BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ▀▄ eas | DIY: LCI Taillight Upgrade for F30 3-Series
      03-30-2017, 03:32 PM   #45
atzebmw
Drives: Tesla Model 3
Originally Posted by Aarie View Post
Great DIY.
I purchased the BMW OEM harness for the F30 LCI tail light retrofit. The harness allows for the left and right inner turn signals to plug directly into the REM.
Can some provide the REM FDL coding that is required for these lights to work via the REM?
Thanks
The best way is to insert the HO-Word "HELC" to the VO and to code the REM with it.
      03-30-2017, 04:08 PM   #46
Aarie
Drives: M-Performance Edition
Thanks for the quick response.
I tried to add HO-Wort=HELC, but get an error when I calculate FP.
PSdZ Error "No FP could be generated from FA" (C002)
Not all elements of the FA were found in the FA2FP: HO-Word HELC (72)
Could my PSdZ files be too old?
Thanks
      03-30-2017, 04:21 PM   #47
atzebmw
Thanks
I think the software of your car is too old.
OK, so you have to change all values manually.
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r
REM_01 > LceOutputChannels 3061 > BFD_L_CCM = ccm_blinker_l
REM_01 > LceOutputChannels 3061 > BFD_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BFD_L_UE_SPG_SCHUTZ = dimmed
REM_01 > LceOutputChannels 3061 > BFD_R_CCM = ccm_blinker_r
REM_01 > LceOutputChannels 3061 > BFD_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BFD_R_UE_SPG_SCHUTZ = dimmed
REM_01 > LceOutputChannels 3061 > BL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BL_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_L_UE_SPG_SCHUTZ = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BL_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_R_UE_SPG_SCHUTZ = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default]
REM_01 > LceOutputChannels 3061 > FRA_H_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > NSL_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_L_UE_SPG_SCHUTZ = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_L_WARMUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_CCM = NEW_ccm_nsl_r
REM_01 > LceOutputChannels 3061 > NSL_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_UE_SPG_SCHUTZ = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_R_WARMUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > RFS_L_CCM = NEW_ccm_rfs_l
REM_01 > LceOutputChannels 3061 > SL_2_L_CCM = Fxx_ccm_sl_2_l
REM_01 > LceOutputChannels 3061 > SL_2_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_2_R_CCM = Fxx_ccm_sl_2_r
REM_01 > LceOutputChannels 3061 > SL_2_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_R_IS_LED = aktiv
      03-31-2017, 03:12 AM   #48
Aarie
Thank you "atzebmw". I updated all values manually and the inner indictor lights are working.
Great help!!!
      05-15-2017, 03:06 PM   #49
palomino05
Drives: 2013 328i sedan
Originally Posted by tom @ eas View Post
Originally Posted by F30_335 View Post
I have rear fog lamp button from factory.
I meant maybe if I have rear fog lamp, coding is different. Without coding, I have blinking in 3 place. Now only stop lamp blinking.
Just performed another install earlier this week with the coding steps as outlined above. No issues on this end.
What's the price on these installed ?
      06-23-2017, 02:36 AM   #50
Levanius
Levanius's Avatar
Spain
Drives: F30 20d M Pack
Should I disconnect positive/negative cable from battery??
      09-22-2017, 03:11 PM   #51
BeeEyez
Drives: 435i Dinan Stage 3
Coding
Coding is necessary in order to keep errors from appearing when new taillights are installed.
REM Module
REM -> BFD_L_IS_LED: aktiv / Werte=01
REM -> BFD_R_IS_LED: aktiv / Werte=01
REM -> FRA_H_L_KALTUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> FRA_H_L_WARMUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> FRA_H_R_KALTUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> FRA_H_R_WARMUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> FRA_H_R_IS_LED: aktiv / Werte=01
REM -> FRA_H_L_IS_LED: aktiv / Werte=01
REM -> NSL_L_KALTUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> NSL_R_KALTUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> NSL_L_WARMUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> NSL_R_WARMUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> RFS_R_KALTUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> RFS_L_KALTUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> RFS_R_WARMUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> RFS_L_WARMUEBERWACHUNG: nicht_aktiv / Werte=00
REM -> RFS_L_IS_LED: aktiv / Werte=01
REM -> RFS_R_IS_LED: aktiv / Werte=01
Install is complete. Please comment if this guide helped you or if any of the steps need a bit more detailed explanation.
Does this coding work the same for f32's? or is it different completely?
      09-22-2017, 03:27 PM   #52
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Adding HELC to your VO and coding REM will work for F32/F82. It's touched upon lightly in this thread: http://f80.bimmerpost.com/forums/sho....php?t=1404489
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      10-05-2017, 12:45 PM   #53
zaynn786
Drives: F30 XDrive 335d
Is the procedure the same if you use the original OEM BMW retrofit harness?
      10-05-2017, 12:46 PM   #54
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Install steps will be slightly different, coding is same.
      10-05-2017, 03:38 PM   #55
zaynn786
Tried retrofitting this and stupidly unplugged a module from the R.E.M and forgot to plug it back in. Shut the boot and now cannot open the boot. Think it was the A174*13B. Now I'm locked out the boot what do I do?
      10-05-2017, 03:42 PM   #56
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
This might help: http://f80.bimmerpost.com/forums/sho....php?t=1410407
      10-06-2017, 10:42 AM   #57
zaynn786
Glad I'm not the only one whose been locked out lol. In the UK I don't think we have the emergency release. Ended up taking the car to the dealer mid retrofitting and asked them to get it open somehow. See what solution they come up with.
      10-09-2017, 12:51 PM   #58
zaynn786
Dealers had to get in through rear seat lol, bummed mme with labour. Fitted lights but inner blinkers are not working. Do I need to VO code?
      10-09-2017, 12:53 PM   #59
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
No need to VO code for F30, just follow the steps outlined in the OP.
      12-09-2017, 08:42 AM   #60
FZainol
Drives: E90 320d
Hi i leave in Malaysia, interested with the LCI Tail light, do u have it in EU version as my blinker are not red.
PLease pm price. Many thanks
      12-11-2017, 11:52 AM   #61
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
We only offer US version (red).
      05-25-2018, 03:16 PM   #62
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
Quick question guys, just did this to my car but when I looked at:
There was only an option for voltage changes. It was at 11V or something. I left it as is, is this okay? Or was I supposed to adjust the Werte? That was at 85.
      06-11-2018, 08:49 AM   #63
320d lucky
Drives: F31
I want to raise the voltage of the LCI indicator, but I do not understand the code. Please give me guidance.
      06-11-2018, 09:32 AM   #64
atzebmw
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 100% or 13.7V
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 100% or 13.7V
      11-08-2018, 06:14 AM   #65
sphynx
Drives: BMW F31 2014
Hey atzebmw, I did the manual coding you said on my F31. Inner blinkers are working on lock/unlock and emergency perfectly. One issue is with the left blinker. After one blink it gets a failure on computer. The right is working fine.
      11-08-2018, 08:20 AM   #66
atzebmw
I just looked at the values from above and I think I have discovered a mistake.
and
have to set to nicht_aktiv.
In general, you can say that all values with KALTUEBERWACHUNG or WARMUEBERWACHUNG have to set to nicht_aktiv.
