09-23-2018, 07:09 AM | #89 |
Rep 21
Hi, its possible retrofit PMA gen2 in bmw f31 non lci with NBT? Or need NBT evo? 2 extra sensor reator is PDC sensor or PMA?
09-23-2018, 05:23 PM | #90 | |
Rep 220
Yes I already have PDC & PMA but I'm adding the two extra rear-side sensors for the added PMA2 functionality. Your feedback is much appreciated! |
Deleted-User73.50 |
09-24-2018, 01:36 AM | #91 | |
I don't drive fast , i fly very low
Rep 358
if you have esys ( even without token ) then it's easy to read the CAFD file ( coding file ) of your PMA2 module , appreciate it if you can post it here . I've done few PMA1 and PMA2 retrofits so if you need any help , let me know . |
Zermatt90.00 Deleted-User73.50 |
09-24-2018, 01:37 AM | #92 |
Rep 358
09-27-2018, 04:26 AM | #94 | |
Rep 358
read my post above reading the sensor direction , F31 even with M rear bumpers still don't have the right angle for the PMA sensors. for front PDC , remember to add 2 extra wires when you run the harness from front to the back of the car , 2 extra wires are the signal wires of the PMA front sensors Last edited by ehssan_alkhiyami; 09-27-2018 at 04:27 AM.. Reason: add info |
09-28-2018, 02:27 PM | #95 |
Rep 21
My car dont have M rear bumpers my version is sportline. But for rear is necessary PMA sensor or PDC? Is possible retrofit with PMA gen2 but only add to front PMA sensors?
Thanks for help me. Last edited by Pedrom92; 09-28-2018 at 06:46 PM.. |
09-29-2018, 06:21 AM | #96 | |
Rep 358
Rear PMA sensors are normal PDC sensors exactly like the normal front and rear PDC sensors . |
10-01-2018, 06:46 AM | #98 | |
Rep 358
you can simply drill a 18mm hole and stick the sensor in it , but good luck with PMA not working properly . I am waiting for Zermatt feedback to get his coding file of his OEM PMA and compare with LCI non M car so see the how PMA module handle the missing rear 2 PMA sensors . |
10-02-2018, 02:08 PM | #101 |
Rep 277
10-02-2018, 03:00 PM | #102 |
Rep 21
10-03-2018, 03:56 PM | #103 | |
Rep 358
some fabrications is needed but possible . |
10-18-2018, 10:30 AM | #104 |
Rep 57
Hi. I'm doing this retrofit in a F48 X1, when I plugged in the front harness, ISTA says that theres a shortcircuit in the front PDC. I connected the parking assistant sensors as you did, using bmw fast connectors. I checked and the positive wire in the front connectors, doesnt show any voltage. I suppose that It may send some Signal when the gear is in D, isn't it? In the other way I think that although it is named in esys as PMA2, the ECU it's prepared only for rear PDC and that would be the problem. Any help? F48 differs than F30 that one ECU controls front, rear PDC and PMA
10-18-2018, 05:57 PM | #105 |
Rep 58
Hi everybody. I am working on this retrofit. I bought a full set of lci bumpers with included pma and pdc sensors. So i must buy the pm2 ecu. I have a pre lci, can you tell me the pn of pma2?
10-22-2018, 01:59 PM | #106 | |
Rep 1,154
66337938190 - Control module for Park Assistant Supersedes: 66336886210 (03/01/2017 — 03/06/2018), Exchangeable retrospectively 66336884836 (07/01/2016 — 11/21/2017), Exchangeable retrospectively 66336880742 (07/01/2016 — 04/11/2016) |
ehssan_alkhiyami13.50 |
10-23-2018, 06:25 AM | #107 |
Rep 358
10-23-2018, 06:29 AM | #109 | |
Rep 358
we are talking about PMA2 in the last few months of this thread . |
10-23-2018, 06:40 AM | #110 | |
Rep 277
pma1 has 4 front pdc 2 front pma and 4 rear pdc pma2 has 4 front pdc 2 front pma and 6 rear pdc |
