01-25-2013, 06:48 PM | #67 |
Rep 487
I've had no problems since BMW replaced my windshield reservoir, although it hasn't been super cold recently (18F today). Supposed to be closer to 0 over the weekend, so I'll make an updated report next week.
01-28-2013, 08:21 PM | #68 | |
Rep 10
Good luck to everyone else... |
02-09-2013, 06:49 AM | #69 |
Rep 99
Looks indeed being an epidemic failure. I recently joined the club (surrounding temp around freezing point). Mine gives low level warning all the time now (though maximally filled with fluid protected until -20°C and correctly functioning). Clearly the low-level detection seems defect. Have to contact my local agent.
02-10-2013, 03:56 AM | #70 |
Rep 63
The sensor is most likely not faulty as such so replacing it with an identical part won't help, but it is susceptible to being tricked by a cleaning agent that is not conductive enough.
I had the exact same problem as everyone else in this thread, and the short-term solution is simply to change your cleaning fluid. Or mix your own using normal ("dirty") water and concentrated cleaning fluid. When I did that my warnings disappeared and have been gone since (even during very cold weather). The long-term solution is for BMW to replace the sensors, this is clearly a design fault. They need to design/source a new sensor.
Melbourne Red F31 328 M sport
02-19-2013, 09:46 AM | #71 |
Rep 369
My car's at the dealer now for this ongoing issue. The light was still on this morning even though the temp had risen to 41F. I'll report back what the dealer says. Anyone else with this issue had any luck?
02-19-2013, 11:50 AM | #73 |
Rep 4,321
so basically we have to replace with BMW specific fluid? That's got to violate some sort of antitrust law...
02-19-2013, 11:54 AM | #74 |
Rep 55
That's basically what they told me. Obviously there is a sensor issue (my previous E90 didn't have any issues with the exact same fluid), but its easier for them to tell you to use another fluid then it is to replace the sensor. I guess I'll just live with the warning (I really like Rain-X!)
02-19-2013, 02:45 PM | #75 | |
Rep 369
02-19-2013, 06:00 PM | #76 | |
Rep 2,101
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
02-19-2013, 08:10 PM | #77 |
Rep 487
My issue went away after service replaced the reservoir and sensor. No faulty warnings since, which leads me to believe it is a sensor fault. And we've had plenty of cold days since it was replaced.
12-20-2013, 11:41 AM | #78 |
Rep 371
So I took my car in today because the low washer fluid warning is back, just like last winter. The service advisor calls me to tell me the issue is my rain-x washer fluid I used. That is such bullshit. He said BMW's fix is to use "any" blue washer fluid.
He said the sensor is conductive and can't read rain-x fluid. I call major bullshit! I called cooperate BMW a filed a complaint about this. |
12-20-2013, 11:51 AM | #79 |
iX1 2022
35
Rep 333
Has anyone tried the salt trick yet? Adding a grain of salt to the container.
My tap water is soft and has a low conductivity which might be the reason for my earlier problems. Will try with salt as soon as the problem reappears. |
12-20-2013, 12:01 PM | #80 | |
Too much is never enough
655
Rep 3,079
The explanation makes perfect sense. But I do say it's BS that they didn't design it to work with a wide array of fluids. I would think it could be corrected with a recalibration provided the sensor is capable of generating enough current to traverse the Rain-X fluid... |
12-20-2013, 12:08 PM | #81 | |
Rep 371
BMW can't just use a simple level sensor they need to over complicate things. So a KIA can use rain-x fluid but I can't, oookkkkaaayyy. |
12-20-2013, 12:16 PM | #82 | |
655
Rep 3,079
It's probably not what's in the blue fluid, but rather what's in the Rain-X. The Rain-X has additional compounds that lower its conductivity. Or it uses a more purified water as its base. Either way, it has a lower conductivity so the sensor doesn't work... |
01-03-2014, 10:35 PM | #83 |
Rep 4,321
Confirm:cheap blue stuff from grocery works best.
Lol BMW!! RainX be damned...
01-04-2014, 12:02 AM | #84 |
Rep 596
I get this warning every day since I've put in washer fluid. I only use Rain-X, and after putting in a gallon, I would get this message. I've continued to use Rain-X and continued to get this message every morning. It was really annoying being told you're low on washer fluid, when in reality there's plenty in the reservoir. I didn't really care that much, as long as I had windshield washer fluid.
Interesting observations - I'm going to try a different brand, and see what happens.
2013 BMW 335i xDrive Sport Line
01-04-2014, 07:27 AM | #85 |
Rep 2,101
So last winter I had no problems with this issue, but anytime it's been below -5C or so I get this warning as of late. Still running the same Rain-X fluid as I was last winter. I'll bring it up at my next service and see if they can fix it.
02-10-2014, 08:49 AM | #86 |
Rep 116
Filled up with Rain X this weekend and now I have this issue. Sounds like the cheap fix is just to buy some blue stuff, huh?
'18 F82 M4 ZCP
02-10-2014, 10:25 AM | #87 |
655
Rep 3,079
02-14-2014, 06:41 PM | #88 |
Rep 2,101
This. Added a bit of the blue stuff and haven't had any warnings since.
