08-12-2019, 07:37 AM | #68 |
Rep 153
That's true, I'm just tired of this retarded chinese products. I think EU could be a huge market for this kind of units.
08-12-2019, 07:41 AM | #69 |
Rep 79
08-12-2019, 08:36 AM | #70 |
Rep 1,048
Ok, thats exactly what i thought, no good EU support.
i also have already a snapdragon HU with built in LTE but have not used it. instead of i`m installing an Automotive grade Wireless hotspot, also used in buses like FlixBus i found two cool devices, one is the Teltonika RUT850 and the second one is the Mikrotik wAP LTE Kit (RBwAPR-2nD&11e-LTE / EU version ) I tested both of them, if someone is interested in them, i made a little review here (german). the additional benefit of this is that you can also connect your normal mobile phone and you still have internet for whatsap and navigation the whole time when doing a call. when doing thethering of your normal phone you loose internet functionality after some kilometers while calling. sincerely Chri. p.s.: Mikrotik does also have an US LTE Version Last edited by Kri; 08-12-2019 at 08:46 AM.. |
08-12-2019, 08:45 AM | #71 |
Rep 67
anybody brave enough to try this for rooting?
https://forum.xda-developers.com/sho...&postcount=143 i would like to recompile the eventcenter.apk to change some of those horrible default apps... Last edited by marakeh; 08-13-2019 at 01:53 AM.. |
08-13-2019, 03:06 PM | #72 |
Rep 44
I'v been advised to post here instead of a different thread i started, the answers without quote tags are from the original thread, answered by lethee himself, so bear with me as this may be a long list.
I've read through this thread, but I still have quite a few questions that I think others may find useful as well. I'm going to try to be as methodical as possible, so here goes. (The questions are in bold, I'll add responses in regular text to this post along the way). 1. What is the boot time for these headunits, and when does the boot start (when unlocking, or when starting the car)? 1. According to reviews I've seen, boot time is something like 15-30 seconds. But someone who owns an unit will know better. 2. How do these units hold up in cold humid weather? 3. How is the brightness compared to the original, especially during bright sunny days? 4. I know the new chips (qualcom) have good audio quality, but what about volume, the difference between Bluetooth and radio is very noticeable on the original radio, is it the same with this (i.e. Android part lower volume than iDrive radio)? 5. Are these devices rooted? 5. The devices are not rooted by default and it is quite hard to root them. Some people have succeeded on rooting their unit on the android 7.1/8 models but I haven't seen a 9.0 root yet. 6. Does anybody have a 1920x720 (or close to this) version, with a qualcom 8 core cpu, 4gb ram, 64gb rom and anti glare screen with good brightness? If so, where can I find it? 6. I have searched a lot and came to conclusion that there is no model with 1920x720 screen AND snapdragon. It's either 1280x480 screen + Snapdragon or better screen with PX6 7. Does sound from the android part, for example spotify, stop when accessing the iDrive part for for example vehicule info? 8. Is the dashboard (rpm , speed, fual level etc.) still as choppy as in the videos from the android 7 & 8 versions? 9. Can the buttons on the radio fascia still be used to add shortcuts like it does on the iDrive? 10. Which buttons on the controller & steering wheel don't work with the adroid unit, or do something weird? (like on the original radio, the steering wheel scroll can't skip songs over bluetooth) 11. Is there a difference between i.e. AVIN units and the aliexpress ones, even though they look the same? 11. No. The products are same, the difference between sellers is in after sales support. However you may be able to add some (costly) extras to your unit (built in carplay for example) with some sellers but not all. 12. For europeans, supplier ewaying seems to be a good option due to the german warehouse, can anybody confirm if their products are as good as the others? 