 |
Rep 216
Billfitz wondering if you could help me understand how to set crossovers/filters. For the setup where we have a mid/tweeter in the door and woofers under the seats, do I set a Highpass filter for the mid/tweeters to the low end of the speakers published FS and a Lowpass filter for the high end of the woofer's FS? Or do I need to bracket both the min/max FS using both filters (i.e. band pass?).
The amp I just installed (Match UP 7/DSP) has a sound setup file that is shown in the pictures below; first is the front mid/tweeters and the second is the woofers. Looks like they have set both a Highpass and Lowpass for all speakers which I guess I understand if they either think the speakers perform best with those settings or perhaps can't handle frequencies outside those settings without damage. I was a bit surprised to see the front mid/tweeters confined to only 1000 Hz. Aren't tweeters supposed to handle up 20 mHz? There's also a gap between the woofer's Lowpass and the mid/tweeter Highpass that I'm thinking is just an error. |
07-30-2021, 11:07 AM | #466 |
Rep 16,200
You want to crossover from the under seats to the doors around 120Hz. Crossing higher than that will take some load off the mids, but you don't want to go too high or you'll lose directional information from the mids that the under seats can't deliver. It's normal to have a gap between the woofer low pass and midrange high pass, but it shouldn't be more than 15-20Hz.
Using a high pass on the under seats prevents cone over-excursion in the lows where they can't handle it. Where to place that depends on the woofer. With the OEM and 3rd party replacements with similar specs, which is almost all of them, 50Hz is prudent. With a low Fs long excursion driver, such as the Earthquake, 35Hz is appropriate. If it has a crossover between the mids and tweeters that should be set around 4kHz. There should be no lowpass on the tweeters. |
07-30-2021, 01:50 PM | #467 | |||
Rep 216
Thanks! |
07-30-2021, 02:03 PM | #469 |
Rep 216
Hahaha, got it! I must not understand the DSP display then, cause it looks like it's set to 1000 Hz, it must not be active. Thanks again for your help!
08-09-2021, 01:40 AM | #470 | |
Rep 45
I have Matchup 7 BMW and am on the stage to set up the crossover point from trunk sub to under-seat sub to mid-range. I replaced all the drivers with Audison kit along with some high quilty Morel tweeters and even using custom x-over between 4" mids and tweeters since from my understanding the factory wired 4" mids only has a high pass filter which means it will play all the way up to 20k. Tried multiple settings but still can't blending the trunk sub with the underseat sub well, I feel like the under-seat sub is too weak to bring the bass to the dash even I set high pass at 60hz for it. The other thing is I tried to set the cross point for mid-range and under-seat sub at 150hz, but still can't enjoy how it sounds, I will try to set low pass at 120 for the under-seat and leave the gap less than 20hz, coz I know normally the less bandwidth the better sound, right? I would say I really hate how BMW decided to use the 8" under-seat sub instead of the 6.5" door mount mid-bass, it also limited the upgrade option since you can't directly install the aftermarket 2way or 3way kit. Last edited by MrBigB; 08-09-2021 at 01:48 AM.. |
08-09-2021, 10:24 AM | #471 |
Rep 16,200
I'd cross to an Audison APBMW underseat at 60Hz. Getting the balance right is going to take a combination of dialing in the EQ and the levels. The main problem you probably have is that the Audison has very low sensitivity, so it needs a lot more power than the stock woofer to reach the same levels. You might find putting the OEM back in works better.
The stock 8 inch under seats work better than 6.5 inch in the doors because the doors as enclosures can't be tuned to deliver a good result below 100Hz. If I was to go all out with 6.5 inch Faital Pro in the doors I'd still run them only down to 100Hz, with Earthquake underseats handling the low end. Last edited by Billfitz; 08-09-2021 at 11:22 AM.. |
08-09-2021, 12:38 PM | #472 | |
Rep 45
08-09-2021, 01:17 PM | #473 |
Rep 16,200
Running the underseats to 200Hz isn't going to work well. If you've got the APBMW K4E mids I can understand why you don't like taking them lower than 150Hz. They're not well suited to mounting in a door, so they start rolling off at 250Hz, and the excursion capability is a quarter what it should be. It's not that all fours can't go comfortably to 120Hz, it's that this one can't.
