08-16-2020, 10:12 PM | #507 |
Rep 104
Not entirely but I can get it working if I'm careful...
What SEEMS to be happening in my case is that if the ethernet connection is plugged in when it boot, the RPi doesn't try to connect to WiFi on boot... so with the ENET-OBD connector plugged in, it never connects to my phone. But if I unplug the ethernet connection before I power it up, it will very quickly tether to my phone; after that I can plug it into the ENET cable and it will connect to the car and then the BM3 app will talk to the car without trouble. I'm sure there's some simple tweak to the Rpi config that would avoid this but I have no idea what it is! |
08-25-2020, 11:49 AM | #508 |
Rep 1,469
anyone else having problems downloading the latest agent firmware version on the web? It give me a 404 error on the drop box page.
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 Last edited by Insane435; 08-25-2020 at 12:15 PM.. |
08-25-2020, 12:22 PM | #509 |
Rep 104
Just an observation I had also - if you're in the testflight or beta releases with the integrated OBD agent on your mobile device, that version is incompatible with the agent firmware that is available for this solution so you'll need to go back to the current public release of the iOS or Android software to use the WiFi agent.
09-23-2020, 11:32 AM | #510 | |
Instagram: matte_f80_competition
127
Rep 219
this morning I downloaded the testflight version (because I gave up and wanted to switch to the new ethenet to lightning adapter method) and when I tried connecting with the DIY wifi agent again (because the ethenet to lightning adapter has not yet arrived), it worked! BTW I didn't unplug the ethernet cable from the OBDII port beforehand like you recommended.
18' M3 (F80) ZCP 6-Speed - IG: matte_f80_competition
Ind Frozen Dark Grey/M-Perf CF Pkg/MPE/KW CS 2-W/Girodisc+Carbotech/Vorsteiner VFF103 Track: Michelin Pilot Sport Cup 2 F: 265/35-19 R: 285/30-20 Street: Michelin PS4S F: 265/30-20 R: 285/30-20 |
zerodb10.50 |
09-28-2020, 07:27 AM | #511 |
Rep 932
New update released for the firmware and app. Works with the BM3_NET wifi network instead of hotspot on my iPhone. Directly connecting the ENET cable though is what I do also as its so damn simple LOL
09-28-2020, 07:25 PM | #517 |
Rep 932
09-28-2020, 10:37 PM | #518 |
Rep 643
Their instructions never mentioned allowing the browser, which was the missing link and now everything works as it should. Not to mention there was a sneaky update to the app 9/26 which could have been for bug fix
M235i rwd 6mt
10-26-2020, 02:00 PM | #519 |
Rep 643
i've been using the new wifi agent firmware with the wifi bm3_net and it works okay with the workarounds of allowing 'mobile data only' apps... however, has anyone found a better solution? this still seems a bit buggy with some hiccups in the app, and datalogs don't get uploaded until after i disconnect phone from the wifi network. not to mention it's a pain to go through the phone settings to enable this workaround.
in the past, i believe someone modified the wifi agent to allow bluetooth connection. is this still an option?
M235i rwd 6mt
06-08-2021, 10:37 AM | #520 |
Rep 1
The image does boot on an Rpi4 and I am able to connect wirelessly with my iPhone 12 Pro. However, the app keeps losing connection. The longest I was about to stay connected was about 70 seconds of logging. I'm not sure why this is and have not had a chance to try to dig through the error logs(if I can even find them.). Has anyone else had this issue?
06-08-2021, 11:00 AM | #521 | |
Rep 3,715
I just ended up going hardwire to my phone, and now I have no more issues! |
12-10-2021, 02:06 PM | #523 |
Rep 248
Drives: 1989 325i & 2014 335i
I'm working on building/installing an OBD Agent, but I want it to use the OBD plug for both data and power. I'll build the ENET cable like normal, but I'll have a second set of wires going to a transformer to step down from 12V to 5V. I plan to put a switch and fuse on the power into the transformer.
Any thoughts on this approach? |
07-21-2022, 05:41 AM | #524 |
Rep 1
08-16-2022, 02:53 PM | #525 | |
Rep 3,361
I would like to set mine up in a similar fashion to this |
08-18-2022, 06:26 AM | #526 |
Rep 248
I did not. I moved across country and had to focus on maintenance and now I don't have a garage space to tinker. I hope to mess with it again in the coming months, and will put a write-up on my build thread.
dmanb2b2134.00 |
