03-06-2020, 12:04 PM | #1167 | |
Rep 256
anyone have a front camera they recommend? just seems a few on ebay Last edited by nitsuj17; 03-06-2020 at 01:19 PM.. |
03-06-2020, 02:34 PM | #1168 |
Rep 109
I'm still having a lot of problems with the unit not connecting to my iPhone automatically. I spent well over 5 minutes yesterday futzing with resetting it, clearing out the CarPlay pairing on my phone and trying to re-pair, etc. Sometimes it's fine and sometimes it just will not connect.
What's odd is that on the iPhone's CarPlay setting screen, when it's first searching for it, it shows as Carplay8003830 or something along those lines. Then once it connects, it switches to being identified as "GPLink". When the unit won't connect, I sometimes can go into this settings screen on the iPhone and I see both GPLink (under "My Cars") *and* the Carplay8003830 (under the new available CarPlay list). Where can I keep an eye out for updated firmware for this thing? |
03-06-2020, 04:48 PM | #1169 | |
Rep 256
What is your current system and MCU? What BMW hu do you have? Does it always not connect or just sporadically? Have you tried different MCU and system files in combination with each other? Do you have the andream box? Which iPhone do you have? Are you connected to home wifi when trying to pair? Good to know if trying to figure out a solution |
03-07-2020, 06:25 AM | #1170 |
Rep 21
Hi all,
I’m new here and this is a very interesting post to follow. I have the andream box installed in my i3. 2 things I have to sort out. 1 echo with phone calls. But only when I volume up. Not on low volume, then all is ok. 2 can I change the volume of Siri etc. When listening to music and want to activate Siri that voice is less volume than my music. And I can’t hear it very well. Also while navigating through maps. Voice is low on volume. |
03-07-2020, 11:32 AM | #1171 | |
Rep 1,217
x-m4n148.00 |
03-07-2020, 01:13 PM | #1172 |
Rep 21
Couple of questions that I haven’t put a lot of thought about using this box for 2 weeks now,
1. Am I the only one not seeing the volume control bar when changing the volume? Right now the volume would go up and down with the steering wheel control as well as the knob on central console but wont show the any bar on screen. 2. Does the steering whee control(wheel) for next/prev track work for you guys? Right now the buttons are the only thing I use on the far right of the central console to change tracks. |
03-07-2020, 02:57 PM | #1173 | |
Rep 767
The andream firmware didn't skip/prev songs for me and vía AliExpress they told me it was not supported. For that reason i am running the btech firmware |
03-07-2020, 04:06 PM | #1174 | |
Rep 256
Do you mean the slight turn up or down and click like on idrive to switch tracks? That doesn't work because the clickwheel moves the cursor when you do that in carplay. With my carlinkit on latest firmware the buttons on the head unit work, clicking on idrive wheel when the cursor is on the next track (and same with steering wheel clickwheel) and clicking left or right on idrive controller switch tracks for me |
03-07-2020, 06:58 PM | #1175 |
Rep 54
03-07-2020, 07:04 PM | #1176 | |
Rep 54
03-07-2020, 07:06 PM | #1177 |
Rep 54
03-08-2020, 05:37 AM | #1178 | ||
Rep 256
If that's the case then you wouldn't have sound in Waze. It's either carplay or idrive for sound, not both at the same time. You would have to listen to music on carplay |
03-08-2020, 09:09 AM | #1179 |
Rep 7
I'm looking to install an MMI in 328xi (F30)
Car production date: 5/27/2015 Current HU: Entry Nav Screen: 6.5"(NO Navigation) Used screen bought: 8.8" (see image) Question 1: Do l need to code the current HU for the widescreen mode before installing the MMI or will the MMI upscale the signal from the HU? Question 2: What software version , for the MMI, is the most current/ trouble free and how can one tell before ordering the MMI? Thanks |
03-08-2020, 09:33 AM | #1180 |
Rep 3
Hey guys I have an andream box with the latest software posted a page ago or so and have been having several issues and I was wondering if anyone else was having them or if I possible have a defective unit.
I have had the box installed for a week and it has frozen/crashed twice, also had it where audio was skipping like if you were playing an scratched CD which I had to disconnect the phone to fix. Also had the unit video mess up like it had bad connection(picture attached below) but when i switched to BMW oem it was fine so it was not a hardware wiring issue just an mmi software issue. also has anyone else notice how turning off the vehicle does not reset(shut off) the box at least not immediately, which means that this unit seems to be powered all the time even when ignition is off. Last edited by neosolidus; 03-08-2020 at 09:39 AM.. |
03-08-2020, 09:59 AM | #1181 | ||
Rep 256
Then the mmi....but you could really do it all at once. I plugged the new CID in, coded and made sure it worked right then installed the mmi and reverse cam all in one shot. Took about 3 hours, mostly just taking trim off and placing it back Quote:
03-08-2020, 10:39 AM | #1182 |
Rep 3
03-08-2020, 10:42 AM | #1183 | |
Rep 289
For the rest, yeah seems like a broken MMI. |
03-08-2020, 01:18 PM | #1184 | ||
Rep 21
When I look at my phone it's WiFi is connected to the mmi. Even when the car is parked for more then 24h... So the mmi looking for connection and making one is 24/7. Oh and I still can't figure out how to get Siri volume equal to music volume... |
03-08-2020, 03:30 PM | #1186 |
Rep 256
03-08-2020, 04:24 PM | #1187 | |||
Rep 7
Teecue |
03-08-2020, 07:21 PM | #1188 | |
Rep 109
I have CUST v2.0.2.7.gpe.b which is the newest from Andream. MCU 20.1.4.11. Headunit is BMW_NBT. I have not yet tried changing any of the software since it seems to be up to date. Slightly afraid of breaking something since when it does connect, all other behavior is perfect. |
andream, android, android auto, apple, carplay, mmi, retrofit |
