08-09-2015, 07:45 AM | #9110 |
Rep 4
Hi Shawnsheridan,
Could you please send me link for latest E-Sys software, datafiles and where can i download latest version of ncdcafdtool i only find v0.3.0 Cheers & thank you so much Emilio |
08-09-2015, 08:34 AM | #9111 |
Rep 41,207
PM sent.
08-09-2015, 03:37 PM | #9113 |
Rep 109
I found the cause of the issue I am having with coding mirror auto fold/unfold feature in FEM_Body. It is caused by incorrect mapping in the group 3110 PfExternalMirrorMaster. I believe starting from the version 14 of FEM_BODY cafd BMW introduced a new function control parameter and inserted it between original 1st byte and 2nd byte data in that group. Since this is a one bit parameter the insertion we see in new CAFD file includes two data elements -- PfExternalMirrorMaster_1_1_1 for this new single-bit parameter and UNBELEGT for rest 7-bit unsigned space in new 2nd byte. Therefore the rest of data in 3110 group are pushed by one byte. However, as shown in the attachment, the mapping mechanism in the E-Sys Launcher I am using didn't really realize the situation. Although it successfully detected the new parameter, it thought the new item was just a replacement for ASP_BORDSTEINAUTOMATIK_DELTA instead of a newly inserted byte. So all data starting from 3rd byte in 3110 group are incorrectly presented in new CAFD off by one byte That is why we couldn't find ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN. It is also why I located the wrong data when I tried to fix it yesterday.
So it looks like the mapping algorithm in E-Sys Launcher needs some improvement. It seems that now it just looks at the parameter position and its size (i.e. bit mask) without considering other factors such as default value and options. This may be still an easy fix as right now BMW seems to just insert new items into the existing data without totally reordering them and/or regrouping them. Things will turn really ugly once they start doing it.... Update: It turns out that the extra bit they added is not a new function parameter at all. It is actually ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN. It was originally the MSB bit of first byte in the group 3110 PfMirrorMaster. Now it has been moved by 1bit so it become the LSB bit of newsly inserted 2nd byte. So the mapping mechanism failed to detect this change as well. It somehow believes that the MSB bit of 1st byte is still ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN while in fact this bit is now unsigned and PfExternalMirrorMaster_1_1_1 is new ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN... So it looks like that BMW hates the feature of mirror auto folding/unfolding so much that they deliberately shifted ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN by 1 bit and consequently changed the locations of almost all data in PfMirrorMaster just to screw the coding of adding this feature Not sure why.... Maybe they got too many bad mirror motors to replace? Here is the workaround for coding the feature in F020-15-07-50X using E-Sys Launcher Premium V2.2.1 Build 63: For activating ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN: PfExternalMirrorMaster_1_1_1 -> aktiv For activating ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN: PfExternalMirrorMaster_8_8_1 -> aktiv Hopefully the fix will be short-lived as the better mapping mechanism can be most likely expected in next version of E-Sys Launcher Premium. Last edited by valley_nomad; 08-10-2015 at 06:37 AM.. |
08-11-2015, 03:49 PM | #9114 |
yunior
18
Rep 23
Drives: 2018 430i Xdiver (f36)
Finally get my f10 code:
So far: Mirror windows with fob. Trunk with fob Auto stop start , last setting Eco pro ,default on start Angel eyes 100% with headlights on Auto unlock V.i.m
08-12-2015, 05:11 AM | #9115 |
Rep 15
Drives: BMW 640d F13
Shawn, is it possible to change the codes of the drivers and passengers seat on my F13?
What I mean is using the memory and other seat switches with the door closed, engine on and no time limit? Thanks Last edited by mikestje; 08-12-2015 at 07:14 AM.. |
08-12-2015, 10:24 AM | #9116 |
Rep 473
I have a service appointment this Friday for my 40k service.
So far I VO coded Enhanced Bluetooth and FDL coded Flashing brake lights, weather radio, TPS Temp Sensors,DVD in motion, Windows and mirrors open/close via KeyFOB, etc Will any of these (especially the VO coding) be an issue when I bring it in? DO I need to code back to stock? Thanks in advance.
I has no mods
08-12-2015, 10:30 AM | #9117 |
Rep 98
There is some code to the passenger mirror down to engage reverse gear?
I checked the select button. Does not work. This problem is in a F20 from a friend. But I think there should be some code. Thank you
08-12-2015, 10:56 AM | #9118 | |
Rep 41,207
08-12-2015, 11:17 AM | #9119 | |
Rep 473
Ok. Honestly I wasn't aware you could VO code WITHOUT writing your modifications to the car. Basically I followed a similar guide to this: http://codingf10.com/how-to-edit-vo-...by-step-guide/ Changed 6na to 6ns> wrote to car, the VO coded the ECU. I guess I have to change it back to 6na and code the ECU.
I has no mods
08-12-2015, 11:19 AM | #9120 | |
Rep 41,207
You do not need to worry about recoding it. Just make sure proper FA is in VCM.
08-12-2015, 11:30 AM | #9121 | |
Rep 473
Will do. Thanks.
I has no mods
08-12-2015, 02:09 PM | #9122 |
Rep 41,207
Sorry, but I have no idea on this.
08-13-2015, 07:15 PM | #9124 |
Rep 41,207
PM sent.
08-13-2015, 07:49 PM | #9125 | |
Rep 197
Good find. had the same issue with Launcher Pro. any thoughts TokenMaster |
08-13-2015, 08:18 PM | #9126 |
Rep 41,207
2016 Navigation Map Updates
2016 Navigation Map Updates are starting to be released.
Available now are the following 2016 Maps: North America PREMIUM 2016-1 (CIC Systems) North America NEXT 2016-1 (NBT Systems) North America ROUTE 2016-1 (ENTRYNAV Systems) A VIN Specific 2016 Map FSC Coded is needed to install a new map. If you want to update, and need both FSC Code and Map, I have an excellent source. PM me for details.
08-14-2015, 01:45 PM | #9127 | ||
Rep 1,232
08-14-2015, 11:10 PM | #9128 | |
Rep 109
in 3110 PfExtrernalMirrorMaster: PfExternalMirrorMaster_1_1_1 -> aktiv PfExternalMirrorMaster_8_8_1 -> aktiv in 3053 PwMaster: KOMFORTSCHLIESSUNG_FB -> aktiv KOMFORT_SCHLIESSEN werte=00 |
08-15-2015, 08:04 AM | #9129 | ||
Rep 1,232
