11-05-2018, 11:27 PM | #89 |
Rep 10
Always-on fuse?
Hi guys,
Sorry to revive an old thread. I've followed all of the instructions in the OP by smithf80 to wire my DR750S-2CH + Power MagicPro. But for some reason, the PMP stops getting power (the LED on it turns off and the dashcam itself also turns off) within a few minutes after the engine is turned off. Everything seems to work fine with the engine running though. I've also tried the entire column of fuses where 161 is located and none of them seem to stay live for more than a few minutes after ignition is switched off. Any ideas? Did they change the fuse configurations for the LCI cars? Thanks in advance! |
11-27-2018, 07:40 PM | #90 | |
Rep 352
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
12-04-2018, 01:20 PM | #91 | |
Rep 10
Resolved!
Cheers! |
04-18-2019, 04:50 PM | #93 |
Rep 1
Hardwiring dashcam in rear fusebox 4 series F32 F36
Anyone with experience hardwiring a dashcam using the 4 series fusebox in the trunk..?
I have installed a Mini9606 dual channel cam and hardwire kit with parking guard and batt drain protection. I have routed the hw power cable together with the rear cam cable to back of my F32LCI, and am struggling tapping power from the rear fusebox. Issue I have is that the cam switches off on ignition off and start/stop, and can't get parking guard mode to work.. Tried various fuses, and direct battery connection , but can't get it to work properly. Anyone who can advise how to properly wire the hardwirekit to the rear fusebox on 4-series...? |
04-18-2019, 05:16 PM | #94 | |
Rep 10
04-19-2019, 12:19 PM | #95 | |
Rep 352
10-01-2019, 07:00 PM | #96 |
Lurker
26
Rep 61
Im using a Blackvue magic box pro with the exact same set up and it doesn't seem to be working for me. My set up is exactly as OP except for ground.
For the BATT+ you'll use an add a fuse on fuse #161. For ACC+ you'll use an add a fuse on fuse #143 For ground you'll just attach to the bolt on the car's where 3G connection receiver WOULD be. The magic box is not getting power to it and thus the webcam does not have power either. The fuses still have power as my tail light / accessories are still working. Could it not be grounded properly? I plugged the blackvue back into the cigarette lighter and it is working fine so I'm not sure why the fuses arent supplying power correctly.. |
10-04-2019, 12:19 PM | #97 | |
Rep 352
10-19-2019, 12:03 AM | #100 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
08-03-2021, 08:35 AM | #102 |
Rep 4
where can this be bought from? seems neat and tidy? any part no?
01-06-2023, 10:38 PM | #103 |
Rep 13
Bumping this thread as I’m hardwiring a BlackVue Battery (130) in the trunk of my 2018 328d.
Seems I need to use one of the 10A, and I have two options: 1: The one that goes on and off with the ignition, but is tied to engine things 2: The other one stays on for 6-10 minutes after you turn the car off and drains your car battery Does this sound accurate to the situation? Anyone else here running a battery in the trunk and have experience to share? Thanks! |
01-14-2023, 12:09 PM | #104 |
M340i
408
Rep 1,010
Drives: BMW M340i
There are many options to tap into. Does your dashcam have parking mode and use a 3 wire harness? The fuses the OP stated in the 1st post should work. My 2015 435i has a very similar fuse box. This is how I setup my dashcam with 3 wire kit. I did not use the extra battery protector thingamajig. Pic is from OP.
04-26-2023, 05:14 PM | #105 |
Rep 95
Dumbfounded on this one. I feel like I took the right route with this but I'm getting nothing from the camera whether or not the car is on. My car is a 2018 F36 440i gran coupe. Parking mode and whatever else appear to be right with the camera too. I've tried every setting on the hardwire kit to no avail. I have:
A119 V3 https://www.amazon.com/dp/B07JQ1JYPJ...roduct_details BATT+ I used an add a 5A fuse on 20A fuse #161. ACC+ I used an add a 5A fuse on 5A fuse #143 It works fine with the cig lighter but not with the hardwire kit. |
04-26-2023, 06:03 PM | #106 |
Rep 512
Drives: 320i M Sport Shadow Edition
A couple of checks to do…..
Have you made sure your ground is attached to the bodywork which is non painted? When adding the fuse taps do you have these the correct way round so that the live side of the fuse goes up and through the fuse? As per the below? |
03-27-2024, 01:52 PM | #107 |
Rep 28
Drives: Estoril Blue 2014 335i xdrive
Meaning of the hard to read fuse pictograms
Giving back to the group (6 years of Blackvue ownering)
My printed copies of the earlier posted fuse diagrams are a tad hard to interpret. THis hand site explains what all the pictograms mean: https://www.servicetutorials.com/202...ols-explained/
2014 Estoril 335i xdrive 6sp: M Sport, m perf power/brakes/sound kit, AA8 400 hp/ 420 ft-lbs. 10/15mm spacers. Dinan 3/4" spring kit, Misc coding. Mud flaps.
Racing/tuning/teaching since 1997. Long list of clubs as Chief, classroom and in-car instructor. |