08-09-2021, 01:57 PM | #474 | |
Rep 45
Btw, I leave the center channel off at the moment since I can't set it up properly w/o hurt the stage width, do you guys running the center channel or just mute it? |
08-09-2021, 02:19 PM | #475 |
Rep 16,200
I have yet to find a mid that specs out better than the OEM. They may be out there, but when it comes to getting the full set of Thiele-Small specs and SPL charts on third party replacement drivers it's 'Where's Waldo?' time. Most don't have them.
Edit: Researching another query I did come across a mid with full specs, the Audio Frog GB40. As is usually the case it's no better than stock in frequency response and sensitivity, almost identical in fact, so just swapping them in won't sound better or louder with the stock amp. They do have longer excursion capacity than stock, so if you have a more powerful amp they can go louder than stock. But at $549 a pair it's a steep price to pay for another 6dB. Last edited by Billfitz; 08-13-2021 at 11:54 AM.. |
08-09-2021, 04:16 PM | #476 |
Rep 45
Thanks for the input, I will cross the mids as high as I can and the under-seat as low as possible, and both with a 12dB/octave slope. It doesn't make sense to have the gap for me but hopefully, this will help the system sounds cleaner.
08-09-2021, 04:21 PM | #477 |
Rep 16,200
If you have the option for 18dB high pass on the mids use it. That reduces stress on them and allows them to be crossed over lower than with 12dB.
08-13-2021, 10:50 AM | #478 |
Great Teacher
1141
Rep 1,322
Drives: 06 e91 325ix
Billfitz they actually go up to 30db/oct slope and choice of xover type, Bessel, etc.
Reading above confirmed what I heard yesterday during tuning, sws are 140 or below and mid can go down to 80 but no authority except from 100 up… so that’s how mine are set now, mids at 110 with 30db xover, amd slight overlap with sws at 125 or 130, sws are hp at 30db at 29 hz.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
08-13-2021, 11:43 AM | #479 |
Rep 16,200
Very high slopes do result in maximum output capability above the crossover frequency, but that also reduce pass band overlap, which may not work as well as lower slope. Another way to approach it is with lower slopes and wider gaps, like low passing the subs at 100Hz while high passing the mids at 130Hz with 12dB slopes on each. The only way to know what works best in a particular installation is by trial and error.
08-13-2021, 11:51 AM | #480 |
Great Teacher
1141
Rep 1,322
Yep. They were messing up the imaging and pulling soundstage down when I tried it the traditional 12-18 db softer slope, and left a hole if didn’t have some intentional overlap because of the poor mid bass of sws and lower output of the 4.
It was fun to tune them!
08-13-2021, 11:58 AM | #481 |
Rep 16,200
The SWS doesn't have poor midbass, it's just less sensitive in the midbass than stock. You can address that by either boosting the EQ in the 80-100 range or cutting the EQ below that and increasing the gain. There's always at least two ways of getting a desired result.
08-13-2021, 12:03 PM | #482 | |
Great Teacher
1141
Rep 1,322
08-14-2021, 09:50 PM | #483 | |
Rep 45
08-23-2021, 09:56 PM | #484 |
Rep 216
Billfitz I'm using a Butterworth filter with a 12dB slope for my crossover of both the mid (@ 140hz) and the woofer speakers (@ 125hz). I read that using a Linkwitz-Reily filter using a 24dB slope is preferable over a Butterworth at 12db since its LR filter is flat over the crossover region vs a 3dB bump (phase issues?) using Butterworth. While I basically understand (as in very basic) why one would use a 12 vs 18 vs a 24db slope, and what the various filters are trying to achieve, but how do you determine what's best by looking at the speakers specifications? I did read BCAE Passive Crossover Slopes, but given my limited experience with this stuff, it's hard to know what would be better for my system. Later this week I'll try it, but I was wondering what your thoughts are on this for a car audio application, an SUV in my case if that matters.
Second question is about using the speaker's Fs to determine a good starting point for the crossover. I read something about a rule of thumb being 2 x Fs but that seems extreme. Also read that you should set it just beyond the point where the impedance curve peaks and starts stabilize/flatten in a frequency response graph. From what I can see it looks to be maybe 1.3 x Fs value from what I see in some graphs I've looked at for 4in speakers. Is this the correct way to approach this? Last edited by VertigoAtHome; 08-23-2021 at 10:32 PM.. |
