08-15-2022, 12:56 PM | #685 |
Rep 5
Hi, I have a F30 2017, iDrive 6, Business navigation without the wireless charging package (no antenna), NBTevo_Y. Is full screen carplay activation possible and if it is, would that void my warranty with BMW? Thanks!
08-16-2022, 03:55 AM | #686 | |
Coding ECU's remotely
449
Rep 1,182
Send me your VIN and I can check. Any modification you make to a car under warranty can invalidate that warranty. If you remove the carplay activation before a dealer visit, then you'll be fine, otherwise they will pick it up when they plug in their diagnostic machine. |
08-16-2022, 12:05 PM | #687 | |
Rep 5
I do have the bigger screen in the car. How involved is the process of me removing the carplay activation? Thank you! Edit 1 - I can't send you a DM. |
08-16-2022, 12:34 PM | #688 | |
449
Rep 1,182
The larger screen indicates you have Pro Nav, not business Nav, which would have a smaller 6.5" screen. Regardless of all that, activating and de-activating is all done via a small application with a unique key that is tied to your VIN number. |
08-16-2022, 12:43 PM | #689 | |
Rep 5
08-16-2022, 02:52 PM | #690 | |
449
Rep 1,182
That said, I've never had an issue on my own car that was activated and under warranty. If you want a genuine FSC code for Carplay then they are about £300 |
08-17-2022, 02:10 PM | #691 | |
Rep 5
08-18-2022, 03:15 AM | #692 |
449
Rep 1,182
If a genine FSC code is used then it does not need to be deactivated before a dealer visit.
08-18-2022, 03:30 PM | #693 |
Rep 3,070
PM sent
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-19-2022, 05:44 AM | #695 |
449
Rep 1,182
08-25-2022, 02:56 AM | #697 |
Rep 79
I've made it! Apple Carplay finally activated on my car.
I want to thanks Wibbles who gave me avery indication and provide me all the nesessary for the operation. He was very helpful. Great! |
08-25-2022, 04:59 PM | #699 |
Rep 3,070
Yes, PM sent
J3OEF82.00 |
09-06-2022, 08:01 AM | #700 |
Rep 5
Head unit crashed
Hi, I'm driving a F33 420 with a NBT EVO ID4 headunit. Had this unit upgraded to Apple Carplay with wifi some time ago which worked absolutely brilliantly. Unitl mid-drive the whole thing seemd to crash, went black and then rebooted but with only a functional radio. It still connects to wifi and bluetooth but no Carplay menu and the default nav system also stopped working. The rest of the menu works fine. Connecting via USB and snap-in also does not work anymore.
Upon entering the car and before starting the engine, I now hear a clicking noise coming from behind the dash, like a blinker. Could be a malfunctioning solenoid? Any thoughts, anyone? |
09-06-2022, 08:39 AM | #701 |
Rep 540
Or perhaps it's the hard drive in the head unit. I would take the head unit out and try to make sure the noise is coming from that. If it is, it's highly likely to be a dead/dying hard drive.
You can replace the hard drive but I've never done it in an Evo unit, only normal NBT so I'm not sure if the process is much different or not. |
09-06-2022, 10:49 AM | #702 |
Rep 192
Shout out to Wibbles who set me up with Apple Car Play and showed me how to do it without asking for anything. What a top guy! Not many ppl will do what he does in this day and age.
09-06-2022, 05:41 PM | #703 |
Rep 4
hi every body
Any help with FSC codes update,please I have 2019 G30 imported from europ Old map europ evo Current Map north africa 2022 vin WBAJC91090B279724 THANX |
09-06-2022, 07:16 PM | #704 | |
Rep 41,224
https://f30.bimmerpost.com/forums/sh...&postcount=592
