BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Finally added Speed Limit Info
      01-24-2016, 11:27 PM   #67
Jason954x
Jason954x's Avatar
123
Drives: 435i xDrive
Originally Posted by Gabreigns
Or if there is someone I could email about the same?
Contact
      02-05-2016, 06:00 AM   #68
beppeM3+123d
beppeM3+123d's Avatar
205
Drives: bmw m3 dct + 123d e81
Originally Posted by beppeM3+123d View Post
Hi jason i bought the same but i have doubt on the slave positioning? Can you tell me your in which position is the slave? My car is without kafas, but i get an error from fcw with acc that disappear. This is why i ask you info! Thanks a lot!
I made several test because checking with rheingold i got many errors on cas, kombi, Hu nbt due to coding done for this module.
Is not correct to code 8th for cars without chafes installed.
is necessary made FDL coding on kombi and NBT HU.
Hope it will help to avoid several stupid errors that also dealer can see.
      02-09-2016, 07:41 PM   #69
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
Originally Posted by cryptocar View Post
Do you have the pinout for the KOMBI or wherever we tap the power and CANBUS?
Did you ever get this installed & working?
      02-09-2016, 08:09 PM   #70
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
I've been so busy working on perfecting my new turbo and meth setup that I haven't even looked at it since I got my unit reprogrammed.
Even though I want the feature when I'm tuning my car to enter the 500-600HP range i don't wanna see or think about that lol.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      05-02-2016, 10:28 AM   #71
jimmyweng316
Drives: F30
Hello, i have the problem in showing SLI in HUD,
My car has emulator but no KAFAS
Can I get instructions on this as well please?
thanks~
      05-05-2016, 07:49 AM   #72
ColinDuff68
Drives: BMW X4 M40d
Originally Posted by Jason954x View Post
I used an emulator, it pulls the speed limit from the map/navi database it doesn't read the road signs. KAFAS is the camera that reads the road signs which I don't have in my car, I just have the regular FLA camera.
Sounds great can u email me. Thanks
      05-16-2016, 01:08 PM   #73
theblues
Drives: MY14 328xi - Sportline
Jason, is this something you can code or what is it exactly?
      05-16-2016, 01:24 PM   #74
F30MGM
F30MGM's Avatar
Drives: 2016 340i
please pm me!: )
      05-17-2016, 01:56 AM   #75
Jason954x
Jason954x's Avatar
123
Drives: 435i xDrive
It's a hardware plus coding
      05-17-2016, 11:49 AM   #76
theblues
Right on. Can you please tell me what hardware I need and coding to complete?
      05-17-2016, 12:12 PM   #77
Chicken_Joe
Chicken_Joe's Avatar
Drives: 2013 F30 335i M Sport. EB 6M
I wonder if I can add this to my 13 f30 system
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
      05-17-2016, 12:13 PM   #78
Chicken_Joe
Sounds awesome, can you post instruction?
Check your inbox
Please send me info on how I can do this as well.
      07-24-2016, 04:48 PM   #79
hghabri
Tunisia
Drives: 2013 f30 330d M paket white
Hi guys, I have prb need help !!
After updating my Navi map to latest version, the speed limit info (speed limit signs read by KAFAS radar) stopped shown any road signs in HUD and Instrument cluster...
Anything I can code to get it working again??
Note: everything is stock (HUD, KAFAS, Connected drive) nothing retrofitted.
      07-25-2016, 08:10 AM   #80
Jason954x
Jason954x's Avatar
123
Drives: 435i xDrive
Did you select in the setting?
      08-18-2016, 05:41 AM   #81
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: M4CPC // HP4 Comp.
Could anyone support me with a clear picture, on which harness the SLI emulator cables are spliced in? Jason sent me a pic already, but theres not clearly to see, which harness this means. Thank you.
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      08-20-2016, 07:20 AM   #82
wilbur_the_goose
Drives: 2018 330ix Gran Turismo
For what it's worth, I just returned from a week of work in the UK. Rented a Ford, which had this feature. I LOVED it!
The UK has speed cameras everywhere, the the last thing this American wanted was a UK speeding ticket (which really wasn't going to happen because I was too busy keeping left!)
      08-23-2016, 02:17 PM   #83
Val33
Drives: F31 330d Msport+ xdrive
Hi Guys, looking for some help please.
I am fitting the bmwretrofit SLI Emulator and have some problems.
I have VO coded 8TH into the FA and then coded HU_NBT and Kombi. I have speed limit option available in the Instrument Cluster section of iDrive and 'ticked'. Nothing is showing on the inst. cluster. I had expected to see a speed limit sign with dashes.
I checked in HU_NBT and under 3001-extbox.97 I have 'SPEEDLIMIT_INFO and it is active. In Kombi under 3008-PIA-Einheiten.10 I have Ki-pia-speed.limit, this was in-active, but I have changed to active and saved, I have double checked and it is still showing as active.
Have I missed something? What can I check? Its the same with or without the emulator fitted.
Car has pro-nav, no kafkas, no HUD.
Thanks in advance
Val
      08-24-2016, 10:09 AM   #84
Val33
Finally sorted it.
I was intact showing the three dashes '---' just had not realised as it did not show the red and white speed sign. Also, the emulator had been shipped with the jumper on switch 6 missing. Added the jumper and all is good
So thats my first coding, first VO coding, and first modification all in one!
      10-29-2016, 02:14 AM   #85
bimmerace
Drives: F30 335i xDrive M-Sport
Can you please pm me the info? Thanks!
      10-30-2016, 10:11 AM   #86
Dang3r
Schmollbraten
Dang3r's Avatar
I got the emulator also here at home and gonna install it within the next weeks. Where I have to look to check if the jumper is set before I encounter the same problems you've had? Thank you.
      10-31-2016, 07:23 PM   #87
F30MGM
F30MGM's Avatar
Drives: 2016 340i
Can i get DIY instructions too please???
Car List:
2000 328i E46 Steel Gray Metallic 5SPD MT- Sold
2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current
      11-12-2016, 11:10 AM   #88
Dang3r
Schmollbraten
Dang3r's Avatar
Today was the day, installed and coded and it worx
