BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Strut Bar
      12-07-2017, 04:12 PM   #67
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
So I received my Turner Motorsport front strut brace today. Does anyone know what I should torque the strut bolts to? Also, those of you who have the TMS brace, did you adjust the length of the bar or leave it as received? I"m also assuming I should tighten the brace hardware (bolt with nylon lock nut). It comes very loose.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      12-07-2017, 05:30 PM   #68
JaredG_F30
JaredG_F30's Avatar
1106
Nevermind...I found it on newTIC.info. Strut tower bolts torque spec is 56 N-m (41.3 ft-lbs)
kevinjt151.50
      12-07-2017, 05:38 PM   #69
FaRKle!
30Nm + 90deg for M8 bolts, 56Nm + 90deg for M10, although I sure as heck didn't need 30Nm of torque to break the bolts loose from the factory (used my torque wrench)!
JaredG_F301106.00
      12-07-2017, 06:51 PM   #70
JaredG_F30
JaredG_F30's Avatar
1106
Cool! Thanks!!
      12-18-2017, 02:41 PM   #71
GOLDENDUSt86
Egypt
23
Drives: f30 320i 2016
Post Upper adn Lower front Ultraracing strut tower brace fr f30
Hi
I've an F30 320i
i've installed upper front Strut tower (Ultraracing)UR-TW2-3744
and I bought the lower front one UR-LA2-2543,, but the problem was that I have to remove the Underride protection (part number 31146850067)
Does any one has a way around this?? Maybe one had cut through the underride protection ?!!
Ah btw,,, the front upper strut tower brace really does a good job in holding up the front of the car,, I wish I can install the lower one without having to remove the shield,
Thx
      03-25-2018, 02:58 PM   #72
BMWILUVU
Drives: 340ix
Originally Posted by GOLDENDUSt86 View Post
Hi
I've an F30 320i
Thx
Couldn't you just punch two holes in the shield and just have the bar ride below the shield?
      03-25-2018, 03:12 PM   #73
tpliquid
Drives: f31 330i wagon
Hi
I've an F30 320i
Thx
Where did you order it from? I been trying to contact ultra racing but no luck
      03-25-2018, 03:25 PM   #74
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Hi
I've an F30 320i
Thx
eBay
      03-25-2018, 06:02 PM   #75
tpliquid
U have a link? I can't seem to find it.
      03-25-2018, 07:14 PM   #76
sspade
sspade's Avatar
Drives: F30
https://rover.ebay.com/rover/0/0/0?m...2F182901740162
      03-25-2018, 07:34 PM   #77
tpliquid
Originally Posted by sspade View Post
Looks like it's for a n20 motor. I have b48 so no working. Plus my strut mounts use different bolt pattern.
      03-27-2018, 09:10 PM   #78
BMWILUVU
Drives: 340ix
ultraracing.my/ecatalog/index.php/product/bmw-f-30-330-2016-front-tower-bar-front-strut-bar/
      04-25-2018, 10:31 AM   #79
GOLDENDUSt86
Egypt
23
I'm Egyptian ,, we have a store that buys them from abroad and sells them here , sorry mate but I don't know where u can get them , but I can tell u one thing ,, they're the most reliable/cheap braces you can get
      04-25-2018, 10:33 AM   #80
GOLDENDUSt86
Egypt
23
Yeah ,, actually I ordered the wrong one by mistake first then returned it and bought this one ,, but I think they all have the same bolt pattern,,
      04-25-2018, 10:40 AM   #81
GOLDENDUSt86
Egypt
23
Well ,, we've lifted it up,, took the shield off and when we were bolting in the brace we realized it won't let the shield back in,,
But we were tired to try where exactly it won't fit ,,
A friend of mine told me I should AutoCAD it and see where exactly it could be pinched , if any,,, I thought of contacting ultraracing
They shouldve put this into consideration
I've searched alot on the internet for a solution ,, found that some f30 thier underide shield is made of like fabric material ,, like the one that surrounds the wheels ,, so it could be pinched easily
But here in Egypt roads have allot of bumps and holes ,, so a metal under shield is a must
      04-25-2018, 05:12 PM   #82
GOLDENDUSt86
Egypt
23
Rear Lower F30 Ultraracing member BraceCode: UR-RL2-2545
here is a pic of the underbelly after installing the rear lower brace (Code: UR-RL2-2545),,, sorry the quality is so bad
taken by Oneplus5t, my old iPhone6s was much better
If you can see the front lower shield ,, and the new rear lower brace
      04-25-2018, 05:16 PM   #83
GOLDENDUSt86
Egypt
23
another one
Code: UR-RL2-2545
      04-25-2018, 05:23 PM   #84
GOLDENDUSt86
Egypt
23
front lower member brace ultraracing Code: UR-LA2-2543 cannot install
here is the picture of the front lower one,,, see there is no under shield here
BMW F-30 330 (2016) FRONT MEMBER BRACE / FRONT LOWER BAR
Front Member Brace / Front Lower Bar
Code: UR-LA2-2543
      04-26-2018, 01:24 AM   #85
Lancelot
France
577
Drives: 2017 m550i
How’s handling with these? Did you notice a difference?
Thanks!
      04-26-2018, 10:13 AM   #86
BMWILUVU
Drives: 340ix
Code: UR-LA2-2543
The rear lower brace does not look like it will do very much. It looks to be trying to prevent scissoring of the end of the rear axle carrier but there is already a solid strut nearby already doing that. The front brace and the strut bar look solid. How does it feel with all the bracing?
      04-28-2018, 08:17 AM   #87
GOLDENDUSt86
Egypt
23
Thanks!
Yeah,, I've installed the front first,,, the car felt it got hold of itself together better,, I've noticed this when I go slowly over speed bumps,, when the car goes off the speed bumps with the front wheels,, I felt asif the inertia if pulling the front down as u fall off the bump,, but now it's held solid,,
The back one also did a good in corners ,, even ones beloow 60km
      04-28-2018, 08:22 AM   #88
GOLDENDUSt86
Egypt
23
I didn't know what could the rear one do so I asked the mechanic when we were installing it، ،،he told me that the flexing in the rear Axel is higher than the flexing in the chassis, so it should stop the rear Axel flex ,, I don't push my car to it's limits , but it felt a little more solid in curves
