02-13-2020, 03:57 PM | #89 | |
No 55mph
1623
Rep 8,479
02-13-2020, 04:33 PM | #90 |
Rep 3,052
Drives: 2019 M2 Competition
Whats interesting is their option 2 (that you have shown) looks like one solid aluminium pipe, where the description reads like OEM (plastic) pipe cut and fit with the metal adapter end.
Just interesting.. metal seems the way to go here.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
1QuikWS61623.00 |
02-13-2020, 04:38 PM | #91 | |
No 55mph
1623
Rep 8,479
Option 1: Is the custom aluminum section and t-bolt clamp only. You will need to cut your OEM inlet and clamp it to our section. Instructions and t-bolt clamp included. Option 2: One piece complete aluminum pipe
BMW DIY Guy3118.50 |
02-13-2020, 04:43 PM | #92 |
Rep 5,410
Website can be confusing. The original PT Inlet was just the metal end near the turbo that got rid of the constriction point. But it meant cutting a stock plastic inlet pipe to use the other half of the stock pipe connected by a sleeve with clamps. Photo shows the full metal PT Inlet that I got from Kies Motorsports who installed it for me.
BMW DIY Guy3118.50 oma3710194.50 |
02-13-2020, 04:53 PM | #93 |
Rep 3,052
Actually Kies just needs to update their description of the option 2.. I shot Bryan off a message. 8)
02-14-2020, 02:08 PM | #94 |
Rep 3,052
Ordered... lol.. didnt plan on it, but will be fodder for yet another DIY video.
02-14-2020, 03:34 PM | #95 |
No 55mph
1623
Rep 8,479
Ha! Knew u would
02-14-2020, 03:42 PM | #96 |
Rep 3,052
well buying something else for the family and got it for about $300 less than planned.. which sorta left 300 "extra".. and well.. yeah, so that happened.
02-15-2020, 09:09 AM | #97 | |
Rep 3,715
Did you get much additional noise from the Turbosmart plumb back model? |
02-15-2020, 10:08 AM | #98 |
No 55mph
1623
Rep 8,479
The Plumb Back version operates as OEM and redirects all the boost back into the system - so shouldn't be any more noise than stock
ZM22839.50 |
02-15-2020, 10:38 AM | #99 | ||
Rep 5,410
Kinda cool to get some feedback that it's working. If you step right back on the gas the power is instantly there because the Turbosmart is only bleeding off the slight excess. It's not draining off all of the boost. Don't think that I've ever heard it in Comfort Mode. A whippoorwill makes a two syllable sound. The Plumb Back model just makes the sound of the second syllable. It's pretty quiet on the car but I distinctly hear it under the circumstances that I mentioned. Listen here: |
ZM22839.50 alohasurftoad3132.00 |
02-15-2020, 10:44 AM | #100 |
Rep 3,715
Thanks for the feedback guys.
I like the idea of the whole unit replacement vs the GFB DV+. Just wanted to make sure it wasn’t going to be annoying. |
02-18-2020, 12:20 PM | #101 |
Rep 1,282
Ok so here are some logs before the turbosmart bov and intake inlet pipe.
http://www.bootmod3.net/log?id=5e4694e8d10b432feef14c48 http://www.bootmod3.net/log?id=5e46db99c090c6419c25d67b After install. http://www.bootmod3.net/log?id=5e4c1d06d10b431a6386e9f8 http://www.bootmod3.net/log?id=5e4c1d66d10b431a6386e9fc http://www.bootmod3.net/log?id=5e4c1e0dd10b431a6386ea04
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
02-18-2020, 12:33 PM | #102 | |
Rep 3,052
02-18-2020, 12:40 PM | #103 |
Rep 1,282
Honestly, I dont notice a difference. I was hoping the logs would show something.
02-18-2020, 12:42 PM | #104 |
1306
Rep 3,554
Results are inconclusive. Like I reported back earlier. Unless you can dyno back to back or make track runs back to back you wont see anything. Right now its a waste of money. The data just doesnt support it. I think the guy who seen something was at higher elevation on a more restrictive setup.. not an f30.
2017 m240i xDrive 10.67@132.32mph w/bm3
oma3710194.50 |
03-08-2020, 10:55 AM | #105 |
Rep 3,052
Well my inlet install was the right thing to do regardless.. my OEM pipe had two broken flanges and was nowhere near secure.
I also got the BOV installed though it isnt easy.. the change in shape makes the infamous top bolt even harder to access. Its doable, just not a lot of fun. Nice to have them both done though, especially the inlet.
03-08-2020, 12:57 PM | #106 | |
Rep 1,115
05-21-2020, 05:13 PM | #107 |
Rep 7,633
I am bumping this thread because i am wondering:
1. Has anyone tried the VRSF inlet option where you cut your stock inlet and fit to this? https://x-ph.com/vrsf-high-flow-upgr...2-f22-f20-f21/ 2. Has anyone tried the MST inlet? https://www.mst-performance.com/products/bw-mk3352v2 3. Has anyone figured out why some people's MAF maxes at 41.4 and others goes to 45+? I have seen no pattern. |
05-21-2020, 05:41 PM | #108 | |
Rep 3,052
05-21-2020, 05:59 PM | #109 | |
Rep 7,633
https://f30.bimmerpost.com/forums/sh....php?t=1716605 |
05-21-2020, 08:05 PM | #110 | |
F36 GC
143
Rep 259
