BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 New Feature Release *** OBD Unlock and OFFLINE Flasher ***
      04-26-2018, 09:22 AM   #485
prodogs
Drives: 2017 X5 40ei
Total Newbie here so be gentle.
Is there a good FAQ on logging which explains which tests to perform and how to interpret the data in the logs?
I just flashed stage 1 93 on my 2014 435ix and i have no idea what the heck i'm doing.
2017 X5 40ei M Sport
2014 - 328ix -
2014 435ix Coupe - totaled
2010 X5 M Sport - sold
      04-26-2018, 11:21 AM   #486
the dope steez
Drives: F30 335i M-Sport
Usually you do logs at WOT for as long as you're comfortable starting at about 2500 rpm. So get it to 2500 in any gear, then pin it.
Once you pull the log in you'll want to look at timing, generally speaking if it is advancing in a linear fashion throughout the rev range and relatively consistent across cylinders.
You'll want to look at your HPFP to make sure it's keeping up. Any prolonged dips under 1500 psi are not great.
Check out your boost as it compares to mass air pressure. If you are generating too much boost, the car will taper the throttle. If your car is reacting well to the map your MAP and boost should be running in lock-step (or mostly)
Keep an eye on your knock sensor. Intermittent low RPM knocks are ok, but frequent higher RPM knocks could mean poor quality fuel or need to change/re-gap your spark plugs.
Those are the main things. The most important thing is consistent timing and linear timing advance with no knocks (i.e. pre-detonation). Strong, consistent timing = good clean power.
Appreciate 6
      04-26-2018, 12:48 PM   #487
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Use https://datazap.me
Originally Posted by designatedposter View Post
thanks! no I haven't posted this there because that page is a mess full of burble videos and comments. those get the most attention so they float to the top of the heap and most technical discussions get buried immediately.
is there a way to trim logs for better viewing?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      04-26-2018, 03:03 PM   #488
prodogs
You da man!! - Thank you this helps a great deal
2014 - 328ix -
      04-26-2018, 03:54 PM   #489
ilyabarankevich
Drives: 16" M135I / White / Red
Can some one please help me. Im trying to set up this stupid burble thing and im having issues.
Here are my setting. Active sound is also disabled in diagnostics.
[IMG]Burble settings by ilyabarankevich, on Flickr[/IMG]
Can some one explaing to me the number system 1= lowest sound / 7= loudest sound?
Do you have to reflash everytime you change setting in the map?
      04-26-2018, 04:07 PM   #490
MTWO
Drives: M2
Its only common sense that something that says Aggression is most aggressive with a higher number than lower. How’s that so hard? When you change stuff there you have to reflash.
      04-26-2018, 04:47 PM   #491
ilyabarankevich
Thats what i though. The first time i put it at 5, it was quieter then oem. Then i tried the highest number and it went completely away... I have common sense.. lol I assumed the higher the louder but for some reason that wasn't working for me.
      04-26-2018, 07:17 PM   #492
designatedposter
Drives: m235i
Originally Posted by JaredG_F30 View Post
Turn on your throttle angle % and aceel pedal %. You'll see that the area that you've highlighed with the WG dudty cycle spikes coorelates with throttle angle % spikes with no change in accel pedal %. So bascially, with out any input from you, the throttle is momentarily spiking, whcih I would expect to cause the jerkiness/surging that you are feeling. I'm not sure what would cause this though. Did you share this on the bm2 facebook page?
here's a log in regards to the issue I explained above above surging in low rpm, low throttle input.
i don't know how to trim it, so focus on the very end where it goes from 0 to about 1800 rpm.
this only happens in comfort and eco mode, how ironic. very smooth in sport mode.
http://www.bootmod3.net/log?id=5ae1c0f6d10b433a1148f1c7
[IMG]undefined[/IMG]
Update evening: flashed back to stock, no issues at all. Flashed back to tune.......... Non problem anymore. My guess is throttle adaptations got reset. Thought? I'll be monitoring for next few days with more seat time
M235i rwd 6mt
      04-26-2018, 08:17 PM   #493
ilyabarankevich
Got everything figured out.. Thanks to the great support team at BM3.
      04-29-2018, 07:44 AM   #494
TO 335
Drives: EB 335xi
Originally Posted by F30_SixSpeed View Post
Stock PWG Turbo, FBO, 93 octane, V6
Best Pull: 383whp, 494trq
nice power 6speed!!!! was just looking over some early bm3 dyno's from last year seems from version 1 to 7 they have increased the TRQ almost extra 30-40 and power extra WHP10-15.
      04-30-2018, 06:54 AM   #495
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
Thanks man!! Yea the new versions are definitely smoother and more stout!
FYI BM3 Version 1 - I did 355whp & 420wtrq
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
      04-30-2018, 07:45 AM   #496
the dope steez
Correct me if I'm wrong but I believe V6 maps at this stage are the fastest? I feel like they've pulled back the aggressiveness on V7 (for PWG at least). I flashed back to V6 and with proper fuel the low end torque feels much stronger than on V7. I know they mentioned we shouldn't be able to feel it but I definitely do
bm3, bmw, bootmod3
