BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BMW M Performance LSD for 335i and 435i. Pricing and Technical FAQ.
      11-17-2015, 03:05 AM   #89
Krelle
Denmark
90
Drives: M2C
Originally Posted by Darkiedm4 View Post
My quaife was installed in 1h30min....
About the time we spend drinking coffee
Guess you didn't run into pulling problems
Ist der Motor kalt, Gib ihn sechs ein halb.....
      11-17-2015, 12:05 PM   #90
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Nope all went fine. You just need to have the correct tools.
      02-01-2016, 12:46 PM   #91
Alano_Mpower
Drives: Bmw 435i
in sweden it says that it will fitt xdrive......i will ask my stealership for more information
      02-12-2016, 05:58 PM   #92
Gio72
Drives: G80 M3 Competition
Yes, you're right!
I just noticed today that on italian Bmw webside, on the M Performance optionals page, they recently include 335i xdrive and 435i xdrive between cars that fit M Performance LSD!
BMW M3 G80 Isle of Man
      02-13-2016, 06:33 PM   #93
Polo08816
Drives: 2014 335i M Sport
Any info on what the cost is to rebuild this? I can't seem to find any part numbers for the internals.
      02-13-2016, 11:37 PM   #94
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Not a rebuild, it's an easy drop in.
Cost is about 5-6 hours labor.
SOLD: 2012 335i Mineral Gray
      02-14-2016, 02:21 AM   #95
Alano_Mpower
Drives: Bmw 435i
okey so is it worth getting??
      02-15-2016, 06:33 AM   #96
Polo08816
You're referring to the internals, correct?
... the context of my question is let's say I put the M Performance LSD in today and in 75,000 miles I would like to rebuild/replace the worn clutch(packs)....
      02-15-2016, 07:15 AM   #97
Gio72
I've just installed the M Performance LSD on my 435i and I'm very pleased with the improved handling and fun!
Not lots of opportunities to test it, but the car seems clearly more inclined to oversteer on tight corner (because of absence/limitation of internal rear tyre spinning) and got much more traction, even on the "simple" DTC mode.
Must-to-have for me
      02-15-2016, 10:57 AM   #98
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
http://www.gse-getriebeservice.de/er...erentiale.html
It's a german Company offering repair kits or refurbished LSD i.e. for the M3 E46.
Long time short. Probably easiest way is to go for a complete refurbished LSD Box in Exchange for your old one. Assume this will be priced around $1'000.- without labour.
On a quick search I could not find a Price for F3x refurbished M Performance LSD. Guess it's not yet time for that, but E46 prices give you an idea.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      02-15-2016, 11:12 AM   #99
Polo08816
Did some additional searching...
Found these sites:
http://bimmerdiffs.com/collections/1...-service-parts
http://diffsonline.com/
      02-15-2016, 09:17 PM   #100
Polo08816
So can someone explain the difference between these two (from the same vendor)...
1. https://www.getbmwparts.com/parts/in...&siteid=214672
2. https://www.getbmwparts.com/partloca...catalogid=4462
... seems like they are the same part number... with very different cost.
The only thing that makes sense is one of them is the LSD internal and one of them includes the entire final drive assembly.
      02-16-2016, 09:50 AM   #101
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
You are most likely correct. The more expensive one is described as being a "Full replacement differential, no modification of existing differential necessary".
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      02-20-2016, 06:14 PM   #102
Gio72
Originally Posted by Thrillbilly View Post
Will this also fit xdrive? I hope so...
I recently noticed that in the official BMW website the M Performance LSD now fits also 335i xdrive and 435ixdrive!
      02-20-2016, 10:36 PM   #103
Polo08816
...So I went through this entire thread searching for the string "weld".
Any idea whether the M Performance LSD has a welded or bolted ring gear? The stock differential has a welded ring gear, but I'm hoping this M Performance LSD has a bolted ring gear to make rebuilds easier?
      02-21-2016, 02:51 AM   #104
cryptocar
cryptocar's Avatar
I have no idea about the M-Perf LSD since I'm really interested in the Quaife myself, but I'm quite sure they are all welded. It was a engineering/design choice by BMW to the best of my knowledge. The swap isn't hard with the right tools which is just like any other job. At least one poster in this thread who did the job with the right tools did it in under 2 hours.
      02-21-2016, 06:54 AM   #105
Polo08816
Forgive me...I'm a diff noob...
The swap of the entire assembly isn't too difficult as long as you have a lift and a diff/transmission jack + other tools.
But I'd rather be able to just put in new clutch plates or at least be able to swap the entire diff carrier once it comes time to rebuild? All of this would seem to be easier with a bolted design instead of a welded design.
      02-21-2016, 09:14 AM   #106
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
That'd be awesome if my 335i wasn't totalled by grandma pulling out in front of me. But my F80 came with the diff pre-installed
If I still had the F30x I'd be all over it.
      02-21-2016, 10:50 AM   #107
cryptocar
cryptocar's Avatar
You can swap the whole unit but it's significantly more expensive up front due to core deposit etc.
The welded crown wheel was chosen to reduce weight and size
http://www.zf.com/corporate/en_de/pr...wn_wheel.shtml
If you really wanted a bolted crown wheel then you'd likely need an entirely different housing than stock since the stock was designed around the smaller size and weight of the welded crown wheel.
You simply need the right tools and when I say right tools I mean specialty puller tools designed to remove this type of welded diff, not just common garage tools and lift/jack. Darkiedm4 said he did it in 1.5 hours.
      03-21-2016, 03:44 PM   #108
Polo08816
Not sure if everyone's following (or if I'm correct), but it seems like the MSRP and price for this has changed (decreased).
http://www.getbmwparts.com/partlocat...catalogid=4462
      03-21-2016, 06:25 PM   #109
shivaswrath
Drives: 2012 335i
Most of us (or I think I did) got it for nearly that price, when you factored in installation at the dealer ($2700 all in).
      03-24-2016, 09:05 AM   #110
Gio72
Yes, that's true!
One month ago I bought mine by a friend of mine, who sold its 435i Cabrio to buy an M4 and only then I realized that BMW decreased the LSD price
