01-20-2018, 07:48 PM | #90 | |
Rep 742
Looks like only some folders are getting the dates changed (my documents, appdata/local, etc but not appdata/local/temp, c:/programdata, etc).
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-20-2018, 07:58 PM | #91 |
Rep 35
Is there a way to FDL code using this? I'm able to run e-sys after using the script but unable to FDL code without the freetoken.est java error window
01-21-2018, 07:56 AM | #93 |
Rep 4
should this date hack program work on windows vista? i desperately need essays to work one last time, as car is going back this week and need to code out my 8.8 inch screen
01-21-2018, 08:58 AM | #94 |
Rep 509
This issue was easy to fix. It was literally just a syntax error in the script. I’ll post my edits to the script when I get back to my computer.
I am still getting the FreeToken.est error when I try to FDL code... but I think this may be because the e-sys and launcher need to be reinstalled. |
01-21-2018, 09:46 AM | #95 |
Rep 274
01-21-2018, 09:57 AM | #96 | |
Rep 509
Launcher and e-sys were working perfectly with each other until the token expired. BTW, this is how I fixed the syntax error win 10 users keep getting... in the .bat replace this: Code:
if not %PDcr% == %CFGcr% ( Code:
set v = %PDcr% set y = %CFGcr% if v == y ( |
01-21-2018, 10:00 AM | #97 |
Rep 274
I'm working on an updated version of the script. I discovered a bug in 32-bit OS support in V1.5.0 that might also explain the syntax error some users reported. For some reason I can't replicate that error, so I'm relying on feedback... I've also changed the quick self-check on the results so that it is no longer dependent on the Modified Date of RearmLauncher.cfg.
More to come... |
01-21-2018, 10:20 AM | #98 | |
Rep 274
Thanks, but there is a flaw in your logic. You've deleted the 'not' out of the equation, meaning that E-sys will start only if the script DIDN'T work correctly... |
01-21-2018, 11:20 AM | #99 |
Rep 274
Updated version
And here it is: version 1.5.4! I fixed a bug for 32-bit OS support, changed self-test to no longer be dependent on RearmLauncher.cfg Modified date, and also did some other minor changes to the script. I'm anxious to hear whether the 'syntax error' some people were getting is gone now.....
Cheers, ---------- Tony Twoclicks |
01-21-2018, 11:25 AM | #100 |
Rep 274
01-21-2018, 12:42 PM | #101 | |
Rep 509
The correct version is: Code:
set v = %PDcr% set y = %CFGcr% if not v == y ( Here is what I did, 1. uninstall e-sys and launcher 2. delete the BMW and TokenMaster folders from the ProgramData folder 3. delete the 2nd TokenMaster folder from C:\Users\*your_user_name*\AppData\Local 4. change the date and then run your script. 5. re-install e-sys 6. re-install Launcher Last edited by Celestion; 01-21-2018 at 01:01 PM.. |
01-21-2018, 12:44 PM | #102 |
Rep 58
Thank you, thank you, thank you!!!!!!!
Tony.... I L O V E Y O U The thing is, I'm going to sell the car tomorrow and hand it in to the dealer. So i where just going to restore some coding that I've done, no big deal. I tried to start E-sys as usual and it's not working.... WTF...! So... I let loose my "google-fu" and I found some threads that basically saying I'm f****d. I started to get nervous... I did some more google-fu and found this thread. JACKPOT Tony... if you where here, I would kiss you! TONY |
01-21-2018, 12:54 PM | #103 | |
Rep 41,229
There is zero reason to restore coding just because car is being sold or traded in at dealer, but if you insist on doing so, E-Sys launcher is not even needed. Reset Coding by VO Coding ECU's direct with E-Sys (no Launcher).
01-21-2018, 01:09 PM | #105 | |
Rep 58
I did not think about that. The only thing I restored was the "speed limiter removal" for the rear camera. Due to it requires to be manually turned off every time the car has been in reverse. Everything else was left "as is" |
01-21-2018, 01:13 PM | #106 | |
Rep 41,229
01-21-2018, 04:12 PM | #107 |
Christmas Poo
1182
Rep 1,244
Thanks...maybe I'll get an email back...someday.
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
01-21-2018, 04:22 PM | #108 |
Rep 274
mikkenoone27.00 |
01-21-2018, 05:04 PM | #109 | ||
Rep 274
Step 3 is already taken care of by my script, as well as for the Tokenmaster-folder in C:\ProgramData. My gut tells me that it's probably step 1 that made it work for you in the end, but who knows... In testing, I never had to reinstall E-sys or the Launcher. Just adjusting the clock and running the script was enough to reset everything. Last edited by Tony Twoclicks; 01-21-2018 at 05:18 PM.. Reason: added another line |
01-21-2018, 05:25 PM | #110 |
Rep 33
Dear Tony Twoclicks,
Thank you for your hack! I am able to get past the date manipulation error but when coding I get an error regarding the generated token. Specifically, the error says it has encountered an error while processing the EST file. Details say: "EstCmException: Condition Not Correct. General Error". I am using E-sys 3.27.1 and launcher 2.7.1.135. I set the date to September 1 2017. Any idea what could be causing this? |
clock, date, esys, launcher, premium |
