04-30-2018, 07:43 PM | #68 |
Rep 168
Ok final question.....how in the heck did you guys get the signal/led wires into the 16pin connector? I just realized my wires refuse to go down and won't full seat in the connector as if they are being blocked
Edit: NVM got it! |
05-01-2018, 11:27 AM | #70 | |
Rep 168
My alarm is functioning now......everything but the siren. So just trying to track down why that's not working and then I should be set. |
05-03-2018, 10:41 PM | #72 | |
Rep 168
I have a signal wire running from the FZD. Even double checked the siren connections and all of the connections to the FZD. Recoded the CAFD files to a different set that also ended in 503 (my I-step). No change. Starting to run out of ideas other than a faulty signal wire or a bad siren |
05-04-2018, 04:23 AM | #73 | |
Rep 817
Drives: bmw M3 F80
your red led flashes all the time or after arming |
05-04-2018, 09:24 AM | #74 |
Rep 168
After arming. Functions as it should and the horn will honk if the alarm is set off.
So assuming that no issues with coding would prevent the siren from working but still allow the alarm to function as it should, it's got to be a siren/wiring issue. |
05-04-2018, 10:06 AM | #75 | |
Rep 817
Drives: bmw M3 F80
send me your CAFD file CAFD_00000A07_002_018_000.ncd |
sea_m2c82.00 |
05-04-2018, 11:16 AM | #76 | |
Rep 817
Drives: bmw M3 F80
FEM_01 > ClIntegration 3041 > CLI_ZS_RELAY_ASSEMBLED = nicht_aktiv [Default] FEM_01 > LceMaster 3060 > DWA_BLINKEN_ENABLE = aktiv FEM_01 > PfInternalMirror 3120 > PF_INMI_LIN_VAR = nicht_aktiv [Default] FEM_01 > RemoteControl 30D0 > RC_4_BUTTON_SPFN = nicht_aktiv [Default] FEM_01 > RemoteControl 30D0 > RC_DEFAULT_IDG_4TH_BUTTON_LONG = Wert_00 [Default] FEM_01 > RemoteControl 30D0 > RC_PANIC_ALARM = nicht_aktiv [Default] |
sea_m2c82.00 |
05-04-2018, 01:38 PM | #77 |
Rep 168
Hi David - thanks so much for your help. I PM'ed you with my CAFD file. I checked esys on the settings you listed and below are my results. 2 confirmed, 4 different.
FEM_01 > ClIntegration 3041 > CLI_ZS_RELAY_ASSEMBLED = nicht_aktiv [Default] (Confirmed) FEM_01 > LceMaster 3060 > DWA_BLINKEN_ENABLE = aktiv (Confirmed) FEM_01 > PfInternalMirror 3120 > PF_INMI_LIN_VAR = nicht_aktiv [Default] (Mine reads - ISP_k__EC_DWA_UGDO_US_Kompass) FEM_01 > RemoteControl 30D0 > RC_4_BUTTON_SPFN = nicht_aktiv [Default] (Mine reads - Aktiv) FEM_01 > RemoteControl 30D0 > RC_DEFAULT_IDG_4TH_BUTTON_LONG = Wert_00 [Default] (Mine reads - Wert_03) FEM_01 > RemoteControl 30D0 > RC_PANIC_ALARM = nicht_aktiv [Default] (Mine reads - Aktiv)
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
05-04-2018, 02:07 PM | #78 | |
Rep 817
Drives: bmw M3 F80
Put on my own |
sea_m2c82.00 |
05-04-2018, 02:13 PM | #79 | |
Rep 168
So I will need to change these all to Active = 01. I'll give that a shot! Thank you!
05-04-2018, 02:52 PM | #81 | |
Rep 168
That being said - check your back left wheel well first! There was no mounting point on the body for my car as shown in the DIY pictures. So I had to fabricate a metal mounting point. Pictures: https://ibb.co/cMhCDn https://ibb.co/gMfM67
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i Last edited by sea_m2c; 05-04-2018 at 03:35 PM.. |
05-04-2018, 04:33 PM | #82 |
Rep 21
Thanks, but with the bracket you made you realy didnt need the 3 series mount did you? couldnt you just have mounted the siren directly to your custom bracket? If you look up the part number for the 3 series mount on real oem it only fits the 3 series and 1 series... thats why I think on the 2 series the siren is mounted a different way on oem installed alarms. Or am I misundestanding your photos?
05-04-2018, 05:36 PM | #83 | |
Rep 168
I kept the mounting bracket on mine because it left room for the wires/plug, where if I would have mounted the siren directly to the mounting point I created, it would not have left enough room for the wires. Hope that makes sense! |
05-04-2018, 05:44 PM | #84 |
Rep 21
Ok, great thanks for the reply. I already have the 3 series mount as well beacuse the siren i bought from the scrap was mounted to the mount I am planning on doing the install tomorow just trying to get as mouch information I can before I start.
05-05-2018, 06:01 AM | #85 | |
Rep 21
The contact should look like this when the pins are seated correctly. https://ibb.co/er4AJn Last edited by sevenofnine; 05-05-2018 at 06:08 AM.. |
05-06-2018, 12:28 AM | #86 | |
Rep 168
Were you able to get yours working? |
05-06-2018, 02:50 AM | #87 |
Rep 21
Installed everything yesterday but have not yet made the connections inside the car for the siren. Doing that and the coding today. I mounted my siren on a different place beacuse there was nothing to mount it to on the location you mounted yours. How did you mount your bracket you made?
05-06-2018, 03:28 AM | #88 |
Rep 21
Just made the connection to the siren in the trunk and the siren is working. I have not coded the car yet but the alarm is working as it should. Before I connected the siren the led in the rear view mirror would blink fast when I armed the car for a couple of seconds and then it would start blinking normaly. Now when the siren is connected the led blinks normaly directly after arming. So if your led is blinking fast for a couple of seconds right after arming that could mean that there is no connection to the siren.
