05-24-2020, 07:05 AM | #45 |
Rep 2,370
Drives: E63 645Ci
By a popular demand I have added two additional rev counters to my ID7 theme. Now you can choose from 3 options: 5k, 5.5k and 7k rpm red line. Mega folder updated - download whichever you like and simply change its name to id7_btn_dial.png
05-24-2020, 09:36 AM | #46 | |
Rep 117
Matches the Diesel engines. Diesel4ever |
05-24-2020, 09:54 AM | #47 |
Rep 2,370
Drives: E63 645Ci
05-26-2020, 04:43 AM | #48 |
Rep 28
05-26-2020, 04:49 AM | #49 |
Rep 2,370
Drives: E63 645Ci
At the moment you cannot I'm afraid. These models were intended for a standalone app and I'm still working on them. If you wish to use these in stock dashboard you would need to modify layout.xml file and this gets completed rather quick.
05-27-2020, 01:18 AM | #50 |
Rep 28
I am talking about the standalone app. I am using it and its wonderful. I was wondering how we can replace the default car icon with the newer ones you are starting to provide. There will be a different apk for each model ? Thank you !
05-27-2020, 01:35 AM | #51 | |
Rep 2,370
Drives: E63 645Ci
You want to use E63 image instead of your E64, right? |
05-27-2020, 10:20 AM | #52 | |
Rep 28
I understand now. I thought we should add manually the new models and i wondered how we could do that. Of course i understand it is very time consuming. Actually I have an E64. Yes ,i put my name in the list ,but i now saw you released an e63 image so i thought i could use that until an e64 is released. Thank you so much for your effort Last edited by Kostisuk; 05-27-2020 at 10:35 AM.. |
05-29-2020, 04:14 PM | #53 | |
Rep 24
Can we use these splash for PX6? Someone has tested on PX6 devices? |
05-29-2020, 05:23 PM | #54 |
Rep 2,370
Drives: E63 645Ci
05-31-2020, 09:48 AM | #55 |
Rep 24
05-31-2020, 10:12 AM | #56 |
Rep 2,370
Drives: E63 645Ci
05-31-2020, 11:08 AM | #57 |
Rep 24
Visually, if bootanimation is working and not for splash => what will happen on screen?
05-31-2020, 12:07 PM | #58 |
Rep 2,370
Drives: E63 645Ci
05-31-2020, 12:17 PM | #59 | |
Rep 24
+) Splash = "BMW Connect Drive" text +) bootanimation = "Android" text Can you confirm ? Last edited by haibn92; 05-31-2020 at 02:26 PM.. |
05-31-2020, 12:45 PM | #60 | |
Rep 2,370
Drives: E63 645Ci
Boot animation - dynamic sequence / short animation. In your case "android" with animated colour change. So splash and boot animation are two completely different things. |
haibn921.50 |
06-01-2020, 03:58 PM | #61 |
Rep 24
Hi RedErik,
I take a look in my PX6 headunit to see if there's a partition block named 'splash' or 'logo'. And here what I found at "/dev/block/bootdevice/by-name/": View post on imgur.com So, would I rename bootanimation => boot and splash => logo to match with OEM files ? |
06-02-2020, 12:36 AM | #62 | |
Rep 2,370
Drives: E63 645Ci
06-02-2020, 01:34 AM | #63 | |
Rep 24
06-02-2020, 03:02 AM | #64 |
Rep 2,370
Drives: E63 645Ci
No, I don't, I might have a look later on today. But I'm almost certain that these are not the files you are look for. Bootanimation.zip is located in /system/media folder and splash.img is part of Android kernel so it's not a standalone file. The files you pointed out are most likely code - not image files.
06-02-2020, 03:30 AM | #65 | |
Rep 10
bootlogo and bootanimation on PX6-9.0
You risk to brick your screen. On PX6-9.0, it is quite "simple" to change the boot logo and bootanimation. No need to try to hack things out. Boot logo: - Create PNG image 1280x480 - Transform this image into bmp - Rename it to logo.bmp - Put the logo.bmp in usb OEM folder - Turn the device off - Wait 15 sec - Plug the usb in - Let the system start - Stop the system - Start again Bootanimation.zip on PX6, you will need to use adb as root from a computer. There are 4 steps to follow: STEP 1: create bootanimation.zip bootanimation.zip is a set of files as described here: https://android.googlesource.com/pla...tion/FORMAT.md One thing to know, in the desc.txt, the last txt line is empty : -- beginning of file -- 1280 480 25 p 1 0 part0 p 0 0 part1 -- end of file -- Step 2: enable adb WIFI. - connect the HU and computer in the same WIFI network - go in developers options: -> enable USBdebug. - install Terminal Emulator in your HU - run HU Terminal Emulator and enter following commands: > setprop persist.adb.tcp.port 5555 > setprop sys.rkadb.root 1 > reboot When the HU is rebooted: - launch Terminal Emulator in your HU > ifconfig wlan0 : to know your HU address in WIFI, remember this lan address !!! like for example 192.168.0.3 Then in your computer: > adb connect 192.168.x.x:5555 (fill in the remembered address) > adb root > adb disable-verity > adb reboot STEP 3: To have root access to your HU from your computer in terminal command in your computer: > adb devices (you should see your HU IP address listed, remember it) > adb connect 192.168.x.xxx:5555 (fill in the remembered address) > adb root > adb remount NOW, you have a temporary root access to your HU. Be carefull, big power comes with big responsibility. STEP 4: install bootanimation.zip Put the bootanimation.zip you want to install in the root of your USB. Computer terminal command: > adb shell cp /storage/usb_storage/bootanimation.zip /system/media > adb shell cp /storage/usb_storage/bootanimation.zip /data/local > adb shell chmod 644 /system/media/bootanimation.zip > adb shell chmod 644 /data/local/bootanimation.zip > adb shell chmod 755 /system/media > adb reboot You should see the animation now !
PX6 4-32 - Android 9
06-02-2020, 04:21 AM | #66 |
Rep 24
