BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 N55 PURE stage 2 turbo dyno results
      04-24-2015, 01:59 AM   #89
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
Originally Posted by CJ2 View Post
Automatic transmission. No fueling system modifications. Just methanol injection for fuel supplementation. This dyno was done on my daily driven fuel: E59.
well, its just my luck they built an E85 station right down the street from me so E59 is what? 11 gls of E85 and 4.8 of 93?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      04-24-2015, 10:20 AM   #90
CJ2
Drives: 2019 F90 M5
E59 (100 octane) is where I landed after reviewing several logs. You'll want to look for timing pull of more than 3 degrees in any single gear. If you see a timing drop of more than 3 degrees, you don't have enough octane to run your current boost settings. With that said, E59 might be a good starting point. At E59, if your trims are maxed out, you might need to back it off a bit due to HPFP limitations.
Here's an E85 mix calculator http://www.intercepteft.com/calc.html (see octane results from blending two fuels). I downloaded one to my phone for easy access when pulling up to the station.
      04-24-2015, 10:23 AM   #91
BimmerFan
Drives: 2021 M550i
10gal of E85 + 5gal 93 octane = E60. I like to round stuff off
2021 M550i
BMS Pedal tuner
JB4
      04-24-2015, 10:25 AM   #92
CJ2
Drives: 2019 F90 M5
I can't help but be meticulous. Probably drives people around me crazy.
      04-25-2015, 12:51 PM   #93
BimmerFan
Drives: 2021 M550i
I hear you. Nothing wrong with that. I wish I could run more Ethanol. I am limited to E30 on my EWG platform .
2021 M550i
BMS Pedal tuner
JB4
      04-29-2015, 08:20 PM   #94
obriennathaniel
Lol yea the even numbers make it easier 😂
      05-08-2015, 01:22 PM   #95
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Dude, I just want to let you know ahead of time that after your big snail is installed and dailed in, I am going to stalk you till we meet...um, am serious
Good luck trying to catch me : but ill be at eurocharged Thursday, if I decide to let them install it. Waiting on an estimate to see if its worth the money cuz I can easily do it myself lol. Otherwise ill prolly install it Thursday and then bring it to them Friday or Saturday.
How much time were you quoted for the install?
SOLD: 2012 335i Mineral Gray
      05-12-2015, 11:58 AM   #96
CJ2
Drives: 2019 F90 M5
E59.3
      05-12-2015, 04:55 PM   #97
obriennathaniel
10 hours I think? But we worked out a deal.
      05-19-2015, 12:16 AM   #98
e46m3to335i
e46m3to335i's Avatar
Drives: 2015 F80 M3
Originally Posted by Jera_Jakerz View Post
2-3 weeks?! I should be getting mine soon too then?
Where are you located at in Germany?
-Nick
      05-21-2015, 11:55 AM   #99
GSR Technik
GSR Technik's Avatar
Drives: F13 M6 | E92 M3 | '15 Mustang
We are officially working on an ECU flash tune specifically for the Pure Turbo upgrades with the idea that you can run JB4 on top of to control ethanol mix fuel scaling and meth injection. Our goal is to test it all together to make sure it works as a package.
Nick...
      05-21-2015, 01:55 PM   #100
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Nick...
Very nice to hear. Intrested in how that will progress!
      11-07-2015, 11:44 PM   #101
n54pete
n54pete's Avatar
Drives: e82
Originally Posted by wakebord99 View Post
Do we know how much HP/Tq the X-Drive + AT setup can handle before we start breaking stuff?
I'ld imagine AWD + 500 Ft Lbs + No Tq limitation = 0-60 in the 3 second range, and 10 second 1/4 miles...
am curious as well, 8ZF xdrive here also
      03-01-2016, 01:56 PM   #102
kang60317
Drives: 2013 335i coupe
Did you get a backend flash? or is it just iso map w/ n20 sensor??
I am getting pure stage 2 turbo on my 2013 335i and my car is not supported by cobb ap. What tune are you using w/ pure 2 turbos??
thanks
      03-08-2016, 08:29 PM   #103
Chicken_Joe
Chicken_Joe's Avatar
Drives: 2013 F30 335i M Sport. EB 6M
Originally Posted by auf Deutsch
Originally Posted by FC4 View Post
Wow...very nice. Shows how severely turbo-limited these cars are stock when you can gain upwards of 250 RWHP with even a mild turbo.
Sentiment like this among different trim-levels always boggles my mind...
Yeah well, head over to the F80 post. God forbid you draw comparisons between the F3x and F8x. It's blasphemous to mention them in same universe, let alone the same thread.
It's cool to see the N55 perform at such a high level.
Being pretty new to the BMW scene this makes me excited. After doing a lot of reading and comparing between the N54 and the N55 I was a bit upset when I found out that my n55 car was not going to be able to make n54 numbers with such ease. With that being said I feel like the n55 is less problematic. I hope they can figure out a way into the ECUs and make these engines scream. BMW has always been the king, IMO when it comes to high performance L6 engines. I would hate to see the potential drop due to epa regs.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
      03-12-2016, 05:55 AM   #104
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
I am not sure we are going to see a proper flash for the F-series, but the tuning that exists now and the PURE Stage2, will give any N54 a run for its money
Mike
      03-20-2016, 05:51 PM   #105
Bowser330
Drives: i3 REX
+1 pure turbo f30 335xi is a poor man's GTR. Weight is nearly the same, dynojet dynos from the same specialty-z dyno have very similar curve profiles.
It would be really cool if it could 0-60 in sub 3 like the gtr. 2014 335i's have launch control right? Do xi's?
F30 335xi
Pure stage 2
Downpipe
Chargepipe
Methanol or fuel pump upgrade
Upgraded axles
ZF8 TCU flash tune (availability?)
Upgraded rubber
500+whp/500wtq
$7-8k estimated parts cost.
      03-21-2016, 06:30 PM   #106
shivaswrath
Drives: 2012 335i
F30 335xi
Pure stage 2
Downpipe
Chargepipe
Upgraded axles
Upgraded rubber
500+whp/500wtq
You will not be getting GTR times with the xDrive 335i!!
      03-21-2016, 08:19 PM   #107
oguz kuruca
Drives: F83 BMW M4
My car has the limiter, even with the JB4 I'm still stuck at 131MPH did any companies came with a fix to that?
      03-22-2016, 12:17 AM   #108
Sheharyar_rr
Drives: 14' 335xi M-Sport
Xi does have launch control. Although after numerous attempts i firmly believe its better to launch without it. Launch control is made for rwd and it softens the attempts made after since im guessing it adapts to the surface for less slippage but in xi, you want all that power. So DSC off and brake boost and BOOM!
Fastest time i've gotten is 4.0 with flash tune and dp measured via M Laptimer App
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP
Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile
Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile
      03-22-2016, 08:25 AM   #109
Chicken_Joe
That's actually pretty impressive. Hell not many Porsches launch much faster and they have one of the best AWD and LC systems out IMO
      03-22-2016, 09:17 AM   #110
ClevelandBeemer
ClevelandBeemer's Avatar
94
Drives: 2013 BMW 335i M-Sport
2021 BMW X5 45e  [0.00]
2013 335i  [0.00]
2015 BMW S1000R  [0.00]
You need a flash tune to accomplish that.