12. See #11, I'm sure there's maybe 1-2 factories all units come from. Ewaying is the same products, but I have noticed they don't have the latest models available (at least for F20). 13. When adding the optional DAB+ dongle, can you somehow avoid having to add the external antenna (by splitting the regular antenna cable for example)? 14. Does it remember on startup, where it left off last time, if you had a specific app open, does it restart that app? 15. There are a few optional bits and pieces with these units, like the DAB+ dongle etc. Is there anything you really recommend getting? 16. Is there anything you think I really should know about these headunits? Thanks in advance! |
08-13-2019, 04:02 PM | #73 | |
Rep 159
HU_NBT > 3000_HMI > DISPLAY_SIZE_RESOLUTION = 10.25_1280x480 HU_NBT > 3001_EXBOX > DISPLAY_VARIANTE = breites_display I use a HUAWEI E8372 LTE/4G Wingle for Internet. It works like a WiFi Hotspot therefor it only needs power from USB. I never had a problem with it tbh, plus I can share my internet with passengers. |
08-13-2019, 04:36 PM | #74 |
Rep 159
https://aliexpress.com/item/33047984764.html
This unit's UI seems to be a little more updated. Like being able to search in Media App, unpair Bluetooth device and an actual updated Factory Settings. I dont have that on my PX6 Android 9.0... |
08-13-2019, 05:01 PM | #75 |
Z4 35is
60
Rep 270
Does anyone of the Android HU is compatible with HeadsupDisplay? Like for navigation?
2011 Z4 E89 35is 2016 435i GC m-sport
08-13-2019, 06:55 PM | #76 |
Rep 44
Depends on which navigation you use. If you intend on keeping the stock navigation, then yes, otherwise no. The android unit is a layer on top of idrive. It can't do the stuff idrive does, it just passes on the audio and displays the video on the screen. You can however retain the stock navigation by linking it in the android unit as the default navigation. Once you hit the navigation button it will send you to idrive and open up the nav.
08-14-2019, 09:04 AM | #77 |
Rep 22
Still unsure if I should go with an Android HU or a CarPlay box. How is the integration with the OEM microphone working for the Android 9 HUs? However, CarPlay with stock microphone still is my prefered scenario.
08-15-2019, 11:39 AM | #79 |
Rep 87
I'm looking forward for those that get their HD display version to make a review. I would really want a antiglare screen but I don't see this option for HD display unit. So I'm torn between 480p screen with antiglare layer or regular black HD display. Question for owners, how does screen auto brightness work? Does it compensate based on sensor values or? I've seen some hacks done with brightness in 7.1 unit thread.
08-15-2019, 02:19 PM | #80 |
Rep 67
got a new firmware:
PX6 4+32 upgrade file download link. https://drive.google.com/open?id=1j8...J0akAxFKBlnKNe Operation method: PX6 upgrade steps: 1. After downloading the file, please do not extract the file, copy the file directly to the U disk, and change the file name to "px6.zip". 2. The device is turned off (shutdown for at least 5 minutes), and the USB flash drive is inserted into the USB interface. 3, then boot, waiting for the system to detect the upgrade file. Waiting for the upgrade. 4. The upgrade is complete. -> update dialog is not trigged for me, so no update for me yet, im in contact with the seller.. |
08-15-2019, 03:39 PM | #81 | |
Rep 48
Btw where did you get your unit from? |
08-16-2019, 02:12 AM | #82 |
Rep 67
from aliexpress.
https://www.aliexpress.com/store/3090101 (manufacturer is ewaygps) tried update.zip, px6.zip, px6_format.zip. im currently waiting for a reply from the seller. |
08-16-2019, 03:59 AM | #83 | |
Rep 221
Drives: MINI Cooper, 2020 X1
08-16-2019, 04:16 AM | #84 | |
Rep 1,048
as they are very different i think there has to be some kind of configuration db where this is stored to. Chri |
08-16-2019, 04:25 AM | #85 |
Rep 221
oem\app\upgrade_name.txt
just like px3 |
08-16-2019, 05:02 AM | #86 | |
Rep 159
08-16-2019, 06:38 AM | #87 |
Rep 114
