12-14-2022, 01:54 AM | #705 |
Rep 3,070
For SLI you need coding and FSC in KAFAS2 or Emulator
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
12-14-2022, 11:19 AM | #706 |
Rep 105
12-14-2022, 11:40 AM | #707 |
Rep 537
did you fdl code in kombi and activate in hu
F / G Series - KOMBI Ecu If your vehicle has a HUD (Head-Up Display) do these. Just ignore if you don’t have a HUD. HUD_NPI_ENABLE = aktiv HUD_PIA_SPEED_LIM = aktiv HUD_SPEED_LIMIT_ENABLE = aktiv HUD_SLI_ENABLE = aktiv PIA_HUD_SLI = aktiv PIA_HUD_SLI_NPI = aktiv PIA_HUD_SLI_PORTIERUNG = aktiv PIA_HUD_VSLI = aktiv
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
scouse stelth36.50 |
12-15-2022, 12:56 PM | #708 | |
Rep 105
03-31-2024, 01:52 PM | #709 |
Rep 2
Can anyone help me please?
I had ordered this sli emulator https://a.aliexpress.com/_Ey4RGm9 Intalled and coded. In the dash have only 3 lines. From time to time, just a second when i start the engine shows the european circle with 3 lines and then the circle dissapear and remains just the 3 lines. This would made you think that is coded properly but not working. I think it’s coded correctly and works because when i drive, it shows the red line on the speedometer for every limit if i overspeed, but i does not show the speed limit in a circle, down on the dash. This is my issue and i can’t find an exaplanation for this. What you think? Is the module bad, or it still needs some extra coding? F30, 2017, 6WB, nbt_evo, latest maps |
